Go to Post Q: "What does your robot do?" A: "It collects data about the surrounding environment, then discards it and drives into walls" - tsaksa [more]
Unread 11-02-2002, 22:03
Randy_Ai Randy_Ai is offline
Randy_Ai is an unknown quantity at this point
Smile Is a Limiter Switch allowed?
Hello guys,
Here's a question from team 820's engineers:
(I'm actually not too sure what it is, but if you have any idea, please reply)
Thanks.
Unread 11-02-2002, 22:06
thedillybar thedillybar is offline
#0894 (Chargers)
thedillybar is an unknown quantity at this point
Send a message via AIM to thedillybar
Limit switches are allowed, and I think this is what they're referring to. They basically send a 1 to the code when they are pressed, and a 0 when they are not (or vice versa, depending on how you have them wired). Check your manual. It talks about them in the Robot section under "Inputs" and explains how to wire them properly.
Joseph F Joseph F is offline
#0506 (Steel Friars)
Joseph F is an unknown quantity at this point
Send a message via AIM to Joseph F
i believe there are limit switches provided in the kit if thats what your looking for. if a limiter switch is something different (and with my lack of knowledge it very well could be) then one of the other teams will need to answer this for you.
One Team, One Bot, One Fleet of Ambulances!
Unread 11-02-2002, 22:24
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
If limit switches aren't allowed, we're going to be the first team DQed...
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 12-02-2002, 00:57
Larry Barello Larry Barello is offline
http://www.barello.net
#0492 (Titan Robotics Club)
Larry Barello has a spectacular aura aboutLarry Barello has a spectacular aura about
Unpowered switches are an unlimited item. Read the robot rules and additional hardware lists
Reed switches (actuated with magnets) qualify.
Note: this year there were no reed or limit switches in the kit. you have to get them elsewhere.
larry barello Team 492
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
Using a switch before autonomous operation KZos550 Programming 11 04-02-2003 19:12
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
