Go to Post FIRST is good for us. It is good for our own Children. Don't give up, even if you are as tired as I am! - Kyle Hughes [more]
Unread 29-04-2003, 15:20
Trashed20's Avatar
Trashed20 Trashed20 is offline
Boom, Shawalala Boom!
#0862 (PCEP Lighting)
Trashed20 will become famous soon enough
Send a message via AIM to Trashed20
running bot off car battery?
there are some parades that we are thinking about going to and we would like to bring the robot. The problem with this is that it would drain the battery something fierce. Would it be possible to run the bot off a car battery, would it damage anything, and any estimations on how long it would run? we would only be using 2 drill motors. thanks!
Where has all the fun gone?
Unread 29-04-2003, 15:42
Andy A. Andy A. is offline
Getting old
FRC #0095
As long as it's 12 volts (and nearly every car battery is), it won't hurt any of the electric components.
Since most car batteries are not sealed, you would have to be careful on how its mounted- it must be straight up and no chance of it getting tipped over. Battery acid sucks.
It's also likely to be heavier which might reduce your speed, just keep that in mind. Your motors are also likely to get nice a toasty if you run them long, you might invest in a can of coolant.
-Andy A.
Unread 29-04-2003, 16:47
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
we've run robots using one of those battery portable jumper kits- it worked fine.
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 29-04-2003, 17:57
FreeBSDboy FreeBSDboy is offline
FreeBSDboy is an unknown quantity at this point
Be warned though, typical car batteries are not designed for deep discharge cycles. If you drain the battery, chances are you will cause harm to your car battery.
Deep cycle (typically marine) batterys don't have this problem. They're more expensive though.
You might also consider hooking up your competition batteries in parallel to double your runtime.
Unread 29-04-2003, 18:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Those have a battery not unlike what we are given by FIRST. I wouldn't expect it to last any longer than what we have.
Unread 29-04-2003, 19:18
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Perhaps you should find someone with a truck to hold your team and a trailer to hold your robot like we do!!!
Most of the team sits on the truck and the drivers sit on the tailgate...
We have a few people on the trailer and they usually collect the scoring objects (balls or boxes this year) we demonstrate the robots abilities instead of just drivin the bot down the road!!!!!
The people on the trailer also change the batts if needed!
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 29-04-2003, 22:57
Trashed20's Avatar
The problem is that we were a stacker and that never worked so all we can do is drive..... hehe.
Unread 29-04-2003, 23:27
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
It will work
Car batteries will work fine, just be sure the battery remains in an upright position becaus most are not sealed cell batteries!
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 30-04-2003, 01:30
This is what I would use although it is quite pricey. It is the only one you would have to buy for a long time though.
Unread 30-04-2003, 08:59
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire (on sabbatical))
Parade in Canton?
Parades in Canton? I live in Canton and I don't know about any parades. You should let us know what parades you're talking about so I can show up.
-Chris
Unread 30-04-2003, 09:08
T967's Avatar
T967 T967 is offline
5 IA teams, WHOs w/me?
AKA: Seth F.
Team Role: Student
T967 is on a distinguished road
Send a message via AIM to T967
We did this for our homecoming parade: Get a big enough trailer where you can drive the robot around resonably well. Then you can drive the robot around on the trailer. Make sure there are side railings you don't want your bot to fall off a moving vehicle! We had like a 15ft. x 6 ft. trailer.
Old dude wondering if he can really get back into this crazy thing called FIRST.
Unread 30-04-2003, 13:03
jmort03's Avatar
jmort03 jmort03 is offline
jmort03 is an unknown quantity at this point
Send a message via AIM to jmort03
do what we did
we made carousal of six robotics that ran off of two cip motors and we (6 teams) walked behind the float. It also had a FIRST symbol that was suspended in the air which almost hit street lights..i cant find pic right now...but i will post it soon. It was awesome.
...OH...IO...aka Ohio State
Unread 30-04-2003, 15:36
K. Skontrianos's Avatar
K. Skontrianos K. Skontrianos is offline
FRC #0102 (Dexterous Gearheads)
K. Skontrianos is an unknown quantity at this point
We ran just fine in our memorial day parade last year with 3 batteries. I believe the entire length was around 2 miles or so.
www.team102.com
2000 National Finalists
2003 J&J Mid-Atlantic Regional Winners
2003 BattleCry Best Autonomous
Unread 01-05-2003, 20:16
A typical car battery should work just fine. Be advised that the safety issues with FIRST batteries are multiplied with a car battery. It is much heavier and higher available current than the robot battery. Be very careful not to short across the terminals. Insulate very well, all wiring from the battery to the robot. I would suggest removing the breakers for motors that won't be used so that they don't accidentally get turned on when people are close by. (i.e. just drive motors and light because the light is cool) Try to give the robot some rest throughout the parade, especially if it is a hot day and the sun is beating down on the robot. Motors and speed controllers that get hot during driving will smoke during constant use in heat and sun.
As an extra added precaution, you might want to add a high current fuse near the battery, in case the wiring should short in the robot before the 120 amp breaker trips. Always secure the battery so that is does not tip over. Add flags, that's always cool!
Unread 01-05-2003, 20:22
We drove 980's 2002 robot in a parade that was 2 miles long using only 2 batteries. It was cool driving a robot through the streets of Downtown Los Angeles. We were going pretty slow most of the way. The robot ran only on drill motors which didn't really get hot. We followed in a chase vehicle with the radio and OI powered off a battery.
worst experience mike pawlak Chit-Chat 15 06-12-2004 07:04
Batteries Dave Hurt General Forum 21 29-12-2003 17:55
running the OI off a battery AlbertW Electrical 25 29-04-2003 13:09
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
