Go to Post You have the rest of your life to play video games. Time at an FRC tournament is precious. Use it wisely. - gblake [more]
Unread 16-09-2003, 18:15
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
White Paper Discuss: FIRST Editor (v1.1)
Thread created automatically to discuss a document in the White Papers.
FIRST Editor (v1.1) by Raven_Writer
Unread 16-09-2003, 18:16
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Please tell me if you find anything wrong this program. I've tried hard to fix the problems that came up during the past stages of developement.
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 16-09-2003, 19:52
Umm Errr...
Great job! No problems i can see.
1139 Alumni
Unread 16-09-2003, 19:53
AKA: Eric Hansen
Thank you!
I'd like to say that I haven't tested it out yet. I'm planning on doing that tomorrow at our meeting.
If I had a laptop, I'd test it out on the EduRobot RC/OI...but I'm to screwed for that (heh).
Y!: synsoflife
Unread 16-09-2003, 19:58
Umm Errr...
i didn't try the code downloading part, but i can if u want. I have a BS2p40. If it works on that it will work on the RC.
1139 Alumni
Unread 16-09-2003, 20:02
AKA: Eric Hansen
Please do.
I'm not totally sure. It's all based upon what the editor Parallax gives us can do. I know it can download to all the stamps Parallax has available, so if a BS2p40 is a stamp that they give out, it SHOULD work.
Could you please still try though, so that I can know how/what it does?
If you do, please tell me what all happens.
(If it works, there should be no errors that pop-up).
<<EDIT>>: The downloading code is from RoboGUI, so that should make it more of a choice. << /EDIT>>
Y!: synsoflife
Unread 17-09-2003, 17:50
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Ummm... the code from RoboGUI will only talk to a 2sx--mainly out of laziness on my part.
Anyways, I assume you already know that using the /FORCE option is definately a bad thing as it merely covers up problems instead of fixing them. Also, it seems that debug exes won't run, which is probably a sign of bad things happening internally that you may not even know about. It also makes debugging next to impossible.
Other than that, nice work. Any thoughts on future features?
Unread 17-09-2003, 19:07
AKA: Eric Hansen
Ah.....well then, that really doesn't harm team 5 (I hope it doesn't harm others either though). We've always used BS2SX anyways (AFAIK).
I'm only using the /FORCE option because I have no idea on how to fix the "[function] was already defined in [*.obj file]". I've searched MSDN before using /FORCE, but found nothing.
The debug exe's I knew wouldn't run, so I switched to release mode. It deals with something on the docsingle.cpp file or something (it's a MFC-specific file from what I've found so far).
If you are referring to the MSVC++ debugger, I know :'(
Thanks. Please give me anything (else) you have.
BTW: Incase anyone cares, here's a lil' convo. that happened between me and an engineer:
E: What is the purpose of this?
R: It's just for people who don't want to use the Parallax Inc. one.
Well, that didn't happen like that, but that was the main points of it [E = Engineer, R = Me (Raven)].
Y!: synsoflife
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
White Paper Discuss: Team 159 3.0 CD47-Bot Extra Discussion 2 24-06-2003 17:18
White Paper Discuss: Woodie Flowers entry for Andy Baker (2003) CD47-Bot Extra Discussion 2 18-05-2003 08:06
White Paper Discuss: HeatWave 2003 Handheld DB (Beta Version) CD47-Bot Extra Discussion 4 07-03-2003 20:22
White Paper Discuss: Pocket PC 2002 Scoring Program CD47-Bot Extra Discussion 3 16-01-2003 09:45
