My love for you never slides around.
Unread 24-01-2002, 18:48
Scorpion515's Avatar
Scorpion515 Scorpion515 is offline
#0040 (Trinity Pioneers)
Scorpion515 is an unknown quantity at this point
Send a message via AIM to Scorpion515
Question Goal Grabbers
Just out curiousity, if your team is aiming to grab goals...
- How are you planning to do it?
- What type of mechanism are you using?
- Is your team's robot going to enable the robot to grap one or two goals?
Scorpion
Unread 24-01-2002, 20:07
KennethToronto's Avatar
KennethToronto KennethToronto is offline
#0820 (Delta Tech)
KennethToronto is an unknown quantity at this point
Send a message via ICQ to KennethToronto
We're a rookie team
Our goal is to try to grab one goal..and move it
We'll be very happy if we can get it to move
Unread 24-01-2002, 22:47
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
We're grabbing two goals from the sides OR one goal from the back. We're not %100 sure about all of the mechanisms....
~Adam
Unread 25-01-2002, 01:48
Amadkow's Avatar
Amadkow Amadkow is offline
AKA: James Watts
None #0524 (Aplpha Omega)
Amadkow is an unknown quantity at this point
Send a message via ICQ to Amadkow Send a message via AIM to Amadkow Send a message via Yahoo to Amadkow
we are planing on grabing one goal and loading balls
Unread 25-01-2002, 10:24
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Top Secret But I'll Tell You This....
Goals are involved.
Unread 25-01-2002, 11:38
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
few general ways...
A few general ways you can grab the goals.
First, if you are doing one goal, you would probably grab the goal in front when your robot rush toward the goals. Or you can do it on your side, although you will need to compensate for that one goal dragging one side of your drive train.
Second, if you want to grab two goals, you can either do one on each side, or one front one back, or have a telescoping/very long arm extend past the first goal to grab a second goal.
Grabbing two goals probably need some sort of arms on your side extending out to reach for both goal at once to do it fast, or else you you will have to aim to grab the second goal from some other robot.
Grabbing three goals... you can either extend three long arms out toward all three goals, or you will have a really tough time trying to get a goal or two from opponents... If you are lucky enough to get all three goals, then you can hold them around your robot, and basically push forward with a strong drive train, because the opponents will forget everything else and try to stop you.
So that's some of the general position you want your robot grabbing the goals. As for the actual mechanism, you want to design something that will easily slide in between the poles, and lock on really fast. Design some sort of gate latch so that the physics of you mechanism likes to hold onto the pole(s). They can be grippers, hooks... etc. Just try to avoid having to use power to keep the goal(s) in your procession.
You also want to design that mechanism so your driver don't have to point your robot too accurately to get the pole(s)
You can just grab one pole per goal, or you can grab two pole for a solid connection between your robot and the goal, so when your robot is moving around, the goal will always stay the same relative to your robot.
Also, depends if you want more traction or not, you can lift up the goals slightly to add more weight onto your robot.
Unread 25-01-2002, 14:40
Stephanie Stephanie is offline
Stew da Baker
AKA: AKA: Steppie86
Stephanie has a spectacular aura aboutStephanie has a spectacular aura aboutStephanie has a spectacular aura about
Send a message via AIM to Stephanie
Two goals, one front, one back
Unread 25-01-2002, 17:11
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
Think about whaling.
We will harpon the whale. We are from MA. close to BEDFORD MA.
The whaling town.
grab the whale and hang on.
3 will be fun
you need to be flexable, if not things will break.
Unread 27-01-2002, 00:34
Elgin Clock's Avatar
FRC #0237 (Black Magic)
3 goals huh????
Ok I have to admit that I did have a great idea to grab 3 goals that would work (theoretically).
BUT, at our first meeting I came to the realization, assisted by a team mate, that grabbing three goals would be a very Stoooopid idea.
Sure it will score a ton of points if you can sucessfully pull it off but, In order to get a great amount of Qualifying Point's your enemy has to have points on the board. The most ideal situation would be a win by one point! You win by getting the most points in the match and you get the most QP's out of the match that you can.
My 2 cents!
Unread 27-01-2002, 02:30
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: 3 goals huh????
You'd be right IF life ended with the seeding round. The way I see it: If you can reliably grab and control goals, you may not make it into the finals on your own, but you'd make a fantastic alliance partner for someone.
(Understand, I'm not saying I was able to convince my team that this is the tack we should take -- it's just another option (should anyone still be designing their robots.)
Unread 27-01-2002, 04:19
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Do keep in mind that, just because you can control all of the goals, doesn't mean that you must score them all for your own alliance. A three goal controlling robot could score two in its own zone and one in the opponent's zone, or rotate depending on which goals held balls.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 27-01-2002, 09:10
Dr.Bot
Posts: n/a
This is an answer mostly for the rookies who are trying to move one goal. It takes about 30 lbs of pull or push to move a goal.
If you build a simple robot using the FP motors you will have trouble moving the goal from a standing start. i.e. if you plan to drive up to the goal, stop, clamp on, pull it back, stop, fill with balls, push back etc. The reason has to do with the torque vs speed curve of the FP motor drive system. If you make the the robot powerful enough to do this it will be so slow, it won't be able to finish in time. If you plan to grab a goal from the side, a two wheel design robot will be able to spin the goal in a circle but
not get to move in a straight line. - The reason we know this is we used a two motor prototype to test the hypothesis.
Instead of a standing start, you might figure out a way to get up a 'head of steam' and hit and push the goal. If say your robot weighs 130 and the goal 180 - you get the robot up to 5mph, slam into the goal and then push it at about 2mph into the scoring region. You then could back up and try for another goal.
As a rookie team - concentrate on how you can help your alliance.
You help your alliance by scoring points. You score points by being able to move, push, pull, possibly lift and drop balls. If you can score more than 10 points, you will help your alliance. If you
can only score ten or less, you won't be much help.
Now as to our tactics for this year ..... We are not ready to say,
other then it involves goal(s?), balls, robots, our allies and our opponents.
Unread 27-01-2002, 09:29
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
Re: 3 goals huh????
Grabbing and moving three goals would be very doable, as long as there were no robots out there trying to prevent your do so. If a robot has control of three goals, though, there are likely to be two robots of the opposing alliance working very hard to move the goals, and your robot, where they want them.
Team 1062, The Storm, 2003
Unread 27-01-2002, 10:57
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
But if two robots are trying to get the robot with all three goals stopped....what happens with the last robot....
FRee sailing for them
Unread 27-01-2002, 11:20
The last robot may well be helping the robot with the three goals try to move the goals to and/or hold them in the desired location. This is going to be an interesting game.
(edit to fix typo)
FIRST and Success: A Question of Definition Madison General Forum 70 27-11-2002 08:42
Small balls in 2001 competition archiver 2001 10 24-06-2002 03:59
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Hehehe... 3 goal grabbers... Gui Cavalcanti Championship Event 11 18-04-2002 18:02
3 goal grabbers faced off -- MOE vs Sparky ggoldman Regional Competitions 4 10-03-2002 19:35
