Go to Post Now that football is over... ARE YOU READY FOR SOME ROBOTS?!?! - KelliV [more]
Unread 26-01-2002, 20:03
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Our wheels don't touch the ground!
Well, we put together our drive train today, and it appears that our wheels don't touch the ground. The worst part is that I am the one entirely responsible for the calculations on our drive train. The upshot is that we have almost zero rolling resistance, however our robot seems to travel quite slowly. Oh well, back to the drawing board...
Zan Hecht
Unread 26-01-2002, 20:12
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
thats not good at all. i would show our new drive train but i won't. i don't want to give away all our tricks of the trade, if we have any. all that will come later.
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 26-01-2002, 20:44
DaringCommander's Avatar
DaringCommander DaringCommander is offline
DaringCommander is an unknown quantity at this point
That has got to suck
That has got to suck.
Unread 26-01-2002, 21:08
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Easy Fix??
Cant u just change the height or position of what the wheel is mounted to??
Actually, how can they not touch the ground if u put the robot on the ground? Isnt that something that could be very noticable if u make any kind of simple picture/print?
Or, are u trying to fool us by saying that....but u probably dont have any wheels cuz u have a hover craft...and u are using pneumatic wheels on the side of your bot (they wouldnt touch the ground) as bumpers? similar to tug boats....lol
Purdue Alumni
Cummins, Inc.
Unread 26-01-2002, 23:07
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
wheels not touching ground
A lot of teams will see that when their base got welded together, or somehow bolted together, the resulting base become bent sometime during the process, making the wheels not touching the ground.
A quick way to fix it is to remove the wheels, put the base on the ground, and use a soft mallet and hammer it flat. We have been doing that for a couple of years, and the base always came out really well. Just make sure you are hammering with controlled hits.
The other way, or course, is the lift up the height of brackets or wheel mounts to make sure the wheels touch, but you probabmy want to hammer you base a little bit to get good straight surface on it to mount your components correctly. If the base isn't flat, then you will see that legs of components won't completely lay flat on the base, which means you will need ways to stack up washers or whatever you can find under those components for a solid connection.
Bottom line, try to get you base flat and in good shape before you start attaching components on it.
Unread 26-01-2002, 23:21
Jon Lawton Jon Lawton is offline
Bitter FIRST Cynic
Jon Lawton is an unknown quantity at this point
Send a message via ICQ to Jon Lawton Send a message via AIM to Jon Lawton
Re: wheels not touching ground
Yow! Isn't this a really big hassle? Why not go with extrusion? Or a flat sheet of Al, that has "Wheel Wells" machined in? Extrusion *IS* expensive... but MAN! I've fallen in love with it! 8) It is *well* worth the extra cash, if you can afford it. IMO.
Unread 27-01-2002, 00:16
EddieMcD EddieMcD is offline
EddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud of
And if all else fails, use duct tape to mount the wheels/motors where you need them. A semi-decent last resort.
Unread 27-01-2002, 00:18
A Legacy of Impact
duck tape is not a legal material eddie
2010 Championships
Unread 27-01-2002, 01:44
Jordan A.'s Avatar
Jordan A. Jordan A. is offline
#0781 (Kinetic Knights)
Jordan A. is an unknown quantity at this point
Send a message via ICQ to Jordan A.
Considering the amount of engineering and design hours going into our drivetrain I would quite literaly shoot myself in the head if that happened.
Try re orientating the gear box? perhaps on its end it might work? Cant offer much advice without knowing your design, and I dont expect you to tell...
Good luck man, us rookies share your pain.
Unread 27-01-2002, 02:38
mnkysp6353's Avatar
mnkysp6353 mnkysp6353 is offline
no team (Bagel Bytes)
mnkysp6353 is an unknown quantity at this point
Send a message via AIM to mnkysp6353
Hey zan dont worry about it man we all make mistakes. I am the captain of my team and Atleast your team members dont promise death if you make a mistake like my team does. Its your first year we all screw up and this stuff happens to teach us lessons. If you need any help im like a stones trow away in culver city. My team would be more then happy to help if they arent too busy killing me for making a mistake.
Im serious guy if you need any help dont hessitate to drop me a line.
Unread 29-01-2002, 00:47
ahecht's Avatar
'Luzer'
AKA: Zan
Well, I think I better explain. In my calculations, I think I got radius and diameter confused, and the wheels ended up about half an inch off the ground. We can't just lower them, because then their sprocket would hit the frame. However, we found a nifty little solution, but I still feel pretty stupid for not noticing that anything was amiss until the thing was assembled.
Zan Hecht
Unread 29-01-2002, 16:40
Colin Bohannan Colin Bohannan is offline
Colin Bohannan is an unknown quantity at this point
Send a message via AIM to Colin Bohannan
If you don't mind telling, what was the solution that you came up with?
Unread 29-01-2002, 19:35
Jessica358 Jessica358 is offline
#0358 (Titans)
Jessica358 is an unknown quantity at this point
Unhappy wheels don't touch
Measure twice, cut once!
Jessica
Boardz27@aol.com
5483-5433-86-843-3855378-367-843-388873-47-722733!
It does have a meaning people!
What do you use for wheels? Andrew Technical Discussion 36 08-01-2004 10:20
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 17-03-2002 22:09
Skyway wheels w/o bearings ahecht Technical Discussion 4 22-01-2002 01:25
