Go to Post instead of complaining, suck it up, think a little harder, and make the most of what you do have. - Andy Grady [more]
Unread 11-02-2002, 15:45
Huey_Da_X-cat Huey_Da_X-cat is offline
#0191 (X-cats`)
Huey_Da_X-cat is an unknown quantity at this point
Question 4 wheel steering/ Crab
Hi, the x-cats are having alittle trouble getting our unit calibrated. we were hoping that some one who has successfully done crab steering before could give alittle advice on how to keep the front and back wheels aligned. right now we have 1 chain wraped around to control all 4 wheels and a pot on the robot comunicating with a pot in the control. we found the pots aren't very presice and they tend to over compensate. we were hoping to switch over to 2 globes attatched to 2 pots to control front and back steering indepent of eachother. little help? sorry for any mistypes, 7 days till ship and we don't have much to hala about.
Unread 11-02-2002, 17:40
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
feed back loops are your best bet...
Search these forums on "steering feedback"
If you did, you will find the following message:
Old Forum Message on Steering
Read the thread, if you have questions, ask them in that thread or start a new one.
I think we can help you. Read a bit first and then get back to us.
Joe J.
Unread 11-02-2002, 22:23
Matt Reiland's Avatar
'The' drive behind the drive
Ahh I think I can help
We have a very similar setup and have the code working excellent. Email me tomorrow at the following:
matthew.reiland@gm.com and I will send you our code for 4 wheel steering with 1 motor and 1 potentiometer.
Ever since we used the inverse SIN approximation posted here by Leo the thing has been money
We are using a 10 turn pot because of the way everything is geared and it is pretty precise but a 5 turn would be perfect. Ohh well so the robot tracks just a bit off sometime.
Unread 11-02-2002, 22:49
CaptainPlaid's Avatar
CaptainPlaid CaptainPlaid is offline
#0314 (Megatron Oracles "Big MO")
CaptainPlaid is an unknown quantity at this point
We developed a crab walk last year but ended up not using it. We used two drills for the drive and a globe to turn them. We put two bolts through the chain that turned them to contact limit switches. Then we set up two limit switches at the point where the wheels were turned 90 degrees to either side. We also set up the regular junk-from-the-kit servo but only used it to return to center. The resolution worked fine for this. I believe we had the two triggers set up to turn the wheels to either side and the top button for return to center. This way the driver has control for the full 180 degrees but can always get back to center if needed.
I have not failed. I have just found 10,000 ways that won't work.
Thomas Edison
rotation of body of crab drive robots michael_obrien Technical Discussion 6 22-10-2003 19:32
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
What is crab steering?? Adam Y. Technical Discussion 18 30-12-2002 08:12
