Go to Post I think I wanna buy a Segway just to throw myself in the air to see what would happen... - Elgin Clock [more]
Unread 04-02-2002, 02:03
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
drilling that chiaphua gear
We are planning to mount the chiaphua gear to a .25" shaft using a 1/16" roll pin, but we can't seem to drill through it. We got a cobalt bit, a good drill press, and plenty of drill oil, but that darn gear is so hard that 30 minutes of straight drilling at the highest pressure possible before the bit bends got us down about a millimeter. At this rate, each gear will take us 5 hours to drill. Does anyone have any suggestions on how to cut this thing?
Zan Hecht
Unread 04-02-2002, 02:14
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
I've heard a lot of talks about how hard it is to drill that gear...
I think your best bet is to buy a gear that will mate with it, and attach that gear to a shaft instead.
Unread 04-02-2002, 02:24
mnkysp6353's Avatar
mnkysp6353 mnkysp6353 is offline
no team (Bagel Bytes)
mnkysp6353 is an unknown quantity at this point
Send a message via AIM to mnkysp6353
Zan it worked for us i was standing there when we drilled those suckers. It only took like 20 seconds, but i dont know what type of drill bit we were using. If you need us to drill it for you give me a hollar. I will ask our machinist what drill he was using.
Unread 04-02-2002, 10:05
REVving up for a new season
FRC #2848 (All-sparks)
please find out
so we were trying to do it forever also if you could find out what tyoe of bit he used that would be great thanks
Unread 04-02-2002, 13:22
JoeJ JoeJ is offline
#0698 (Microbots)
JoeJ is an unknown quantity at this point
Drilling Gear
Our machinist only broke one bit. He used a cobalt bit. First he ground off the teeth to provide a good drilling surface. The robot is now driving around with both motors. Our gears are pinned to a 1/4" shaft with stainless steel spring pins.
Unread 05-02-2002, 00:22
ahecht's Avatar
'Luzer'
AKA: Zan
Our cobalt bit just kept spinning in place, so we went with a carbide bit. This went through the gear like butter, and we managed to finally drill through both gears, but we broke three of the $8 bits in the process. Those things are quite hard, but that means they also are quite brittle. The trick, we found, is to drill in short pulses, as constant pressure on the drill can actually harden the metal directly under the bit.
Oh, and thanks mnkysp for the offer. I am always impressed with the level on generosity that the other FIRST teams have shown us.
Zan Hecht
Unread 05-02-2002, 03:01
mnkysp6353's Avatar
Zan my team is always here for you guys. If you need any help call (310) 842-4200 ext 6059 ask for me Justin Rolnick or Ms. Swanson. If im not there She can help you.
Unread 06-02-2002, 00:22
jeffreym jeffreym is offline
#0802 (The Lost Bearings)
jeffreym is on a distinguished road
We also had a lot of trouble drilling that gear. We finally found a machine shop that volunteered to EDM (electric discharge machining) to machine an 1/8" hole. You may be able to find a local shop to do this for you.
Jeff
Unread 06-02-2002, 01:23
mnkysp6353's Avatar
We drilled the gear on a mill with a titanium bit and it never broke. You just have to put alot of force on it.
chiaphua gear cluster Antonio Motors 31 26-01-2003 20:04
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Chiaphua Motor Pinion Gear Joe P Inventor 0 27-02-2002 15:48
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
