Go to Post If you want to win, steal from the best, invent the rest. - Michael Corsetto [more]
Unread 13-04-2003, 01:29
maclaren maclaren is offline
AKA: Dexter
FRC #0997 (Spartan Robotics)
maclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of light
Lightbulb Drivetrain, what did you use?
I just wanted to hear what people used for their drive trains including:
Team #?
# of years of participation?
# and type of motors?
# and type of drive wheels?
# and type of non-drive wheels?
Transfer system(chains, belts, etc.)?
Transmission (not including supplied ones)?
Steering?
Sensors?
Success?
Problems?
Next year?
My response:
team 997
2nd year
2 drill motors
2 solid rubber 9"dia. 60 durometer 3" wide
2 wheel chair wheels
direct drive via shafts and gears
the supplied right angle gear box
automotive rear-wheels steering
no sensors
we busted the supplied gear box once and our steering sucked
never use automotive steering ever.
next year simple box chasis tank steering as many motors as possible and a transmission.
Unread 13-04-2003, 03:08
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team 696
3rd year team
2 drills and 2 chiaphuas
4 Skyway 9x2 Beadlok turned down to 8.5 di
0 non-drive wheels (casters are not allowed near our robots)
#35 Chain with carbon steel sprockets riding on 5/8 keyway shaft
3.5:1 reduction between Chiss and Drills; 4.8 reduction between drills and wheels
Skid Steering
No sensors
Much success, 9fps and loads of torque.
Problems - Misalignment, shafts wandering out.
Next year - Provided we have the same equipment, we will either do the same thing with some minor refinements or have a totally new 2 speed drive. Depends on game and engineer support.
Unread 13-04-2003, 10:25
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Team 296
5 years
2 drill, 2 CIM
4 solid rubber 6" wheels
no non-drive wheels
belts between the motors, chains to the wheels
supplied transmission
skid steering
no sensors
success - ~10 fps and lots of power
problems with pulleys coming un-setscrewed and with drill transmission
next year - depending on the game, maybe something a bit more complicated like crab
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 13-04-2003, 11:05
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
Team 422
4 years
2 CIMs (previously 2 CIMs and 2 drills)
2 6 inch wide 6 inch diameter machined aluminum wheels with hard neoprene covering
2 HDPE machined skids - 3 inch diameter touching the floor
Direct drive using a gearbox for the CIM to gear it down to the high speed of the drill; we then mated both on a giant 80-tooth gear on a 5/8" shaft to the wheels
Two-wheel drive (tank-style steering)
Two optical sensor encoder wheels to count the revolutions per minute
The giant wheels were great on the ramp, and the CIMs gave us some good pushing power.
Our robot was not symmetrical and the weight was balanced more over the skids, so we had some trouble getting weight issues settled. We eventually ended up placing over 20 pounds of dead steel weight over our drive train.
Next year we're going to deal with the symmetry issues, but this two-wheel drive was very successful, small, and modular, so I think we'll keep it.
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 13-04-2003, 11:59
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Team 201
6 years
2 CIMs
4 1.5 inch wide, 6 inch diameter custom machined aluminum wheels
No non- drive wheels
Chain drive from a 2-speed transmission
Skid steering
No sensors
Success- really fast, good amount of power, no reliability issues
Problems- can't turn in high gear
Next year- not my problem I'm a senior, though I hear my team is trying for swerve drive next year... we'll see...
Jeff Waegelin
Unread 13-04-2003, 12:59
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
-Team 639 - Code Red Robotics
-This was 3rd year.
-2x Chiapuas
-2x Modified Skyway from Kit for back
2x Omniwheel with 65 grade urethane
-No non-drive wheels
-Chains
-No Transmission, high torque 6.5fp
-Tank Drive, logarithmic control
-Optical Sensor for bin tracking
-Great success
watch www.orbitreview.com/~temp/639movies/639_d.wmv
-None (each regional we had nothing to fix/tune after practice day because we actually spent the time to do tings right this year. We just left the robot outside in Chesapeake for cooling
-.... very secret
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 13-04-2003, 13:57
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Team 6
9? maybe 10?
2 drills, 2 CIMs
4" brecoflex pulleys
0
Brecoflex belts (the green)
None
Sort of
None
A LOT of speed. We were one of the fastest at UCF.
We couldn't really turn until Sat. after we broke the belts in a little
Depends on the game
Unread 13-04-2003, 15:16
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Team #1018
First Year
2 drill motors
2 pneumatic tires from a hand cart
2 UHMW skids
#35 Chains
Sprokets from MSC with about a 2:1 ratio
Tank Drive
No Sensors
Nice mix of torque and speed
In Chicago we had problems with the chains walking of and in one case had a connector link fall off
I think we are going to try to make a gearbox this summer
Unread 13-04-2003, 16:10
Kevin A Kevin A is offline
In Hibernation
#0481 (DART)
Kevin A will become famous soon enough
Send a message via AIM to Kevin A
Team 481
4th year
2 Drill, 2CIM
4 Rubber skyway wheels 9" dia
0 non- drive
Gears for cim, provided gearbox for drills
0 sensors
Succesful...kinda - drill trans kept breaking, cim gear box sheared teeth and broke shaft, but no problems at nationals
Next year...shifter
Unread 13-04-2003, 21:59
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
Re: Drivetrain, what did you use?
