Go to Post Banned for being a nerd. There are no nerds in here! - Schnabel [more]
Unread 16-03-2002, 13:06
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
Question Good or bad: back wheels coming off the ground
During regionals, we discovered an interesting side effect of a super-strong goal grabber; we were being lifted off the ground.
Our goal grabber is T shaped, designed to be pushed out by pneumatics, rotated through a slot, and when pulled back rotate back to pull the goal in. The only thing is, the goal grabber pulls the goal into the chassis, which has a notch cut into it that will perfectly fit the corner of a goal. It's a very nice mechanism, somewhat self-aligning if the driver screws up, but the angle on the top of the "catcher notch" wasn't perfectly aligned. Now, when we pull a goal into us, the T goes all the way back into the robot and our back wheels get lifted about a quarter of an inch off the floor.
Mechanism:
http://groups.yahoo.com/group/gsgisr...s/files/IT.jpg
During regionals, we manufactured aluminum wheels to replace our front wheels, and now their diameter has increased by 1/4". Is this a good thing or a bad thing? We may get lifted farther off the floor, placing all of our weight on these two new wheels that supposedly have great traction. Is this better or worse than what we had?
-Gui Cavalcanti
"Guess what!?"
"What?"
"Our alliance won the VCU regional!"
"Good lord, how did that happen?"
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 17-03-2002, 15:07
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Seems to me that, since your wheels are all chained together, you'd have the same ability to impart force on the ground if two wheels were in the air. Actually, if the wheels you're on after gripping have more traction than the others, you might just be better off with the other two off the ground.
This all changes if you're pushing down on the goal, in which case you're losing normal force on your wheels, and not getting as much traction.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 17-03-2002, 22:09
CaptainPlaid's Avatar
CaptainPlaid CaptainPlaid is offline
#0314 (Megatron Oracles "Big MO")
CaptainPlaid is an unknown quantity at this point
We noticed this on Big MO during the Buckeye Regional this last weekend also. We actually have cylinders that lift up our gripper arms. If we do this with only one goal we tip up seriously. And we we accelerate too fast with only one goal we can get up on an angle. However, we have a very aggressive track drive system so it doesn't affect us much in terms of traction. When we have two goals and lift them up is when we get the real boost in traction. We are about to drive fine with one goal and our robot tipped up but there is really no advantage to it that I can see.
I have not failed. I have just found 10,000 ways that won't work.
Thomas Edison
Vanilla Coke..good? bad? A. Leese Chit-Chat 41 07-01-2004 00:15
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Our wheels don't touch the ground! ahecht General Forum 12 29-01-2002 19:35
