Go to Post Were cargo shorts ever in fashion? I thought they were in the socks with sandals category. - AdamHeard [more]
Unread 21-01-2002, 13:10
Oakridege_665 Oakridege_665 is offline
#0665 (Oakridge NASA)
Oakridege_665 is an unknown quantity at this point
Send a message via ICQ to Oakridege_665 Send a message via AIM to Oakridege_665 Send a message via Yahoo to Oakridege_665
hooking up sensors to controller?
This may have already been asked before but how I supposed to hook up the sensors so the robot can receive data from them? I thought all we had to do was solder the wires to an adapter and hook it up to the RC. One of the engineers was talking about hooking it up to a ciruit and something about and amplifer. Even if I was wrong, isn't what he is suggesting more then needed?
Unread 21-01-2002, 13:20
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Smile Re: hooking up sensors to controller?
What sort of sensors are you talking about?
I believe the sensors that come in the kit are described in the specification. Their connection to the A/D port is also described in one of the section.
On the other hand, if you are talking about other sensors....say, something contained in the CUSTOM CIRCUIT, then you can do alot with amplifiers and such. That is what the word CUSTOM refers to.
Please explain in a little more detain and I'm sure I will understand.
Thanks,
-Quentin
Team 4987: Megarams
Unread 21-01-2002, 13:21
#0811 (A.R.C.)
Re: Re: hooking up sensors to controller?
Ooops...detain should have read detail.
(sloppy fingers get me every time!)
Team 4987: Megarams
Unread 21-01-2002, 13:41
I am talking about the ones that came in the kit. I am trying to do this blind, I'm not sure where the specifications are. We may still have them or they may be lost.
Unread 21-01-2002, 14:54
diego25 diego25 is offline
diego25 is an unknown quantity at this point
Find the FIRST manual, and towards the end, it will tell you how to hook up each sensor (i.e. which wire goes to which pin). Then head over to innovationfirst.com/FIRSTRobotics/ and download the Control Systems Manual. There it will tell you the PBASIC variables that you have to use to get values from the sensor.
Diego
Unread 21-01-2002, 14:55
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
Here's what you'll need.
1) Section 2.0 of the robot.pdf file. It was erroneously omitted on the initial release, but they have since posted it. Section 2 outlines all of the eletrical requirements for your robot.
2) A copy of the InnovationFIRST Control manual. You can download that from the IFI website. Contained in the document are tables defining the pin definitions for the analog and digital data ports on the robot controller.
Analog inputs included in the kit are potentiometers and the yaw rate sensor. Be careful with the pots, you wire them differently on the robot than you do on the operator interface. Digital inputs are limits switches, pressure switches, and optical sensors.
That should be enough to get you going. Remember to read all of the docs carefully before you power up the first time and make sure you have somebody ready to turn off the circuit breaker.
Good luck, I hope it helped.
Warren B
Pool Noodles. They're not just for bumpers anymore.
C controller Rorschach Kit & Additional Hardware 1 29-10-2003 19:21
Robotics Tournament at Sensors Expo & Conference Kyle Fenton Off-Season Events 4 04-05-2003 12:15
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Hooking up Controller to computer for programming. Dragon45 General Forum 3 30-01-2003 00:22
pre-built autonomous sensors? BandChick Technical Discussion 4 05-01-2003 22:06
