Go to Post I didn't think it was possible for Dave to be any more cryptic. I was wrong. - IMDWalrus [more]
Unread 16-02-2003, 01:12
Icebreakers Icebreakers is offline
#0374 (The Icebreakers)
Icebreakers is an unknown quantity at this point
Cool RCU has bad Analog ports - what now?
We've been trying to rectify a situation that we thought was bad potentiometers. When looking more carefully & using our controller from last year, we discovered that analog port inputs # 6 and 7 do not work. Since we had not previously plugged anything into them, we think they came to us defective.
Our question, then is, can we use last year's controller to work with until we get to regionals. During that time we could return the controller to FIRST or to Innovation FIRST for a replacement.
We're posting this question here since it is unlikely the FIRST board will be moderated this weekend.
Thanks.
Team 374
The Icebreakers in Anchorage
GO TEAMS!
Unread 16-02-2003, 11:52
JJG13's Avatar
JJG13 JJG13 is offline
Yoda
AKA: Joshua Graffman
None #0180 (SPAM)
JJG13 has a spectacular aura aboutJJG13 has a spectacular aura aboutJJG13 has a spectacular aura about
It will not work, because the controller from last year is not compatable with autonomous mode. Sorry
Behold the power of SPAM.
Unread 16-02-2003, 15:52
Unhappy
Thanks for the post. How do you think we go about handling the situation at this point? This weekend there is no one at FIRST or at Innovation to contact, and shipping happens in 2 days. We posted on the FIRST site, but no replies there, either. Should we just take the defective unit to regionals & hope to get a replacement there? Or mail it to Innovation & hope to get the replacement to take to regionals & replace there? I really hate crunches like this at this point.
Thanks for any advice.
GO TEAMS!
Unread 18-03-2003, 13:56
Dan's Avatar
Dan Dan is offline
#0267 (Demolition Squad)
Dan is an unknown quantity at this point
Send a message via Yahoo to Dan
Our analog 6 & 7 ports are also bad. They report (via dashboard) 0 for values when the RF link is used, but are correct when tethered. This makes no sense at all. Any ideas?
Unread 18-03-2003, 16:10
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
did you try debug?
Did you try using the debug command in the program, just to rule out a problem with the dashboard?
debug "in6 = ", dec sensor6, "in7 = ", dec sensor7, CR
Unread 18-03-2003, 17:15
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Actually, last year's controller should work just fine with autonomous mode. IIRC, all autonomous mode does is change one bit and set all OI inputs to 127. You would have to use this year's OI, however, and you probably couldn't test autonomous by selecting Team 0000 (although I am not sure about that).
Zan Hecht
Unread 18-03-2003, 18:02
dhendrix's Avatar
dhendrix dhendrix is offline
#0538 (Dragon Slayers)
dhendrix is an unknown quantity at this point
last years controller
Acually, last years controller will work. We used last years during practice in St. Louis. First has spares that they will loan for the weekend.
Unread 25-03-2003, 09:23
None #0116
dashboard port changed
There is a new document on IFI's web site, the analog 6 and 7 bytes in the data stream contain system feedback data when the robot is not tethered. Thats probably why they seemed like they weren't working with the dashboard. When the robot is tethered they're supposed to have to correct values.
Dan - Your controller is fine, but its sending the wrong information for analog inputs 6 and 7 when you're using the RF link. Thats why it works under the tether.
Unread 25-03-2003, 12:48
Jeff_Rice's Avatar
Jeff_Rice Jeff_Rice is offline
ElementisRegamusProelium
#1359
Jeff_Rice will become famous soon enoughJeff_Rice will become famous soon enough
You don't have to use this year's OI.
Make a switch, label it autonomous, connect to a ground and a digital input on say, port 4.
Put this next to your light code, and it should always get executed. Now you have an autonomous switch.
if (put switch name here) = 0 then dontsetauto
auton_mode = 1
goto endautoset
dontsetauto:
autonmode = 0
endautoset:
"He said my name is Private Andrew Malone
If you're reading this then I didn't make it home
But for every dream that's shattered another one comes true
This car was once a dream of mine now it belongs to you
And though you may take her and make her your own
You'll always be riding with Private Malone" David Ball, "Private Malone"
Unread 25-03-2003, 13:15
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
auton_mode = 1
goto endautoset
dontsetauto:
autonmode = 0
endautoset:
Ouch! Why not
auton_mode = yourSwitchName
Unread 25-03-2003, 13:46
Jeff_Rice's Avatar
#1359
Because I like to do things in overly complicated ways.
Actually, it's because I like that format. I've used it so much that it makes more sense to me.
Unread 25-03-2003, 16:02
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
Both the old OI and RC will work and support autonomous mode except for the flashing disabled light on the OI. As they will work, it specificly says in the rules that old control systems may not be used, except for radios.
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
Unread 25-03-2003, 18:42
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
Are you sure about that? I believe the new OIs are key to "real" autonomous mode. It's possible that the state of pin 5 on the competition port may show up in the auton_mode variable on the RC -- in which case, your autonomous program might work correctly. But I think the new OIs actively set all the OI inputs before sending the data to the RC.
Unread 26-03-2003, 07:27
rust710's Avatar
You might be right, but I code my projects specificly to reject any input if the auton_mode bit is high.
Andrew Radamis
Programmer on 862
RCU seeks new leadership MissAbi General Forum 1 23-06-2003 23:27
To the chicks of RCU archiver 2000 1 24-06-2002 00:29
Bad, bad, bad!!! archiver 2000 13 23-06-2002 22:29
RCU Unveils One Year Anniversary Site! Lora Knepper General Forum 2 10-07-2001 11:23
RCU Illuminaries for the week of the 24th Lora Knepper General Forum 5 28-06-2001 17:52