Originally posted by maclaren
Team #?
Steering?
Sensors?
Success?
Problems?
Next year?
-Team 188, Woburn Robotics.
-6 years of participation.
-2x CIM, 2x Drill, and 2x Fisher-Price.
-Wooden wheels with tread, four-wheel drive.
-No non-drive wheels.
-Chains run to front and back wheels for four-wheel drive.
-One-speed only.
-Tank-style steering.
-Sensors on the wheels to count revolutions and/or pointing down to detects the line or the HDPE.
-A good balance between speed and power; in a fairly high gear (speed of about 9ft/s), we could still push well because of six-motor drive, with a low-friction simplistic gearbox
-It draws way too much power, and by the end of a heated match, our robot can barely move. So many drive motors sometimes cause us to trip breakers. We made the mistake of using small chain rated for about 1000 pounds (25), instead of something stronger, we went through 13 of them because they stretched and snapped all the time. Our treads kept delaminating from the pushing matches we got into, so a better means of traction needs to be developed.
-Next year, we're going more complex, possibly with a new gearbox design conceived on the plane back from Houston that can do speed and power without most of the drawbacks we faced, and that's all I'll say. We're looking at tank treads also. Anything else is just speculation, stuff I don't know, or stuff I don't want everybody to know.
Unread 13-04-2003, 22:08
Keith Chester's Avatar
Keith Chester Keith Chester is offline
HGFSP
FRC #0025 (Team 25)
Keith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to behold
Send a message via AIM to Keith Chester
Team 25
7 years participation (2 under my belt)
2 drills, 2 Chippys
3 wheels a side.
0 nondrive wheels
Direct drive (all gears baby!)
1 speed
Tank steering
No Sensors
Success- 13.6 fps, 3.2-3.6 autonomous time.
Problems- Drills! ARGH! Drove us crazy at first. Our programmer and pit crew came through in a miracle to fix that one.
Next year? Who knows.
A proud graduate of 25.
Students. Teammates. Brothers.
Proud member of R.I.N.O.S., Rookies In Need Of Support.
Unread 13-04-2003, 22:17
AlbertW's Avatar
AlbertW AlbertW is offline
harker robotics :. 1072
AKA: Aonic
#1072 (Harker Robotics)
AlbertW is on a distinguished road
Send a message via AIM to AlbertW
Team #?
Steering?
Sensors?
Success?
Problems?
Next year?
  • 1072 (go hrt!!! )
  • rookie team
  • 2x Drills
  • 4x skyway wheels with traction material epoxied on (back wheels were effective on the carpet/ramp, front wheels were effective on the HDPE)
  • no non-drive wheels
  • chain drive for both front and back, motors mounted vertically using helical gear set
  • bosch transmission and supplied helical gear sets
  • tank-steering. the bot would skid on the wheels not suited for the material it was on (if it was on the ramp/carpet, the front would skid, if it was on the hdpe, the back would skid)
  • 3 banner sensors mounted on bottom for line-following, though we didn't end up following the line
  • the drivetrain worked pretty well.
  • The traction material fell off the wheels alot, and we had some wiring issues with the motors. our transmission broke once, but it was easy to fix. our servo-powered gearshifters never made it onto the bot. there wasn't enough torque to move the little switch on the bosch transmission.
  • don't know about next year. We stayed away from more advanced systems like omniwheels and crab drives cause we were a rookie team, but we might just be more ambitious next year
We were the first seeded first-year team at a first-year FIRST regional.
Unread 13-04-2003, 22:18
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
Team 294
Seven Years
2 Drill motors
2 9 inch skyways
2 non drive wheels (locked casters)
First gearboxes
None (we stay in low gear)
2 wheel steering
None for drive
SoCal regional finalists (we lost one match)
We didn't lock the casters at first, causing problems going up the ramp and popping breakers at Phoenix
Next year we are planning something like 111s drive, that was our plan A (ended up with D)
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 14-04-2003, 16:54
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Team 212
5 of years of participation
2 drills
8 inch pneumatich wheelchair wheels
No non drive wheels
Chains
Gearing off of the FIRST gearbox
Tank style, we had a very short wheelbase so we turned really well and had the 4 wheels on the ground for the grip
No sensors
Never had any problems with the drive train, we made this thing like a car with hubs and all it was 1000% sucessful
Next year? i dont know depends on the game duh!
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 14-04-2003, 18:36
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Team 461 - Westside Boiler Invasion
4 Years
2 Drill Motors
4 Skyway wheels. Modified and lathed down an inch or so with supergrip rivited into a channel in the wheel for better traction.
None
Chain. 1.5:1 Gear ratio
None
Tank
Rotary Encoders on the front wheels
Speedy, Robust, Easier to fix and replace stuff then our previous attempts at a drive, we just decided to go simple and not mess with complicated stuff.
We didn't have alot of torque.
We are going to dive into the wonderful world of transmissions
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
drivetrain mouts and gears Andrew Dahl Technical Discussion 3 22-01-2003 13:21
My team is toying with drivetrain ideas .. . Frank(Aflak) Technical Discussion 12 10-01-2003 21:52
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
What motors power your drivetrain? Khalicl13 Motors 35 03-12-2002 16:33
Computer modeling of drivetrain and devices archiver 2000 1 23-06-2002 23:02
