Go to Post If your robot doesn't work, it doesn't matter, because the robot is really meaningless, in the long run. What is the important thing, the reason we're all in FIRST then? To better our understanding of Science and Technology, and hopefully make the world a better place. - Ian W. [more]
Unread 18-04-2003, 04:50
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
Regional & Division winners, did you shift gears or not?
We had a survey prior to the regionals on shifting gears or not. About 3/4 of the respondents felt that shifting was valuable. Now let's see what the winning robots actually did.
Of the winners in the regionals and the championship divisions, which robots shifted gears and which didn't?
If you did shift, what method did you use?
If you didn't shift, how did you overcome any possible handicap that caused?
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 18-04-2003, 10:22
Matthew W's Avatar
Matthew W Matthew W is offline
Wildstang Alumni
no team (Wildstang)
Matthew W is an unknown quantity at this point
Send a message via AIM to Matthew W
Wildstang does not shift gears. We have it set in software so that the Speed Controller isn't running the motor at full speed when driving unless you are pushing a button. We dubbed this a Turbo" Button. This shouldn't be confused with a true geared transmission because it's just done in software and does not change the gear ratio.
Unread 18-04-2003, 11:02
TravisCarpenter's Avatar
TravisCarpenter TravisCarpenter is offline
292 Human Player
#0292 (Panthertech)
Team Role: Human Player
TravisCarpenter is on a distinguished road
Send a message via AIM to TravisCarpenter
No shifting here either. I think the reason we were able to do so well was a mix of the power and traction our robot had, and the strategy we used in our matches. But most of all I would say we did so well due to our driver. Every match he did basically the same thing, and doing this allowed him to become really good at it.
Unread 18-04-2003, 11:13
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
384 didn't use a gear box that allowd for shifiting of the gears.
Unread 18-04-2003, 11:40
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
45
45 has shifted gears since 1999 and we continue to do it today. We've progressed from using the standard FIRST provided gearboxes for shifting to designing our own custom shift on the fly transmissions (used in 2002 and 2003).
2003:
http://www.chiefdelphi.com/pics/bin/...99dscf1904.jpg (expect a white paper this summer)
2002:
http://www.chiefdelphi.com/forums/pa...gle&paperid=78 (our first shift on fly design)
2001:
http://www.chiefdelphi.com/forums/pa...gle&paperid=21 (back to back motor design)
2000:
http://www.chiefdelphi.com/forums/pa...ngle&paperid=9 (149669 download(s) )
Purdue Alumni
Cummins, Inc.
Unread 18-04-2003, 11:43
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Well, we weren't a division winner, but we were division finalists. We used a custom 2-speed transmission on the CIM motors, just like we used last year.
Jeff Waegelin
Unread 18-04-2003, 11:51
Soukup's Avatar
Soukup Soukup is offline
Animation Guru
AKA: David Soukup
Soukup is on a distinguished road
Our robot was able to shift on the fly. If was really effective, expecially when teams that didn't scout robots, thought that we were only speed and no power. We had a high-speed gear and a low gear at a 3 to 1 ratio. Even though we didn't win, we had a eliminations appearance, a semi-finals twice, and we were a #1 seed in galileo.
soukupd_gv@hotmail.com
Team 74 Alumni
2003 Great Lakes, Midwest, and West Michigan Regional Animation Award Winner
Unread 18-04-2003, 12:27
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Post
We were the finalists at 2 regionals and the semi-finalists in our division at Nationals.
For the past few years we have mounted servos overhead of the drill motor's gearboxes.
It seems to work fine once you find all the bugs
Unread 18-04-2003, 13:37
AParadkar's Avatar
AParadkar AParadkar is offline
#0102 (The Gearheads)
AParadkar is an unknown quantity at this point
Send a message via AIM to AParadkar
We had shifting capabilities, but we found that we could push most robots simply by building momentum in high gear. By backing up and ramming, we were able to knock even suctioned robots off the ramp.
Ameya Paradkar
Team Leader
Driving Team Member
www.team102.com (PLAY PONG!)
X-WAVE --> To the X Power!!
2000 National Finalists
2003 J&J Regional Champions
Unread 18-04-2003, 14:12
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
I see many people here saying "We didn't win, but...."
The author specifically stated people that won a regional. The fact that you shifted and still didn't do well, complements the arguments of the people who are against shifting. You're digging yourself into a hole here.
If you look at all 3 national winners, none of them shifted. Obviously an optimized non-shifting robot is far superior to a shifting robot. Less that can go wrong.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 18-04-2003, 14:38
the doors's Avatar
the doors the doors is offline
#0234 (CyberBlue)
the doors is an unknown quantity at this point
Send a message via AIM to the doors
I disagree (somewhat). Just because the winners didn't shift doesn't mean that the best robots are those that don't shift. While the winning robots were all incredible machines, there is more to winning than simply your robot (for example skill and experience of driver).
Unread 18-04-2003, 16:40
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
We were winners along with 25 & 102 at rutgers & i don't believe any of us shifted. 25 used 4 motors for both speed & power. We along with 102 both went with good speed, good traction, & 1 gear. Sometimes, having less to think about can be better. The only times torque to speed change could have helped was getting to the stack, & getting to the top. The thing that really made a difference was a teams ability to do an auto-mode well, or even consistant. And knowing how long it would take to get on top.
Unread 18-04-2003, 16:42
Matt_Kaplan1902's Avatar
Matt_Kaplan1902 Matt_Kaplan1902 is offline
#DecadeofDelicious
FRC #1902 (Exploding Bacon)
Matt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond reputeMatt_Kaplan1902 has a reputation beyond repute
Send a message via AIM to Matt_Kaplan1902
shifting
When we won the Central Florida Regional, our robot couldn't run in our high gear (We also changed the transmission 11 times but thats a different story). For chiago and nationals we were able to shift on the fly.
Team 1902: 2007-??, Mentor
Team 108: 2002-2005, Student
Unread 18-04-2003, 16:52
Matt D's Avatar
Matt D Matt D is offline
college time!
FRC #0254 (Cheesy Poofs)
Matt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to all
254 shifts
This year team 254 shifted. We used servos to shift the drill transmissions. In low gear we went about 3ft/s and in high we went about 9ft/s. We made it up the hill during auton from 3.5-3.8 seconds. We won SVR (with 115 & 852) and were the finalists at Sacramento (with 599 &256). However, our partners did not shift at either event. At Nats, we paired up with 27 & 192. 192 shifts as well, but I believe 27 does not. We made it to the semifinals.
Last year (I know this is about this year) we used a shift-on-the-fly transmission with 1.5ft/s in low and 13ft/s in high that coupled the drills and the CIMs.
-Matt Durstenfeld
Unread 19-04-2003, 18:46
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
662 does not shift and we were part of the winning alliance at Sacramento. We are geared for about 9 fps. I think that we would have done better at the championships if we were geared lower or could shift.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Break Down of Awards By Fields. Josh Hambright Championship Event 13 09-04-2003 10:22
Regional Chairman's Winners starshrike Chairman's Award 23 07-04-2003 12:39
Even more interesting numbers: Division of regional winners archiver 2001 8 24-06-2002 03:10
NYC Colombia Regional Winners MChen Regional Competitions 0 23-03-2002 21:11
Braodcast and web coverage of regional competitions dlavery Regional Competitions 26 16-03-2002 17:21
