Go to Post Don't take things too seriously; It's supposed to be fun. :) - ScoutingNerd175 [more]
Unread 19-04-2002, 12:19
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
if you got 255 from two joysticks in a row ,your robot would do a "not-happy dance". believe me, sending two 255 variables in the wrong place at the wrong time doesn't work very well. resets the robot, and everything goes crazy. so, no 255 variables from the joystick, ever!
AIM --> Woloi
Email --> ian@woloschin.com
Unread 20-04-2002, 12:21
ChrisA's Avatar
ChrisA ChrisA is offline
#0857 (Superior Roboworks)
ChrisA is on a distinguished road
Send a message via AIM to ChrisA
heres also the easiest way to swap the x-axis values. just open up your joystick and swap the wires for the x-axis. this wont affect your y-axis in any way and is not that hard to do.
to confirm my buddy mike soukup 255-x does work and is the simplest way our team found to swap the joystick values in the code. we use it in our code right now and it works without any problems whatsoever. we have a pretty cool piece of code based off of this whole equation.
Programmer
Team#857
Superior Roboworks
WildStang Alum
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
multi-bank programming problem GregC Programming 3 14-02-2003 16:13
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
