Go to Post I love it when someone tells me I can't do something. - dlavery [more]
Thread Tools Rating: Thread Rating: 5 votes, 4.40 average. Display Modes
Unread 25-01-2002, 22:36
PHIL358 PHIL358 is offline
#0358 (Titans)
PHIL358 is an unknown quantity at this point
Question Teams that build 2 robots
TEAMS THAT BUILD 2 ROBOTS WHERE DO YOU GET ALL THE EXTRA PARTS TO BUILD ONE
- TAKE OFF RELAYS,SPEED CONTRLERS,ETC. OF OLD BOTS?
- ORDER THEM FROM FIRST?
- OBTAIN THEM FROM OTHER TEAMS?
- GO TO THE FIRST ROBOT JUNKYARD?
IF YOUR TEAM DOES BUILD 2 ROBOTS CAN YOU SHARE HOW YOU GO ABOUT DOING IT!
THANKS.
Unread 25-01-2002, 22:51
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
There are teams that build multiple robots? Hmmm....how does that work?
I wish we had the money for something like that!
~Adam
Unread 25-01-2002, 23:07
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
Last year, the bobcats had two robots.... we built spare parts when we were building hte actual robot. I.E. if we were building hte motor mount, we machined 2 or 3 instead of just one. As for the electronics, we did quite a bit of stealing off of other machines, and we may have ordered a few more things from IFI.
our 80/20 (www.8020.net) frame also made this a lot easier, we were able to assemble our entire frame in a little under 2 hours.
Tom
Unread 25-01-2002, 23:11
Jon Lawton Jon Lawton is offline
Bitter FIRST Cynic
Jon Lawton is an unknown quantity at this point
Send a message via ICQ to Jon Lawton Send a message via AIM to Jon Lawton
Our team is planning to do this... using the IPS extrusion should make making a second frame a breeze. We will, of course, have to buy extra motors. We're not decided as of yet if we will rip electronics off of an old robot, or buy new parts. Since we are using most of the motors in the kit, I'd wager we will do both! I'll post back on CD if and when we get this to happen. 8)
RIGHT NOW we're still a number of hubless sprockets short of ONE robot!
Unread 26-01-2002, 08:25
gniticxe's Avatar
gniticxe gniticxe is offline
B.C.O.M. Forever!
AKA: Brian Gattman
no team (FRC2910 - Jack in the Bot / FRC365 - MOE)
gniticxe will become famous soon enough
We also make a second robot. I think it is a good idea because it allows the drivers to practice between the time we finish up until the competitions themselves. It also helps train the pit crew as the second invariably malfunctions more than the one shipped off the the competitions.
We do have to buy all the extra motors/everything else necessary, but it is well worth it if you are able to.
Unread 26-01-2002, 12:41
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Last year we built a second robot and we plan on doing it again this year. As a rookie team, last year, we had to buy everything that was on the primary robot. This included the robot controller, compressor and motors. To name a few. Gets expensive fast. We used 1" aluminum tubing for the frame. It took time to build but we realy saved alot of weight over 80/20.
This really helped us last year. We developed an auto balance using the back-up bot, tweaked the program and then downloaded it to the primary bot at a regional. It worked first time out.
This year we are building two of everything instead of building from scratch after the primary bot is done
Wayne Doenges
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 26-01-2002, 14:53
mnkysp6353's Avatar
mnkysp6353 mnkysp6353 is offline
no team (Bagel Bytes)
mnkysp6353 is an unknown quantity at this point
Send a message via AIM to mnkysp6353
Team 702 is also building a second bot for practice. We are just going to take parts off last years robot and buy other parts. This will be a huge help. Our sponsor has agreed to pay for our seconde robot so that helps out alot.
Unread 26-01-2002, 19:46
DaringCommander's Avatar
DaringCommander DaringCommander is offline
DaringCommander is an unknown quantity at this point
Cool Obvious Benefits
With people not able to keep their robots between events having another bot to try stuff out on would be a great help.
Unread 26-01-2002, 20:51
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
We don't have the time or the money to build a second robot. We would like to be able to, but it just isn't possible for our team.
Unread 26-01-2002, 21:18
Todd Derbyshire's Avatar
Todd Derbyshire Todd Derbyshire is offline
Alumni
Todd Derbyshire will become famous soon enoughTodd Derbyshire will become famous soon enough
Within three weeks TJ2 HAS BUILT 2 robots that are totally different. The only reason why people are able to build multiple robots is the amount of resources they have and manpower. If the money isn't there then a second robot is out of the question.
Unread 27-01-2002, 13:46
AdamT's Avatar
#0401
But that makes me begin to wonder....
Is that legal? And I suppose it is. Hmmm. It really shows how the advantage of money really makes it hard for other teams. Oh well.
~Adam
Unread 27-01-2002, 23:52
RoboGirll RoboGirll is offline
#0212 (R.A.C.E (Robotics And Creative Engineering))
RoboGirll is an unknown quantity at this point
Send a message via AIM to RoboGirll
teams that build 2 robots...
your team has too much money! GIVE TO US SO WE CAN ATTEND NANTS!!!
-RoBoGiRl
2003 Florida's Regional Champions
Unread 28-01-2002, 01:20
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
I am reminded of the first year that team 254, The Cheesy Poofs (Broadway High School in San Jose) entered the competition. It never occured to them to make anything other than two robots. They bought two kits, entered twice and built two machines.
That year their two robots came in first and second at the west coast regionals, and they both made it to the final 16 at nationals.
All this done by a team with about 12 students, one very energetic teacher, one insane engineer/mentor, and very little money.
I wish we were all that good!
-dave
- one of the ones your mother warned you about
Unread 28-01-2002, 06:51
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
-dave
Well, I'm not sure you mean "very little money", because their two entry fees alone are about our entire budget.
I guess it is all relative....and I have nothing against that. Heck, we want to be in that position in a year or so....all we have to do is build up a reputation of doing good work and getting benefits from what we are able to do. (build it, and they shall come..."George Washington's" that is)
We are thrilled with the budget and support we have this year. We are "in the game" and that is a first huge step.
-Quentin
Team 4987: Megarams
Unread 28-01-2002, 10:53
Paul Copioli Paul Copioli is online now
President, VEX Robotics, Inc.
2 Robots
Each year we ponder building 2 robots and each year, we back out. Not this year! We are building 2 robots. Driver skill is the difference whan it comes to the competitions. We have 5 weeks from our ship date to our first regional. Having a second robot will be a huge help.
How we do it:
(1) Each student must fundraise $1,000 in order to be part of the travel team. We are in a very industrial area and the students find a lot of Corporate sponsors.
(2) We design ALL our parts in CAD before we make one part (takes a lot of discipline). So it is easy to have multiple parts made.
(3) Find machine shops that will donate their machining. It has never been a problem for us. We just ask, show them our prints, and they are willing to help.
(4) We use everything from last year that we can (we had to buy the Chiaphuas)
One note about the Cheesy Poofs: They have never lost a Regional. Their drivers have been among the best each and every year. Now I know why (2 robots).
Long post - this year's game was tough - here's why: archiver 2001 7 24-06-2002 03:31
Hits, Misses, & Suggestions -- long message archiver 2000 17 23-06-2002 23:36
The Case For 'Regionalizing' teams at the Nationals. archiver 2000 33 23-06-2002 23:35
How do we view more teams? archiver 2000 0 23-06-2002 23:11
BattleBots IQ BSMFIRST Televised Robotics 37 15-10-2001 01:29
