Go to Post make your robot so it's not a problem and it won't be a problem - pfreivald [more]
Unread 15-02-2002, 19:12
punarhero's Avatar
punarhero punarhero is offline
#0696 (Clark Magnet Robotics)
punarhero is an unknown quantity at this point
Send a message via AIM to punarhero Send a message via Yahoo to punarhero
Question Prgm4 2 joystics control 1 speed cntrl???
Can someone tell me how to program 2 of the joystick ports to operate 1 pwm output????
Unread 15-02-2002, 22:37
Ameya's Avatar
Ameya Ameya is offline
Freelance Goon
FRC #0293 (SPIKE Robotics)
Ameya is on a distinguished road
Send a message via ICQ to Ameya Send a message via AIM to Ameya
Why would you want to have two joysticks control the same PWM output? Seems redundantly redundant to me.
Ameya Agaskar
Team 293 alumnus
Unread 15-02-2002, 23:08
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Do you mean two pwm's on one joystick, because i don't think it's even possible to control one pwm with two joysticks. I mean, you could, but it would be rather pointless.
To control two pwm's with one joystick is easy:
serout [255,255,pwm1,relay1,pwm2,relay2,pwm3,pwm4...pwm16]
just replace which ever pwm with the variable of the joystick...
serout [255,255,p1_y,relay1,p1_y, relay2,pwm3,pwm4...pwm16]
if this makes no sense, sorry, but i'm typing this on like, no sleep, and well, it makes sense to me.
Unread 16-02-2002, 12:44
punarhero's Avatar
Cool
Thanks for replying. What I want is for forward on two joystics to work the same PWM output. Call me crazy but there's a long story of why I need it.
Unread 16-02-2002, 18:24
Joseph F Joseph F is offline
#0506 (Steel Friars)
Joseph F is an unknown quantity at this point
Send a message via AIM to Joseph F
this is just off the top of my head... but i think it may go something like this...
If p1_y > p2_y then use1
pwm1 = p2_y
goto end
use1
pwm1=p1_y
end:
basically it takes whichever joystick is greater and uses that as the output to pwm1
you would have to edit the serout command so that it would read
[255,255,pwm1,relayA,p2_y,relayB,p3_y,p4_y,p1_x,p2_ x,p3_x,p4_x,p1_wheel,p2_wheel,p3_wheel,p4_wheel,12 7,127,127,127]
just remember if you did this you couldnt use pwm2 because p2_y would still control it as well as pwm1 if you went forward.
One Team, One Bot, One Fleet of Ambulances!
Unread 19-02-2002, 18:03
Ameya's Avatar
Freelance Goon
problem with previous response:
The problem with that solution is that you won't be able to go in reverse (since joystick centered is 127 and joystick reverse is less than 127).
Ameya Agaskar
Team 293 alumnus
Unread 19-02-2002, 19:42
then edit it to read:
If p1_y | p2_y < 115 then rev
if p1_y | p2_y > 135 then fwd
pwm1 = 127
goto end
fwd:
pwm1 = p2_y
goto end
use1
pwm1=p1_y
goto end
rev:
if p1_y < p2_y then use2
pwm1 = p2_y
goto end
use2:
pwm1 = p1_y
end:
Unread 21-02-2002, 09:57
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Try this
pwm1 = (p1_y + p2_y) / 2
switch speed control wayne 05 Programming 6 01-10-2003 09:35
speed control punarhero Technical Discussion 11 24-01-2002 18:03
