Go to Post Never underestimate the ability of a team of high school students and engineers to break expensive things. - Alan Anderson [more]
Unread 21-01-2002, 15:08
kangarue23 kangarue23 is offline
kangarue23 is an unknown quantity at this point
Question More than 2 pneumatic tanks?
Are we allowed to have more than the 2 Clippard Instruments tanks? Also, are we allowed to order larger thanks?
Unread 21-01-2002, 16:13
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Q1) If the parts list shows 2 being shipped to you, than two are the most you can have on your robot.
Q2) Unless there are any in the Small Parts catalog or on the Additional Hardware list, than you can't order any other sizes.
Wayne Doenges
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 21-01-2002, 17:39
Kai Zhao Kai Zhao is offline
#0686 (Bovine Intervention)
Kai Zhao is on a distinguished road
Send a message via AIM to Kai Zhao
I heard some teams last year ordering the largest piston they could, and cutting the stoke off, to use as a large tank. I don't know how practical it is, try searching the old forums about it.
Unread 21-01-2002, 17:46
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Extra air at a price
You can also use an extra cylinder as a storage tank. Many teams did this last year. However, there is a price:
First, it means one less actuator. A cyclinder used in this way must be mounted in such a way that the piston does nothing at all. Preferably you use the retract side of the cylinder as your reservoir. That way the piston wants to stay in. But if you have the space and need the volume you may have the piston fully extended.
Second the piston adds weight and potentially removes volume, though not very much.
Of course, if you do this you want to get the biggest cylinders on the list. Remember that you are not allowed to modify the cylinders in any way. So don't even think about cutting off the piston rod.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 21-01-2002, 19:10
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
I had an idea last year and it basically went like this
if you had small actuators and could afford the air being a lil slow through the regulator and needed more volume at 120 then you could use a coil of the penumatic hose set up with 2 tees so that the air could flow straght to the regulator without having to go though the long loop of hose but the hose would give extra volume, basically cut into your supply line, put a tee on each end, then connect your loop to the tees then connect a small maby 2" peice of line between the other output of the tee..
if your interested here is a very crude drawing.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 22-01-2002, 09:53
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #0930
Team Role: Parent
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
Don't forget, pneumatics from Small Parts are not allowed on the robot! See Robot rules.
Unread 22-01-2002, 12:58
The big guy
i wish that the pumps we have did have a pressure input on them... if it did then we could bleed the pressure from an extended but retracting cylinder back into the pump to make its work easyer. kinda like a closed system.. but I can see problems with it too..
you would need a popoff valve on the return pressure side to prevent the return and the supply from equalizing and freezing the cylenders untill the compressor could lower the pressure in the return side.
but its all a moot point cause the compressor doesent have that input, and we cant make a fitting for it to have...
tho another interesting idea is to use exuasted cylender air to cool your motors.. I mean it was cooled when it expanded from the cylender and its going to waist if you dont do somthing with it..
ohwell.. just a few thoughts.. take them as you will
Justin Stiltner
KI4URQ
Unread 23-01-2002, 00:18
Jon Lawton Jon Lawton is offline
Bitter FIRST Cynic
Jon Lawton is an unknown quantity at this point
Send a message via ICQ to Jon Lawton Send a message via AIM to Jon Lawton
Curious... why would you want more than two tanks worth of volume? I suppose if you triggered large pneumatics repeatedly you might run into trouble... but... why else?
Unread 01-05-2002, 03:34
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Umm...
You're absolutely limited to reservoirs you get in the kit?
Can you not use something like steel conduit for storage purposes?
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 01-05-2002, 09:47
Originally posted by FotoPlasma
Umm...
Wouldn't that come under the rule against "manufacturing your own pneumatics equipment" ?
Unread 01-05-2002, 12:14
Andy A. Andy A. is offline
Getting old
FRC #0095
More storage is always good!
If you hang your hat on pneumatics, then you want all the reserve power you can get. The compressor is heavy, and if you can get enough storage on the 'bot to get away with out having that compressor mounted, then all the better. That much less weight, volume and power use you need to worry about.
So, outside of having lots of air to use, you might be able to drop the compressor altogether.
-Andy A.
Who has used pneumatic wheels? chellyzee93 Kit & Additional Hardware 3 16-02-2003 11:49
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
Pneumatics and last year's storage tanks Darwin695 Pneumatics 3 04-02-2003 02:13
pneumatic system pressure illumanat'i Pneumatics 6 31-01-2003 00:46
How can i mount a pneumatic piston to a pvc pipe!?!?! archiver 2001 4 24-06-2002 01:11
