Go to Post Magic doesn't count as a support, sorry. Neither does simply constraining in CAD... - EricH [more]
Unread 16-01-2002, 17:26
Anton Abaya's Avatar
Anton Abaya Anton Abaya is offline
None #0419 (Rambots)
Anton Abaya has a spectacular aura aboutAnton Abaya has a spectacular aura aboutAnton Abaya has a spectacular aura about
Send a message via ICQ to Anton Abaya Send a message via AIM to Anton Abaya
Shifting Gears --
After taking a poll, it seems a lot of the teams who browse Chiefdelphi are going to be building dual transmission robot. I guess I would define this as a robot that can shift gears (low to high).
http://www.chiefdelphi.com/forums/sh...&threadid=1697
Now with this information, can someone post what they have done in the past? I'm particularly interested in "on-the-fly" gear switching mechanisms using spur gears or a built gear box. But post anything and everything you're willing to share.
As always, I am grateful for your help.
-anton
Unread 16-01-2002, 17:56
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Last year we used drill motors for propulsion. We used servos to shift gears. The problem is you had to be standing still to shift. We had a spring go from the servo arm to the shift lever. The spring acted as a servo saver and wouldn't stall the servo. When the servo arm would swing left/right the spring would pull on the shifter. It worked pretty well.
Wayne Doenges
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 17-01-2002, 09:50
s_alaniz s_alaniz is offline
#0057 (Leopards)
s_alaniz is an unknown quantity at this point
Shifting
Anton,
If you're willing to build your own shifting transmission, I suggest you look at a moped/minibike transmission, they do auto shifting AND RC car transmissions. We are attempting to develop shifting but as yet all our ideas are unproven
Best Wishes
Steve Alaniz
"Ted, I think the microwave just exploded your soup" - Sally Forth
" Once agin, technology turns on it's masters." - "Ted Forth"
Unread 17-01-2002, 10:14
BillCloyes's Avatar
BillCloyes BillCloyes is offline
#0677 (The WireStrippers)
BillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura about
Wayne Doenges
Could you post some pictures for this spring lever.
Unread 17-01-2002, 10:47
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Talking TRANNY
Maybe I will be nice for once and give you a picture of our shifters!
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 17-01-2002, 14:06
Matt Reiland's Avatar
'The' drive behind the drive
See if someone has a picture of the HOT BOT from last year they had a trick shifting mechanism using little air cylinders. I don't know if they used it but it looked really cool
Matt
Unread 17-01-2002, 22:10
Mike Rush's Avatar
Mike Rush Mike Rush is offline
Somewhat Insightful
FRC #4154 (Perpetual Recursion)
Mike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really nice
Why shift? Why not a continuously variable transmission? Any thoughts?
Unread 17-01-2002, 22:21
like using belts similar to the insides of a drill press? lots of friction perhaps? i dunno.
Unread 18-01-2002, 10:29
CaptainPlaid's Avatar
CaptainPlaid CaptainPlaid is offline
#0314 (Megatron Oracles "Big MO")
CaptainPlaid is an unknown quantity at this point
Shifting 2 Drills with 1 servo
It is also possible to shift both drill motors with one servo. We did this on Big MO two years ago. However you still have to stop to shift. On-the-fly shifting is the way to go. By the way, HotBots shifting did work last year. Now if only there was pictures.
I have not failed. I have just found 10,000 ways that won't work.
Thomas Edison
Unread 18-01-2002, 20:37
thedillybar thedillybar is offline
#0894 (Chargers)
thedillybar is an unknown quantity at this point
Send a message via AIM to thedillybar
2 sets of drive wheels?
Our team is going to try to shift on the fly by having 2 sets of drive wheels that are always spinning (one set for high gear, one set for low gear) and putting the high gear wheels down with a pneumatic. I am skeptical of it but only time will tell.
Unread 20-01-2002, 08:48
Dr.Bot
Posts: n/a
A transmissiom would be cool - anyome thought of using something smple like a bicycle chain dereiler? This would be failry easy if using one drive wheel - harder if two drive wheels -
you'd need a differential - really hard if using a 4 wheel drive.
The drill press stacked pulleys are really the same thing has the
typical bicycle gear cluster, and I have seen designs for 'infinately variable speed transmissions based on two parabolic cylinders and a drive wheel.
Remember automatic transmissions work because of fluidic coupling - ie they are clutch less. Manual transmission rely on the
very sophisticated feedback system of a human mind to match the
speed of the motor to the speed rnage of the wheels.
So while I see that some of you suoer sophisticated teams will want to be both super fast and have super torque, think about all those gears and sprokets and things getting strewn all over the competition floor. What is the problem you are trying to solve? Is a multi-speed transmission the only way to do it?
Unread 20-01-2002, 16:21
Jon Lawton Jon Lawton is offline
Bitter FIRST Cynic
Jon Lawton is an unknown quantity at this point
Send a message via ICQ to Jon Lawton Send a message via AIM to Jon Lawton
Personally, I love this idea to bits! Being from the "Computer Science" side of the force, I'm not exactly sure what the best way is to make one of these contraptions. I think other teams have done it with varing degrees of sucuess? Could those teams who have made CVTs please tell us about them? Pictures too! Thanks!
Unread 20-01-2002, 17:21
schitnis schitnis is offline
schitnis is an unknown quantity at this point
Transmotion
One idea which we had, but we did not use it, was that there be a cradle for the chain on the gear. then, a high torque, low speed motor was taken and made to pull this cradle left and right and make the chain go from gear to gear. We did not consider this design because a bike chain is required to be used. It is same like a multi speed bike. Need presicision work
Works in moton and while standing !!!
Regards
schtnis
Team 915
Unread 20-01-2002, 19:09
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
We did consider building a CVT, but we decided against it. We came up with a much better idea, and it is simpler and easier to build. I won't tell you what it is our how it works, but anyone going to Cleveland or Chicago will get a chance to see our secret drive system in action and on display. I bet you all can't wait to see...
Unread 20-01-2002, 21:44
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Re: 2 sets of drive wheels?
We are doing essentially the same thing, Fast and Slow wheels, powered by the same drill motors, but to conserve space only skid plates will be used in conjunction with the fast wheels.
Shifting Gears MBosompra Technical Discussion 71 23-07-2004 02:49
Regional & Division winners, did you shift gears or not? DougHogg Technical Discussion 34 02-05-2003 16:10
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
