Go to Post Oh yes - and thanks for giving us kids our dreams. - DonRotolo [more]
Unread 13-08-2003, 13:04
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #0930
Team Role: Parent
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
Signal specs for FIRST contorllers
I'm looking for signal specifications for FIRST controllers. Here is what I am looking for:
1. pinout for Spike BLUE relay control (blk, red, wht) and how to drive them from a BS2 for a hobby project.
2. PWM specs for Victor 883 and/or 884. What are the default PWM widths for neutral (1.5ms?) full forward (2.0 ms?) and full reverse (1.0 ms?).
Many thanks and enjoy what's left of your summer!
Tim Skloss
Unread 13-08-2003, 14:03
Matt Reiland's Avatar
'The' drive behind the drive
On PWM Outputs
Red = +5V
Black = Gnd
White = Signal
The signal is compatible with that of a hobby servo so I would venture to guess a 1ms puls min to a 2ms pulse max with a 40ms delay between pulses. Hope that helps!
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 13-08-2003, 14:20
Tim Skloss's Avatar
Dr. Skloss
FRC #0930
Team Role: Parent
Unhappy
Actually, I know that already. What I'm looking for is the specific timing (down to microseconds) for the default Victor 883/884 control signal at full fwd/rev, neutral and deadband.
And what the control signals to the Spike BLUE look like. (CMOS, TTL, serial?)
I could measure it myself if I get time in the lab, but I wanted to see if anyone knew off hand.
And it would be good to record this in the delphi database for future reference.
Tim
Unread 13-08-2003, 16:23
Umm Errr...
Please see thread:
http://www.chiefdelphi.com/forums/sh...threadid=21568
1139 Alumni
Unread 13-08-2003, 16:39
Tim Skloss's Avatar
Dr. Skloss
FRC #0930
Team Role: Parent
Smile Half the solution!
Great. According to the (rather long) thread above, Innovation First has said that the Victor expects a pulse width between 1.0 and 2.0 ms for full fwd-rev control (1.5 ms pulse width is center). I had assumed this but wanted to hear it from someone else. The 17ms delay between pulses is approximate. The industry standard is 20 ms period for the square wave (20 ms period minus a 2ms positive pulse = 18 ms delay). In my experience the delay can vary from 15 to 25 ms. Some servos (or speed controllers) can tolerate more or less so stay as close to 20 ms as possible. For BS2 a delay 18 should be OK. If you get jitter in the control or nonlinearity, try delay values between 17 and 20.
Now, does anyone know how to wire a Spike BLUE to a BS2?
Tim
FIRST Mentor and Team Leader
C.O.R.E 2062 a NASA, GE Volunteers and Rockwell Automation FRC Team
Unread 23-08-2003, 09:29
Spikes have a ground (Black) and two "signal" leads, going to two optoisolators. one for either relay circuit in the Spike. +5 V to ground should turn 'em on.
Unread 31-08-2003, 18:30
Tim Skloss's Avatar
Dr. Skloss
FRC #0930
Team Role: Parent
Thread is dead
Mission Accomplished!
Many thanks to those who helped answer my questions.
-Tim
Q&A Discuss: Are specs available on the new motors/mounts? CD47-Bot Extra Discussion 3 15-01-2003 19:39
motor specs? Gary Dillard Motors 0 04-01-2003 17:54
Loss of signal in PWM cables. archiver 2001 6 23-06-2002 23:29
Motor specs kmcclary Off-Season Events 4 26-10-2001 22:41
