Go to Post I'm absolutely certain that kids prefer scoring points to not scoring points - AdamHeard [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 18-01-2005, 20:07
anna~marie's Avatar
anna~marie anna~marie is offline
misses FIRST
AKA: HOT's first female operator
FRC #0067 (HOT- Heroes of Tomorrow)
anna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond repute
Send a message via AIM to anna~marie
Exclamation WARNING- New camera meets magic smoke
Just a warning to teams who haven't yet discovered...
Our new camera for autonomous mode fried at our team meeting tonight (oops ). Here's the layout of what happened so you guys don't make it turn bright orange and smoke...
  • Camera assembled with two Servo's attached (all in correct places)
  • Camera system hooked up to a PC
  • Camera's PMW and power supply attached to an '04 Robot Controller, hooked up to a modified cordless drill
  • and here's what made the mess... Wires from Servo external power supply hooked up to a cordless drill battery.
Here's a web-page one our of mentors found about this issue:
Finally, power is needed for the CMUcam2. Be very careful at this stage, reversing the polarity of the power source has a rather spectacular effect as I found out myself first-hand. Smoke, sparks and a dead CMUcam2. The positive (red) cable should connect to Vdd and the negative (black) cable connects to Vss.
Highly recommend NOT doing
I'm proud to be a...
Unread 18-01-2005, 22:16
roboticsguy1988's Avatar
roboticsguy1988 roboticsguy1988 is offline
Larry Johnston
AKA: Larry Boy
FRC #1501 (Team THRUST)
Team Role: Electrical
roboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud of
Send a message via ICQ to roboticsguy1988 Send a message via AIM to roboticsguy1988 Send a message via MSN to roboticsguy1988 Send a message via Yahoo to roboticsguy1988
Re: WARNING- New camera meets magic smoke
wow, sorry to hear about that. But thanks for posting..................now i will always check my power connection for the cam.
Larry Johnston, Team THRUST, Team #1501, Team THRUST webpage
2005 IRI - Imagery and Design Award
2005 - 2006 BMR - Professional Grade Award
2006 BMR - Delphi Driving Tomorrow's Technology Award
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~ RogerR
~Da team that uses all tha rivets, Team #1501~
The FIRST Software Repository ~ Chief Admin
openFIRST ~ Project Supporter (Former editor)
DMOZ.org - FIRST - US Teams Section ~ Chief Editor
Unread 18-01-2005, 23:36
Electrical Engineer
Rookie Year: 1995
Originally Posted by anna~marie
...Camera's PMW and power supply attached to an '04 Robot Controller, hooked up to a modified cordless drill...
I do not understand "and power supply". The camera gets all power from the PWM connection (according to the documentation I have)...
Mike Betts
As easy as 355/113...
Unread 18-01-2005, 23:44
russell's Avatar
russell russell is offline
#1430 (WRONG)
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
you can power it using whatever you want, and methinks they decided to use a cordless drill battery (btw what gave you that idea? is it the right voltage?). But this is probably a good thing to take note of, as it should apply even if you are using the pwm power hookup (though I am sure I have hooked mine up backwards a few times so I dunno why ours is ok....? I actually managed to make ours track a target today. It was a great moment.) Im sorry to hear about your camera though.
Unread 18-01-2005, 23:49
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
The following is quoted from the camera manual:
The servos can either be powered by internal power or by the external servo power connector. To run them from internal power, connect a jumper across the “internal power to servo” jumper. To run them off of external power, leave the “internal power to servo” jumper open, and connect an external 5-volt power supply to the “external power to servo” connector.
The included diagram is from the camera manual.
NOTE: The first setup assumes that the camera is connected such that the servos are powered from a PWM cable connected to the Robot Controller.
The camera pin diagram can be found on page 12 of the manual.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 18-01-2005, 23:51
CJO's Avatar
CJO CJO is offline
If you look at the PWM hook up, you will see that ground is the outside pin, hence, I would guess that if you failed to heed the many boldface warnings, and hooked up the PWM in reverse, little would happen, as there is no closed circuit.
