Go to Post "Maybe if I stare at it long enough our robot will actually work" - frcguy [more]
Unread 04-04-2003, 18:01
Joel J's Avatar
Joel J Joel J is offline
do you..
Originally posted by Solace
If you run into something hard enough - be it a wall or another robot - the main 120a breaker in your robot can trip from sheer impact.
We accidentally ran into the walls protecting both driver stations in autonomous mode a few times.. neither tripped the main 120 amp breaker. In one match we were tangled up in another team's robot, and it ended with the weight of our robot breaking their arm, and thus body slamming our robot onto the floor from about a foot off the ground... that tripped our breaker.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 04-04-2003, 18:03
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
i stand corrected
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 19-04-2003, 23:52
Jessica_166 Jessica_166 is offline
#0166 (Chop Shop)
Jessica_166 is an unknown quantity at this point
Send a message via AIM to Jessica_166
Re: Robot gone wild
Originally posted by Gui Cavalcanti
Alright, so we're competing in Philadelphia on Friday, and I notice as the driver that the robot can no longer turn the left wheel forward (we have two-wheel drive). The funny thing is, reverse works fine. Since we're in the middle of a qualification match, however, I don't think about it,but I do what I can and get to the top of the ramp in reverse.
Once I get there and let go of the sticks, the left drive starts to jerk. I wonder if the joystick calibration is off, and compensate by moving the stick forward, holding on till the last second. The buzzer sounds, and I unhook our controller. That's when it happens.
Suddenly, our machine is no longer on the top of the ramp. At first I thought it had merely slid off because I had not positioned it correctly, but the still-going video of the match showed that the robot was actually moving under it's own power . Remember, the competition controls were not only disabled, but physically disconnected from power.
Anyone else have a robot gone wild story?
We had a problem with static at our regional where when the power was turned off our robot light was still going. This might have happened to your robot since you think there was a problem with your controller
Jessica
"WRENCH!"
http://groups.yahoo.com/group/mhsfirst/
This is my team's site. Visit if you wish
Unread 19-04-2003, 23:56
#0166 (Chop Shop)
wild robot
While we were programming our autonomous programs, we had to do several testings to see what was going on.
Well I had forgotten to initialize the drive constants so that the robot was at a standstill when it got power. So when we turned it on to test the program, it started going fullspeed in reverse and ended up running a student over....
It also took us a while to figure out why this was happening. You can imagine the boggled people wondering why the program that worked a little while ago is suddenly doing unexplanable things!
-Jessica
"WRENCH!"
Unread 20-04-2003, 00:14
Clanat Clanat is offline
Custom Title
#0753 (High Desert Droids)
Clanat has a little shameless behaviour in the past
Before shipping our robot, we were testing our auto mode, and we only had half of a ramp:
The back side didn't have mesh on it, and our programmer held the button to enable autonomous too long... Our robot fell off the ramp and landed on its front. It's a good thing our robot was sturdier than the light was (which didn't actually hit anything but broke anyway from the sudden decelleration.)
Former Co-Captain
Winner NW Regional 2002 and 2003
Unread 20-04-2003, 00:55
JasonStern JasonStern is offline
FRC #1123 (AIM Robotics)
JasonStern is on a distinguished road
Red face Re: wild robot
Yah we did that during build time, too. turn on the robot, not expecting anything to happen (yet) and the robot goes flying backwards. a couple of our team members run after it and hold it until someone can hit the breaker. after we pick up the bot, we notice it burned two holes thorugh the carpet
one of our matches at nats, our partner was faster than us, I programed in a 3 second delay in or auton code, or so i thought..... autonomous starts and 3 out of the 4 robots on the field start moving, only the stationary bot isn't us, it's our partners. meanwhile, we go flying up the ramp and knock down one side of the boxes. somehow our code get reset, so we back all the way off the ramp, rotate, then go forward again, knocking down the other side of the boxes!
I guess our robot wasn't happy being told to sit and stay
Que será será
Unread 20-04-2003, 12:47
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
2. if you output 255 to any PWM in your code, then the serial out link looses sync, and the data will no longer be going to the right devices- PWM data may end up going to relay spikes, PWMs may use the wrong PWM outputs. You should always use the
drive= (2000+drive)min 2000 max 2254)-2000
line right before your serial out section, for all your PWM variables, if there is ANY chance the math your SW uses might end up with 255 in a PWM variable.
Could you elaborate on this? I have seen some "interesting" behavior when output a 255 in a serin. Is there something in the documentation that says not to do this? Is this a best guess as to why wierd behavior results (ie losing sync)?
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Index of team's post about their robot... Ken Leung Robot Showcase 1 20-03-2002 17:10
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
