Go to Post Don't worry so much about the wording of the rules but the intent of the rules. - Greg Needel [more]
Unread 24-11-2003, 18:13
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
What do you use for wheels?
Every year, we get into the situation where we have to choose/design our wheels. We've ended up using highly modified 6" skyway wheels for the last couple of years and are generally happy.
However, we have to double them up to get the width that I like (2") and we have to knock out the bearings and make many other time consuming mods.
We have made polycarbonate wheels, but they have fairly low friction with carpet. We have wrapped wheels in timing belt, which had much better friction characteristics, but tended to de-bond.
I wanted to try knurled aluminum, but last year's rules threw that out.
I like the skyway beak-lok design, but the choices are too big and heavy for my tastes.
So, I wanted to see what other people have used or plan to use for wheels.
Unread 24-11-2003, 18:25
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
Last year we used 4 9" pnematic wheels.
Unread 24-11-2003, 18:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Last year we used 4 of the skyway 9x2 beadloks like in the kit. We drilled them out to save weight and we turned them down to 8.5 in di to have a flat tread profile. While the traction was surprisingly good, the wear characteristics were not.
Next year we hope to go with a pneumatic tire.
Unread 24-11-2003, 18:36
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
we used 8 inch pneumatic wheel chair casters that we bought at a local supplier.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 24-11-2003, 18:40
Duke 13370's Avatar
Duke 13370 Duke 13370 is offline
C is for cookie...
#0862 (Team Lightning)
Team Role: Webmaster
Duke 13370 will become famous soon enough
Send a message via AIM to Duke 13370
We just use the wheel chair wheels, but i think we may make some custom ones this year.
---Lightning Robotics!---
Unread 24-11-2003, 18:54
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
We designed and made two 9" omniwheels using lexan and urethane as the front wheels. The back wheels were modified kit 9" skyway wheels, treaded.
[edit] This was for last year's robot only. [/edit]
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 24-11-2003, 19:28
Bill Gold Bill Gold is offline
Retired -- 2006
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
Our wheels change depending on our robot strategy and design. In 1999 and 2000 we used the 8" wheelchair wheels. In 2001 we used the 6" wheelchair wheels. In 2002 we built aluminum wheels that were 5.5" in diameter and 2" wide that we attatched belting material to. In 2003 we built aluminum wheels that were 6" in diameter and 1.25" wide that we attatched belting material to. We'll decide on wheel diameter and width, or tank tread width for 2004 the first week of the build period.
Unread 24-11-2003, 20:46
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
In previous years and the beginning of 2003, we took the 6" skyway wheels, lathed off all the rubber, and epoxyed a strip of some soft rubber tread stuff to the wheel. It gave us great traction. However, this year, when we tried the same thing, we found that our tread was all but gone after one regional, shredded away by the ramp. So we switched to these other, wider, 6" wheels made from smooth neoprene which weighed 2 lbs each (!!!) but gave us awesome traction, even on the HDPE.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 24-11-2003, 20:50
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Weuse plywood laminated wheels. This allows us to change treads easily if worn out or find some with better traction.
Unread 24-11-2003, 22:59
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
you mean no one else uses bricks?!?!
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 24-11-2003, 23:23
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Bricks????
Big Mike says you need bricks... Well when you have Gum RUBBER all you need is a 6 inch hole saw!
Refer to this thread:
http://www.chiefdelphi.com/forums/sh...ght=gum+rubber
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 25-11-2003, 08:53
What belting material? How did you attach? Did you have any problems with either slip or delamination at the join of the belt ends?
Unread 25-11-2003, 08:55
Re: Bricks????
These wheels look really cool. Where did you get the gum rubber? How much did it cost? Were there any problems of tearing at the bolt holes?
Unread 25-11-2003, 09:56
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Hmmm anyone ever think of casting their own wheels using poly urethane?? People do cast their own wheels for sumo robots using this material and it displays great traction. I just received an article on this. Apparently wheel hardness is measured on the Shore A hardness rating. This rating can rage from 10 to 80 where 80 is the hardness of a bowling ball and 10 is soft, gummy material. Though this material has only half the traction of the gum rubber. People also coat the wheels with silicone to improve the wheel's traction. Silicone can be bought at automotive stores. One last note. Generally high traction wheels tends to loose traction as it picks up dust so make sure that you clean it off with baby wipes.
Yeah modifying those tires in any way was a bad idea. My friend said that the synthetic material was not really designed to be modified. We lost our treads in the first run of our match.
Unread 25-11-2003, 11:12
Greg Young Greg Young is offline
Science Enabler
FRC #0587 (Hedgehogs)
Greg Young has a spectacular aura aboutGreg Young has a spectacular aura about
We use the Skyway 10 X 3 pneumatics for all four wheels. You can order them with bearings or keyways. They saved us last year when we had too much traction and were stalling motors trying to turn. We ran the pressure up to the specified max to reduce the contact patch and could turn again.