Unread 19-01-2005, 01:06
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
7.2v
That's how much power they take.
If you look on the RC, you see that the output from the PWMs are 7.2v
Our head programming mentor hooked it up to a varible powersupply connected to the correct pins, and it ran fine.
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 19-01-2005, 13:15
cbudrecki's Avatar
cbudrecki cbudrecki is offline
AKA: Carl Budrecki (buh-dre'-key)
FRC #0222 (Tigertrons)
cbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to all
did anyone happen to get a picture of this spectacular event?
Unread 19-01-2005, 13:55
IMDWalrus's Avatar
IMDWalrus IMDWalrus is offline
This is a line...
AKA: Paul
FRC #0818 (Genesis '02)
IMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to behold
Send a message via AIM to IMDWalrus
You could try recreating it with your camera.
If this isn't a reminder to make sure that your connections are always right, I don't know what would be. Thanks for reminding us of that - I know I'll make extra sure of it from now on...
Unread 19-01-2005, 14:04
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
The correct thread title should be "WARNING - New camera parts with magic smoke". See http://www.chiefdelphi.com/forums/sh...877#post106877
Team 1257
Unread 19-01-2005, 15:10
anna~marie's Avatar
misses FIRST
Hey...drills are my friends....well okay, so we had a few lying around....
Sorry, no, but I can recreate it. . .
Small cubical, to the right of the keyboard was the camera and its accessories. Power cords clip onto the battery and at that moment, right along side of that computer adapter cord, a very bright orange glow emits and smoke billows up. Many crackling sounds, the light goes out...and the room smells like magic smoke
Unread 22-01-2005, 14:52
roboticsjenkins's Avatar
roboticsjenkins roboticsjenkins is offline
robotics_jenkins
AKA: Andrew
#0616 (Southampton Indian Robotics)
roboticsjenkins can only hope to improve
Send a message via AIM to roboticsjenkins Send a message via Yahoo to roboticsjenkins
Can Anyone post a picture or tell me how they mounted their servo motors to their camera box?
Unread 22-01-2005, 15:50
nparikh's Avatar
nparikh nparikh is offline
i heart infrared
AKA: Neil Parikh
FRC #0025 (Raider Robotix)
nparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond repute
Send a message via AIM to nparikh Send a message via MSN to nparikh
Well I can't tell you how they did it, but if you download this and then open the "start here" pdf, inside it has a sample configuration using serovs, and the works.
Doing the right thing is always better than doing the easy thing.
Team 25 Alumnus
Attending: NJ Regional, Boston Regional, the Championship Event
Unread 26-01-2005, 19:26
Redneck's Avatar
Redneck Redneck is offline
Hacker Hick
AKA: Jamie (2.0) Moran
FRC #0599 (Robodox)
Redneck is just really niceRedneck is just really niceRedneck is just really niceRedneck is just really nice
Send a message via AIM to Redneck
I wish I'd seen this about.... oh, 45 minutes ago.... we just fried our camera, too. Anyone have any solutions (other than the obvious one of ordering a whole new camera)?
Unread 27-01-2005, 00:32
nukem nukem is offline
nukem is on a distinguished road
Our camera board fried today as well. We talked to innovation first to get an RMA. We can send it back and they can look at it, if they feel that its our fault then we have to pay for them to fix it/replace it. Since just the board shorted anyone know how much the board would cost alone? One of our mentors looked at it and said that he could probably fix it. The problem is that if he cannt fix it we need to RMA it and then we will definatly need to pay for a new one.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
The Magic Smoke... BlueOrion Motors 17 30-03-2004 07:47
Anybody let the magic smoke out? Ryan M. Control System 17 11-02-2004 17:56
Magic: TG meets Gulf War II DanL Chit-Chat 2 05-02-2003 12:48
