Go to Post My mom's cousin heard from her friend who heard from her brother who heard from his barber who heard from his son that his teacher told him that his father's brother's sister's former roommate heard from Frank himself. - notmattlythgoe [more]
Unread 09-02-2002, 23:56
Larry Barello Larry Barello is offline
http://www.barello.net
#0492 (Titan Robotics Club)
Larry Barello has a spectacular aura aboutLarry Barello has a spectacular aura about
How much code can an IFI controller handle?
I imagine this has been answered somewhere else before: But, roughly speaking, how much code can the IFI robot controller handle before missing packets?
I have heard things like 10,000 lines of basic/second which would imply ~250 lines of code.
Is there a simple way to determine when you start missing packets? Compare packet #?
Larry
#492 Titan Robotics
Unread 10-02-2002, 00:47
Dr J pointed out last year that you could, in fact, store 8 programs in the BS2sx, and have one program call the next into action, sharing between programs variables stored in a special way. Just in case you should worry about running out of space.
The whole topic is probably archived here, or you could check out parallaxinc.com for details.
Unread 10-02-2002, 00:51
The issue isn't code space, but timing: how much code can I execute between packets. I want to do some real time programming (velocity control, servo stuff) which adds up.
Unread 10-02-2002, 01:00
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
You can get the delta_t from the master processor just like you would a joystick axis. Delta_t tells you how many packets you missed (your code was still working with a packet when a new packet came in).
Unread 10-02-2002, 09:58
Thanks. Looking at Delta_t I see that I am currently missing 1/8 packets. If I leave a subroutine out that implements a slow PWM (to get around the Victor deadband) I miss 1/16 packets. So I must be on the edge...
Now, to learn how to optimise code - pbasic style.
Any suggestions on what is good, bad and ugly with regarding pbasic coding & execution speed would be appreciated.
Cheers!
Unread 10-02-2002, 12:43
I'm not sure how you are viewing the value of delta_t, but you should realize that debug statements are really slow. Put 1 or 2 in and delta_t will go up, so your code may be fine.
Unread 10-02-2002, 16:25
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
A trick to see Delta_t easily...
The following code has the lights up just on LED at a time on the OI. For me, it is easier to see.
Joe J.
PacketsMissed VAR delta_t
' put the following just after the serin command
PacketsMissed = delta_t +1
'I know the above is sort of "unclean" code because it is not obvious that a variable on the right side of the equation is also on the left, but for me it tells me that I have changed the definition of delta_t to something more to my liking. After I have incremented delta_t, I never refer to delta_t any more, only PacketsMissed
OUTS.lowbyte = 1 << PacketsMissed
'continue with code...
Unread 10-02-2002, 19:06
THanks for the code snippet!
I had already done, logically, what you stated (look at delta T and light an LED) since, as you point out, even a trivial debug statement can easily chew up 1 cycle (9600 baud, and probably polling! - the basic stamp sure sucks)
But what I DIDN'T know, is that you can use a variable to specify which LED to illuminate. That will help make my code somewhat tighter.
Thanks!
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Autonomous code PBoss Programming 7 14-01-2003 15:29
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Operator Interface is crazee !!! HELP punarhero Programming 30 17-07-2002 14:23
