Go to Post If you want to use the don't ask, don't tell logic about asking then you know it is wrong. - Steve W [more]
Unread 02-11-2003, 12:49
GregTheGreat's Avatar
GregTheGreat GregTheGreat is offline
GregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura about
Spikes with Motors
Does anyone know if a spike can be used to run a johnson motor on last years controller (2003)? The manual does not really state that it can't, but does not say that it can.
Thanks.
-Greg The Great
Unread 02-11-2003, 13:50
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
I don't think the Johnson Motor was in the kit last year, but according to the rules from 2002, the Johnson can be run from a relay module. It hink the reason the rules exclude it this past year is because the motor wasn't in the kit.
Unread 02-11-2003, 13:55
So the spike would need to be fun to a relay instead of a PWM?
Can anyone confirm this for me?
Thanks,
-Greg The Great
Unread 02-11-2003, 14:34
Mark Hamilton's Avatar
Mark Hamilton Mark Hamilton is offline
Belphegor made me do it.
#0108 (SigmaC@t)
Mark Hamilton will become famous soon enough
Send a message via ICQ to Mark Hamilton Send a message via AIM to Mark Hamilton
The spikes do in fact connect to the relay connectors on the IFI controller. I'm not sure exactly what would happen if you connected it to a pwm, but as they use the same voltage range, it would probably work anyway (but not suggested). The difference is the PWM's can output a range of values, the relays only puts out of and on.
Retired member of Team 108
Unread 02-11-2003, 16:52
Would it be able to jun a Johnson 12 volt DC motor, on a Relay Out?
-Greg The Great
Unread 02-11-2003, 17:10
Bduggan04's Avatar
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Yes, connect the motor to the spike and run the spike off of one of the relays.
Unread 02-11-2003, 17:44
based on your previous posts, you (Greg) don't have a lot of electronics experience, so don't try this!
The signals are not compatible, and definetly won't work.
Unread 02-11-2003, 17:56
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I hope everyone understands that the power for the motor and relay comes from the fuse panel, not the robot controller. It is only the signal (forward, reverse, or off) that comes through the small three-wire cable from the controller.
Unread 02-11-2003, 18:09
xplod1236's Avatar
xplod1236 xplod1236 is offline
None #0818 (Genesis '02)
xplod1236 will become famous soon enoughxplod1236 will become famous soon enough
Send a message via AIM to xplod1236
Lightbulb
You should be able to control a spike thru the pwm output. You would have to set the values to either 0, 127, or 254 for reverse, neutral, and forward respectively. If the signal is close to 0, 127, or 254, the spike should turn on, but I dont think it will work with any other value.
Unread 02-11-2003, 19:16
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
That will not work. The signals are not compatible. The connectors are the same but you cannot interchange PWM's and Relay Outputs. Please do not do that.
Matt
Unread 02-11-2003, 20:54
Matt
Thats What I was thinking...
However a Johnson can go on a spike and then to a Relay Output correct?
Thanks for The Help All,
-Greg The Great
Unread 02-11-2003, 22:29
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Greg, I suggest you ask one of the other members or mentors on your team before you try any of this. As we cannot really see how you have hooked it up before you apply power we cannot really tell you if somthings going wrong, if you read the manuals to the control system located here
quick start guide
http://www.innovationfirst.com/FIRST...tart_Guide.pdf
http://www.innovationfirst.com/FIRST...ence_Guide.pdf
those should get you pretty well started
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 02-11-2003, 23:24
quick start guide
I am aware on how to set up the main system, what I am asking is if a SPIKE (this years (2k3)) can operate a motor, I know how the connections go, and all that stuff, I just do not know if a spike can run a Johnson 12 Volt DC motor. The manual says (selonoids, pumps, etc.) Does this include motors, I am aware of how to connect it and how to run it to the breaker pannel and all that fun stuff, I just do not know if a spike can run a motor. Does anyone know if it can???
Thanks,
-Greg The Great
Unread 02-11-2003, 23:36
I know the spike can do light, compressor window, seat, and the tiny little Johnson if that is the one you mean. I know it cannot run the drill or chia. I don't know about the FP or globe.
Unread 03-11-2003, 08:16
The johnsons I am refering to are simmiler to the ones in FP gearboxes. The RPM tops off around 14,000 on a good battery.
-Greg The Great
Can you use the spikes with the globe motors? Caleb Fulton Electrical 1 15-02-2003 20:13
coding, motors, spikes, help archiver 2001 3 24-06-2002 00:48
