Go to Post Imagine a time before alliances. A time when secrecy was rampid and the Delphi Forum was just in it's baby stage. - Andy Grady [more]
Unread 29-06-2003, 11:37
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
A New Concept for the Tournament Structure in 2004
One of the problems that has occured with the 2v2, random pairings in Qualifying Matches is that some teams get tough pairings and other teams get advantageous pairings. This affects the overall tournement outcome, even for teams that are not directly affected by these particular pairings.
In other words, if you get paired with tough pairings and advantageous pairings equally, but someone else gets only advantageous pairings, you have to perform at a higher level in order to maintain the same ranking.
What if the tournament structure continued as is (2v2, 4 random teams selected for each match, what teams are in a match are announced in advance) however the alliance pairings were determined at match time based on current rankings.
The highest seed is allied with the lowest seed (call this the blue alliance) and the middle seeds are paired with each other (call this the red alliance).
This concept would guarantee that the eight best teams floated to the top.
Unread 29-06-2003, 13:18
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
thats a really good idea. It would keep things a lot more equal and fair. I like it.
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 29-06-2003, 14:22
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
FRC #0871 (WI RoboTechs)
MrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the rough
I agree.. did you get a chance to present this to FIRST at the discussion forums a couple weeks ago?
did they give any feedback?
~ Mr. Buonomo, Team 871
Unread 29-06-2003, 14:35
D.J. Fluck
Posts: n/a
In 2000 I believe (yes I was around) FIRST used to do something similar to that. It gave you the match list with 4 teams in a match, but you didnt know who your partner was until you got to staging. Once all 4 teams were there (or as many that showed up) they told who was partnered with who, based on an automated selection. Even that would also work. In 2001, you really couldn't use that system. In 2002 and 2003 they flat out told you your partner before hand.
Unread 29-06-2003, 15:17
We almost sent someone to the Forum this year. But, we were all recovering from the season.
Unread 29-06-2003, 17:30
Also, like DJ said, with Andrew's method you wont know your partner until match time. This makes things more interesting, and in my opinion, more exciting. How you know your partner for evey match at the start of the competition makes coming up with strategies way to easy. With the older method, it required teams to come up with quick strategies in less than 2 min. It required more skill at being able to think quickly.
Ryan
Unread 29-06-2003, 19:22
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
This pairing sounds interesting... I'd like to see it make a comeback for next season's competitions. Matches would be very unpredictible... can anyone say.. scouting nightmare?
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 29-06-2003, 19:29
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
I like the idea very much. It'd be pratical and would spread out the competition a lot better.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 29-06-2003, 19:39
pauluffel's Avatar
pauluffel pauluffel is offline
AKA: Paul Luffel
FRC #1127 (Lotus Robotics)
pauluffel is a jewel in the roughpauluffel is a jewel in the roughpauluffel is a jewel in the rough
Send a message via AIM to pauluffel
I agree that it sounds fun and I would like to see this come into play in the future. It probably wouldn"t be that difficult to scout because if there was a simple rule that would always be used to determine what the pairings would be out of the 3 you could be paired with, you could guess fairly easily which team you would be with. This vagueness would also make it much more fun for scouts as well, because they would have to think up 3 strategies for each match. If you think about it, the 6 week build is a nightmare too, but that"s what makes it fun
I love challenges, eh?
Unread 29-06-2003, 20:34
apk apk is offline
Hi Everyone, I'm Back.
AKA: Andrew K.
#0104 (Team Universal)
apk will become famous soon enough
Send a message via ICQ to apk Send a message via AIM to apk Send a message via MSN to apk Send a message via Yahoo to apk
If this were the case, we (fsn) are going to be put to the test.
~Andrew
http://www.team104.com/
Unread 29-06-2003, 21:15
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Thumbs up
Sounds like a good idea to me. The rankings would have to be locked maybe 3 matches beforehand in order to give the teams a chance to get to the proper side of the staging area and collaborate with ally, etc.
At nationals in 2002, we were ranked #1 for our division for most of qualifications. This was in part because we had one great ally after another, all who could score enormous amounts of balls quickly. With this new system, we wouldn't have had the good allies time after time, while other teams were never fortunate enough to get any good ally.
Well, g2g
Patrick, NY
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
Unread 29-06-2003, 21:18
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
What if the highest seed in the 4 teams keep getting paired with the lowest seeded teams with non-functional robot?
Then most of their matches they will be stuck to fight against 2 functional robots.
That's what happened to my team at 2000, and every match we were paired with really bad partners a lot of times.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 29-06-2003, 21:24
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
That becomes a problem at smaller regionals. I know from the SBPLI regional, of about 35 teams....there are sometimes up to 10 robots that don't really work. So thats how a lot of really good robots end up seedling low, because of bad partners and facing 2 working robots.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 29-06-2003, 21:26
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Oh yeah, not to be blunt, but I hate the idea.
Yeah, I might be a trouble maker, but look at it this way: FIRST isn't about making everything even for everyone since it would remove the fun and competitiveness of it (as Dean said.) This 'new' system would take away the real life aspects of the game such as that you won't be able to win every time and there won't be a god like figure that would automatically pair you with alliance partner that is the same using formulas. FIRST is about replicating situations that you might face in real life, if your an engineer or not.
I vote no...
Why am I always the one who disagrees?
Unread 29-06-2003, 21:34
Mike o.'s Avatar
Mike o. Mike o. is offline
AKA: Mike O'Brien
FRC #1086 (Blue Cheese)
Mike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud of
Send a message via AIM to Mike o. Send a message via Yahoo to Mike o.
I must agree and disagree with the situation
I agree in the sense that it seems fair and all and that its a little logical in the sense of the phrase "crunchtime thinking"
I disagree in the respect that it takes away the funn of being able to plan ahead and just process your battle plan(strategy).
truthfully i am very mixed up, i would althogh probably like to see stay the same
Mike
Mike O'Brien
Founder, Almuni, & Mentor Team 1086
2010 GAL Division Finalist & Coopertition Award; NC Regional Winner & Quality Award; VA Regional Winner & Engineering Inspiration Award Winner
2009 CMP Team Spirit Award; VA Regional Winner & Chairman's Award
2008 VA Regional Winner & Chairman's Award
2007 & 2006 VA Delphi "Driving Tomorrow's Technology" Award
2005 VA Team Spirit Award; 2004 VA Imagery Award; 2003 Rookie Year
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
