Go to Post Don't fix mechanical problems with software, ever. - Chris is me [more]
Unread 11-06-2003, 13:22
Chris's Avatar
Chris Chris is offline
So apparently it hangs......
AKA: Chris Carnevale
FRC #0177
Chris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond repute
Confusion concerining Battlecry
Hey I just had one point of curiosity to bring up, the Battlecry website says that its limited to 36 teams and the finals are set up for 36 teams, However under warriors participating it list 38 teams, Is there an alternate system or am I just missing something?
Chris
Proudly Survived First year of College FIRST: 229
Unread 11-06-2003, 13:27
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: Confusion concerining Battlecry
Note: Just Barely...
Unread 11-06-2003, 17:52
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
3 Days until BattleCry.
Unread 11-06-2003, 19:22
WernerNYK WernerNYK is offline
AKA: Chris Werner
FRC #0190 (Gompei & the HERD)
WernerNYK is a jewel in the roughWernerNYK is a jewel in the roughWernerNYK is a jewel in the rough
Send a message via AIM to WernerNYK
Just spoke to a BC4 staff member. The website simply hasn't been updated. There will be only 36 teams competing.
And by the way, anyone seen the SITREP #4? Pretty interesting... outlines a new way of scoring, as well as outlining specifics regarding "tipping" of robots...
http://www.wpi.edu/News/Events/BattleCry/tactical.html
-Chris Werner
"Production Manager"
BattleCry@WPI
Team 190 - WPI & Mass Academy
Est. 1992!
Team 871 - Former team leader
Unread 11-06-2003, 22:37
Andy Grady Andy Grady is offline
I'm done being quiet!
FRC #0131
Rookie Year: 1995
Andy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond repute
Send a message via AIM to Andy Grady
Tipping
From The Rules...
Tipping Rule Clarification: In general, a tipping DQ will result when the 'tipper' initiates a lifting action that results in tipping; if the 'tippee' initiates the action, there is no fault.
Examples:
1. If a "wedge-bot" engages a stationary robot such that the stationary robot climbs the "wedge" and then, through action on the part of either robot, ends up tipping over, a tipping offense is appropriate.
2. If a robot engages a stationary "wedge-bot" such that it climbs the "wedge", and then, through action on the part of either robot, ends up tipping over, there is no offense.
3. In all cases, and especially when both 'tipper' and 'tippee' are in motion, final decisions as to DQ's, warnings, or no-fault calls are up to the Head Ref. His decision will be uninfluenced by a tipped robot's ability to re-right itself.
Very clear and concise guidelines, which is good, one problem though...there is no mention of two robots ramming each other and one riding up a wedge. This happens quite often, especially on the ramp, in both normal and autonomous modes. Might be a good idea to clarify this rule just a little bit further. Otherwise, I think the current guidelines are fair. Good job.
Unread 12-06-2003, 00:17
ColleenShaver's Avatar
ColleenShaver ColleenShaver is offline
Asst Dir, WPI Robotics Resource Ctr
FRC #0190 (Gompei and the HERD)
ColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of light
Send a message via AIM to ColleenShaver
My impression of the situation that you describe is that neither robot would be at fault, and therefore no tipping penalty would be called. Essentially, if two robots are engaged in an aggressive pushing battle or something, you accept the consequences of being involved, which I think is fine.
However these rules clarify that if your robot is stationary (or I would also assume moving away from the wedgebot) and they are approached and engaged by the wedgebot at all, any tipping that occurs of the engaged robot would be the fault of the wedgebot (even if it is continued driving/manuvering by the engaged bot that essentially causes the tipping, it was the wedgebot who first approached and put them in this situation). I think that is a very good interpretation of the tipping rule and I trust the Battlecry refs to make good and fair calls based on it.
I am also very happy to see mention of robots who can right themselves. Those tips are often overlooked simply because robots can do that. But we get tipped too!
Anyway, I'm happy to see the clarification before the competition and hope any interpretation issues can be cleared up nefore Saturday!
Can't wait!
Colleen Shaver (Traitor) - Assistant Director, WPI Robotics Resource Center
FRC190 WPI/Mass Academy (2001-Present) :: FRC246 BU/O'Bryant School (2000) :: FRC126 Nypro/Clinton High (1996-1999)
Unread 12-06-2003, 00:23
JVN JVN is offline
@JohnVNeun
What if a "wedge bot" is defending a stack, and another robot tries to get around them to knock if down. The wedge bot then maneuvers itself between the other bot, and the stack.
Technically, the wedgebot is moving and "engaging" the other robot, but in actuality it is simply repositioning itself for blocking/defense.
What is the call?
Unread 12-06-2003, 08:23
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
I say let it be. The other driver knows that it's a wedge bot...
That rug really tied the room together...
Unread 12-06-2003, 10:36
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Another thing that these rules don't address is if a robot uses a box to flip another bot (extremely common and most of the time unintentional).
And it also doesn't state what happened when a robot is on the ramp and is flipped. Many robots, especially tall robots, were flipped by teams that didn't even have a wedge. For example, team 42 was really defensive with the 157 in the semi-finals at Mayhem on the Merrimack, and tipped them over about 4 times in that match.
And what if a robot accidentally tips another robot, and the tipper de-flip it up so it can move again? Will the judge consider that too?
Unread 12-06-2003, 18:09
AKA: Chris Werner
You're asking all the right questions (to an extent I suppose), but all in the wrong place
The people to ask are the refs at BattleCry And either way the clarification lists examples, not all the specifics and also mentions that any ruling is indeed the refs decision.
-Chris Werner
BattleCry@WPI
Est. 1992!
Unread 12-06-2003, 18:51
JVN JVN is offline
@JohnVNeun
Who will be the head-ref?
Gary Fields?
-John
Unread 12-06-2003, 22:34
To offer my interpretation of what would be the answer to Kyle's last question... if a robot is tipped over, the team righting it wouldn't matter. Just as they say the tipping rule applies even when a robot can right itself, I would guess that it implies in any situation even if the robot ends up righted.
You have to look that in most situations, the two robots involved in a tipping occurance are both actively pursuing each other. I believe the intent of the rule is to prevent/discourage deliberate actions to tip a stationary or retreating robot over. Many of the tips in off season competitions occur when both robots are in motion at one another, and often top heavy robots end up on the lower half of that meeting.
But there were at least a couple incidents I saw at off-seasons were a stationary robot was wedged under and tipped or a robot driving the other way was chased, caught, and eventually tipped. These clarifications, as I interpret them, are to prevent these occurances and what could be considered malicious or 'brutal' tipping.
And just as other years, there will be a very qualified group of refs with FIRST experience. I'm sure we can count on very consistent calling of all rules and a fair event for all.
Looking forward to it.
Battlecry AParadkar General Forum 1 14-04-2003 21:38
BattleCry 2: the neverending sequel archiver 2001 11 24-06-2002 03:16
Who's coming when to Battlecry? ColleenShaver Off-Season Events 0 13-06-2002 12:19
BattleCry Update nick-190 Off-Season Events 7 17-05-2002 17:58
Battlecry 2(k1) Jon Abad Rumor Mill 3 06-06-2001 20:28
