Go to Post If you're doing it to win, you're doing it wrong. Teams who truly understand why they are doing what they do will win Chairman's simply as a result, an added benefit. The award isn't the goal. It's the impact you create, and the results you see. - dcarr [more]
Unread 08-10-2003, 21:41
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: LEGO Vernier Gearbox
Unread 08-10-2003, 21:44
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
All rite! 3 speed, Nice Job Man
i Hope im the Inspiration to this
Ive built 3-speed before but I had problems with getting the Rcx to stop on the gears, mabie i should try again with my new rotation sensor
Unread 08-10-2003, 22:40
Kevin A Kevin A is offline
In Hibernation
#0481 (DART)
Kevin A will become famous soon enough
Send a message via AIM to Kevin A
Why do you need a shifter for lego league? You don't need to push and load or any other robot, so high gear will work fine. It is not worth the motor or whatever actuator you are using to shift, as you could use it for an arm or something.
What is shift-on-the-fly about it? The fact that the gears will mesh because they are plastic? It actually wouldn't shift unless the robot is moving.
If you are just building this for the heck of building building it, then thats awsome, and you should ignore this rant.
Unread 09-10-2003, 00:04
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Kevin: Nobody ever said it was for Lego League.
Lego's are a kids toy with so much potential for adults to use. There are designs that can be made and used with Lego's that can't be used well in real life, or real life things that can be converted into Lego things. Such as this picture. None of us (I assume) have seen this design, done with lego's until now. That's what makes it so cool.
Something new and interesting, being made from a toy.
Unread 09-10-2003, 01:16
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
You speak lies!!
Lies I say!
Wetzel
Unread 09-10-2003, 08:03
golf_cart_john's Avatar
golf_cart_john golf_cart_john is offline
AKA: John W
FRC #0095 (Grasshoppers)
golf_cart_john is a jewel in the roughgolf_cart_john is a jewel in the roughgolf_cart_john is a jewel in the rough
It's not for the LEGO competition; I just built it out of LEGO cause it's a lot easier than using real metal and stuff.
Unread 09-10-2003, 09:28
AKA: Ty
Theres always Somone who Just LOVES to stomp on wikid cool ideas and things, I bet you never/Can't Drive a stick can you? The mission mars Is I think a very usefull place for a Shiftable Gearbox, i maen getting to the tasks quickly and then Shifting down to get the toutque you need to complete your tasks and then shifting up again to get back to the base to get started on another task is And will be a distinct advantage
Unread 09-10-2003, 09:51
SarahB's Avatar
SarahB SarahB is offline
SarahB has a spectacular aura aboutSarahB has a spectacular aura aboutSarahB has a spectacular aura about
Send a message via AIM to SarahB
You don't really need a huge amount of torque for most of the tasks. The only one I can think of that requires much at all is going over the crater, and that is just as much an issue of drive base design and wheels as it is torque. You can very easily find a nice gear ratio that allows you enough speed and torque without wasting a motor shifting gears.
Unread 10-10-2003, 00:25
In Hibernation
#0481 (DART)
Like I said, if you are just building it for the heck of it, then that is awsome!
I don't want to start anything here, its just that Im doing Lego League twice a week, and thats where my mind is at with legos.
That is truly an awsome design. I have made something very similar to that myself.
Now I will challenge you: Using two gearboxes very similar to that, make a swerve/crab drive 3 speed lego robot. I had one mechanically made, but not programmed.
edit: I have known how to drive a stick since I was 14. I have done alot of work with cars, legos and anything mechanical. Just because I don't put up pictures of everything I do, doesn't mean I didn't do it. I am sorry to "shoot down" any ideas.
Unread 10-10-2003, 09:43
AKA: Ty
I just orderd the turntables Its going to be a reality soon
pic: Gerrish Gearbox MK-III #2 CD47-Bot Extra Discussion 26 12-09-2003 11:35
pic: Gerrish Gearbox MK-III CD47-Bot Extra Discussion 22 04-09-2003 16:32
pic: 3-speed lego geerbox CD47-Bot Extra Discussion 4 14-07-2003 23:42
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
pic: Gerrish Gearbox MKII CD47-Bot Extra Discussion 63 03-07-2003 00:06
