Go to Post Like a moth to a flame, true FIRSTers are attracted by the Victor instead of the Banner. - Rich Wong [more]
Unread 02-02-2004, 19:50
SeanCassidy's Avatar
SeanCassidy SeanCassidy is offline
Antiregistered User
#0263 (Aftershock)
SeanCassidy is an unknown quantity at this point
Interrupt timer, executing code asap?
Thanks for Innovation First for that good white paper on timers, without that I'd be lost.
Well I got the interrupt timer working, looks good. So I wrote this function to use the loop code. Here is the code:
void example(unsigned int seconds, char startEnd)
  static char runOnce1 = 0, runOnce2 = 0;
  if(startEnd == 1 && runOnce1 == 0)
    int snapSecondCnt = secondCnt;  //Take a snapshot of the seconds
    runOnce = 1;                    //Make sure it doesn't run again
    //Run any command to start here
  else if(startEnd == 0 && runOnce2 == 0)
    if(secondCnt == (snapSecondCnt + seconds))
      snapSecondCnt = 0;
      runOnce2 = 1;
      //Run any other stopping command here
  else
    printf("example() error!\n");
void Process_Data_From_Local_IO(void)
  /* Add code here that you want to be executed every program loop. */
  if (updateDisplay)
    INTCONbits.GIEL = 0;            /* Disable Low Priority Interrupts */
    updateDisplay = 0;
    INTCONbits.GIEL = 1;            /* Enable Low Priority Interrupts */
    rc_dig_out04 ^= 1;              /* Pin4 toggles every 1s */
    secondCount++;
    example(10,1);    //Start - My edit!
    example(10,0);    //End   - My edit!
    printf("Pin 4 = %d, Elapsed Time (s) = %d\n",(int)rc_dig_out04,secondCount);
Now let me explain briefly what this code does if you do not understand, it is vital to my question. The normal loop executes, until example(). It tells example to have a timer for ten seconds, and the second example is to stop the timer. I'm sure I could've done that a little better. So in example() if it's starting and it's its first time running (runOnce#) then it starts a motion, like say going forward (pwm01 = 254; pwm02 = 254; just say those are our motors at full throttle forward). The loop executes until the satisfied time is up (if(secondCnt == (snapSecondCnt + seconds))). Then it stops.
My question: does this approach even work in practice? I know that you have to be zip zip in and out of interrupts, but in the whitepaper it says that the interrupt od is the most effective timer. So does my example() start and end always take less than one second? Have I approached this totally wrong? Any tips?
I wouldn't recommend anyone to take this code for their own, it most likely doesn't work.
Unread 05-02-2004, 21:17
Antiregistered User
#0263 (Aftershock)
Re: Interrupt timer, executing code asap?
Was I meandering in my meaning? I apologize, sometimes I do that.
My question is purely that if a function is executed, does everything else stop while that is exected?
Unread 05-02-2004, 21:36
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Yes, only one thing can be happening at a time. When an interrupt occurs, whatever is currently happening stops, and the data being used gets set aside (onto the stack actually) Then the interrupt handler runs, and handles the interrupt (obviously). Then whatever code was running before resumes where it left off, without any real knowledge of the interruption.
Let me know if this doesn't answer you question.
Unread 05-02-2004, 21:48
Antiregistered User
#0263 (Aftershock)
So my example(), if it took 5 seconds (start and end each), then the timer itself would be off by 10 seconds? Well I need a fork().
Unread 05-02-2004, 22:33
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
technically, even fork() only does one thing at a time it just interlaces the needs of multiple things, so that part of one function executes, then part of the next, et cetera.
solution? no function in your bot code should last 5 seconds
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 05-02-2004, 22:41
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
No function in your bot code should last > 26.2 milliseconds.
Unread 05-02-2004, 23:42
Computer Guy
AKA: Dav
that too heck, no individual function should last anywhere near 26ms
Unread 06-02-2004, 15:22
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
except sine Well, if you forgot the lookup table!
Unread 07-02-2004, 00:10
Computer Guy
AKA: Dav
wouldn't be that useful a sine function if it took near 26ms - remember, you have do do something with it too
Unread 07-03-2004, 00:07
Daniel Daniel is offline
Daniel Katanski
#0240
Daniel is on a distinguished road
Real time programming requires the use of a "state machine", which is a programming technique where one state starts the motors, for example, and the second state monitors for a certain amount of time to pass before proceeding to the third state.
The second state can be entered multiple times without causing any problems. So the second state checks the time, then reutrns to the code where the data packets can be handled. Then the same fuction is called to execute the seconds state which looks at the time again.
State machines are best implemented using the C "switch" statement, and some long hard thinking.
Unread 07-03-2004, 01:47
Kevin Watson's Avatar
La Caņada High School
FRC #2429
As Dan pointed out, software state machines are a very powerful concept (I cannot possibly over emphasize this). I wrote a serial transmitter example that uses a state machine to generate the waveforms. The code can be found here.
-Kevin
Kevin Watson
http://kevin.org
Interrupts Questions mightywombat Programming 0 03-01-2004 14:50
EDU Demo Code: Serial Data Transmitter Using a State-Machine Kevin Watson Programming 3 28-12-2003 22:56
EDU Interrupt and Timer Template Code Kevin Watson Programming 8 22-12-2003 14:11
EDU Demo Code: Real-Time Clock Using a Timer Kevin Watson Programming 1 17-12-2003 15:14
