Go to Post You all have made me think about this in a new way - which I appreciate. - aaeamdar [more]
Unread 28-03-2003, 23:04
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
Question Wheel wear??? 6" Pneumatic tires???
In the 2 regionals we've competed in, we've used the 6" Skyway rubber wheels, and they have been chewed up pretty bad by the ramp. We find that we need to replace them about 1/2 way through the competition.
Since we need new wheels for the Natl's, we're considering going to the 6" Skyway pneumatic tires.
Anyone have experience with how these wheels hold up? I believe Rage is using them. Any comments guys?
I do note that they have much better traction all around (especially on the top ramp surface), but I am very concerned about wear, since obviously the outcome of wear in a pneumatic tire can be a flat!!!
Any experience, especially with the 6" Skyway wheels, would be greatly appreciated.
Thanks,
Scott358
Unread 28-03-2003, 23:40
MarcusF MarcusF is offline
#0157 (Aztechs)
MarcusF is an unknown quantity at this point
Send a message via AIM to MarcusF
Last year we used the 6" ones and they held up great 2 Regionals and nats along with a ton of other events. This year we are also using 8" ones and they are just as good.
Unread 28-03-2003, 23:56
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
we have used pneumatic tires for two years now. If you are worried about wear, dont be... we ran our current tires for a bit last year, through practice this year, through a 21 match regional this year, and through 4 matches today, and finally we had to replace the tires because they had gone bald. You dont need to worry about wear that much...
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 29-03-2003, 00:09
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
I would recommend using timing belt around the outside of the skyway wheels. Yes we leave about half of our tread behind in every match but its worth it.
take a look at this pic
258's wheels with tread
It grips well on the carpet as well as the HDPE. The only problem is that the mesh eats it like a cheese grater.
Unread 29-03-2003, 00:37
Powers's Avatar
Powers Powers is offline
#0710 (PAW)
Powers is on a distinguished road
Send a message via AIM to Powers
We are using some kind of wheelchair wheel in the front, not sure what kind, i think foam filled, and Goped wheels to drive, they are cool.... We have had no wheel problems so far, and did not need to change our wheels
Team 710 PAW Alum
The team that supports the use of the word "Blatantly"
TEXAS WON THE ROSE BOWL
Unread 29-03-2003, 00:39
Engineer/Mentor
AKA: Scott5736
Thanks for the comments... Question for Marcus & Cory...
.... are either of you specifically using the Skyway pneumatic tires?
The reason I'm being so specific is that the type of rubber will effect the wear, so if you were using a different tire (with a "better" rubber) the Skyway pneumatic tires might not wear as well (especially on the ramp).
Regardless of what you're using, congrats, since many people have had wear problems from the ramp.
Please clarify if they're Skyway.
Thanks,
Scott
Unread 29-03-2003, 00:44
Cory's Avatar
AKA: Cory McBride
Re: Thanks for the comments... Question for Marcus & Cory...
Thanks,
Scott
We are using skyway 8" pneumatic tires. They are labeled as Cheng Shin, but are sold by Skyway.
GilaHumanPlayer:
The cheesegrater comment was right on. By the end of thursday, 258's treads were mutilated. Oh well, reduced lifespan is the price you pay for high traction I guess...
Cory
2001-2004: Team 100
Unread 29-03-2003, 06:59
roboticscom13's Avatar
roboticscom13 roboticscom13 is offline
roboticscom13 is an unknown quantity at this point
Our team is using Skyway's 6 inch pneumatic wheelchair wheels and we have no complaints except for getting the psi right takes some trial and error depending on what you want. Our wheels still look practically new and we are in our second competition now.
Unread 29-03-2003, 08:16
Joel J's Avatar
Joel J Joel J is offline
do you..
Thanks,
Scott
We have used 6" Skyway pneumatic tires for the past two years, and they do wear eventually. Last year we had to switch out tires before every regional, because lugging around a goal took its toll on the wheels. However, this year we haven't replaced our tires yet. So I imagine they'd do well.
[BTW] Wear on the skyway pneumatic tires could be a good and bad thing.. the more they wear the better your traction is on the carpet and mesh, but the harder it is to turn if you are using all pneumatic tires; however, you may not have a problem with that.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 29-03-2003, 10:30
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Yeah well we used the stock 9 inch skyway wheels and in our first practice match we actually managed to rip holes (not just the treads) out of the tires. It is proabably why the robot steered so poorly.
Unread 29-03-2003, 11:36
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Pneumatic tires
Team 121 used those 6'' tires this year and last year, and there are many advantages and disadvantages with them.
The tires wore out pretty fast for us last year because we often gotten in tugging contest for a goal. When the wheels are turning but the robot isn't it will cause it to go bald almost immediately. Last year in 9 competitions we had to replace it 4 times I believe. This year however is somewhat different, and we actually have a pretty good tread left after practice and the BAE Regional.
The one thing I hate about those wheels however is that changing the tread only is impossible because after you change it, it weakens the bushing that holds the shaft, and tends to want to come out of the wheel.
Unread 29-03-2003, 13:35
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
What wheels will these tires fit on? Also how wide are they?
