Go to Post In theory, there is no difference between theory and practice. In practice, however... - Alan Anderson [more]
Unread 10-11-2003, 22:55
yangotang's Avatar
yangotang yangotang is offline
#0253 (MRT)
yangotang is on a distinguished road
Send a message via AIM to yangotang
Where to Buy 40-Amp Fuse Panels?
Hello, I will make this quick and to the point.
I searched CD for "buy fuse panels" and "40-amp fuse panels" and nothing relevant turned up.
Could anyone direct me to a place that sells these 40-amp fuse panels?
Thanks in advance!
--Yang
Unread 11-11-2003, 09:18
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
ummm...
at the first yardsale, i saw a crate of those fuse blocks for the 40amp. maybe that means that first is dooing away with them?
I wouldnt suggest purchasing any...due to the fact if first unincludes them in the kit, thats a waste of money.
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 11-11-2003, 10:09
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
He never said that he wanted them for a FIRST-related project.
Unread 11-11-2003, 12:21
yangotang's Avatar
#0253 (MRT)
Hmm, I see.
What do you suggest I do?
My team is currenty in a mock-6-week build period, where we must find parts and stuff. I need a 40-amp breaker box in order to run the two CIM's that we have. the 30-ampers have been popping under load.
Any suggestions?
Unread 11-11-2003, 12:23
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Gear down your motors more.
Unread 11-11-2003, 12:36
yangotang's Avatar
#0253 (MRT)
I would have done that if my design would have permitted it.
Unread 11-11-2003, 13:39
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Stinger fuse holders to the rescue!
I have used a fuse holder by Stinger Electronic
Model: SFB1MAX
(about half way down the page)
I like them because they hold the MAXI fuse size, they snap together to make a bank of fuses, they have nice screw terminals for connecting wire, AND they are easy on the eyes.
On the down side they are not cheap (about $20 each) and they are not the lightest fuse holders.
But... ...on balance, I like them a lot.
Hope this helps.
Joe J.
Unread 11-11-2003, 15:07
AKA: Mongo
I have one fuse block, i dont need it, so i dont see why it would be an issue to give it to you...but those things are heavy, so it would be quite a bit for shipping (depending on how soon you need it)
pm me for more info
Unread 11-11-2003, 16:05
Make sure that going to a 40 amp circuit breaker makes sense. If you are only tripping the breakers at the highest loads, then a bigger breaker will help. But, if you're poorly geared, putting a bigger breaker in won't help at all.
Unread 11-11-2003, 18:44
KevinB's Avatar
AKA: Alum
Re: Stinger fuse holders to the rescue!
Sort of off topic, but I use one of these to protect the sound system in my car -- and it really does look mad pimp.
FIRST FYI: Best Buy Children's Foundation Grants Rich Wong FIRST E-Mail Blast Archive 16 01-12-2003 20:57
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
Blowing 60 Amp fuse archiver 1999 4 23-06-2002 22:07
Fuse Panels punarhero Electrical 5 18-02-2002 10:52
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
