Go to Post Change your process to change your product. - Justin Montois [more]
Unread 05-02-2005, 16:28
GregC's Avatar
GregC GregC is offline
I Like Cheese.
AKA: GERG
#0384 (Sparky)
GregC is an unknown quantity at this point
Send a message via AIM to GregC
Autonomous Camera Integration
Hey all,
My team is having quite a problem attemping to integrate the current camera code (2-26) into our default code for autonomous.
We're hitting all sorts of problems.
Can anyone PLEASE share their implementation so we have something to go off of?
We're totally stuck here!
Thanks!!
-Greg, 384
cheese
Unread 05-02-2005, 18:56
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Autonomous Camera Integration
Here's my two implementations:
int cmd_point_at_color(void)
#if _USE_CMU_CAMERA
static int state = START;
static int color;
static long int tolerance;
static long int time_out;
int rc = DONE;
long int heading_error;
switch (state)
  case START:
    color = PARAM1;
    time_out = robot_time + PARAM2;
    tolerance = MRAD2SERVO(PARAM3);
    camera_find_color(color);
    printf("Looking for color %d\r", color);
	state = TURNING;
    rc = WORKING;
    break;
  case IN_PROGRESS:
  case TURNING:
  case STOPPED:
  case LOST:
    if (cam.x == 0)  //Not found!
        state = LOST;
        break;
    heading_error = (signed int)cam.pan_servo - 128; //BOT: center of X on cam
    // Whether we are turning or stopped we want to always check heading
    if (heading_error < -tolerance)
	  // Turn Left
      set_vel(LEFT, TURN_SPEED);
      set_vel(RIGHT, -TURN_SPEED);
      state = TURNING;
    else if (heading_error > tolerance)
	  // Turn Right
      set_vel(LEFT,  -TURN_SPEED);
      set_vel(RIGHT, TURN_SPEED);
      state = TURNING;
    else
      if (state == TURNING)
        set_pid_stop(LEFT);
        set_pid_stop(RIGHT);
        state = STOPPED;
      else
        // We are stopped, so maintain postion
        set_pos(LEFT, 0);
        set_pos(RIGHT, 0);
	if (robot_time > time_out)
      state = COMPLETE;
    rc = WORKING;
    break;
  case COMPLETE:
	state = START;
	camera_stop();
    rc = DONE;
    break;
return rc;
#else
printf("POINT_AT_COLOR: Camera is not being used!\r");
return DONE;
#endif
int cmd_goto_color(void)
#if _USE_CMU_CAMERA
static int color;
int rc = DONE;
switch (state)
  case START:
    color = PARAM1;
    printf("Going to color %d\r", color);
	state = IN_PROGRESS;
    rc = WORKING;
    break;
  case IN_PROGRESS:
  case TURNING:
  case STOPPED:
  case LOST:
        state = LOST;
        break;
	  // Turn Left
      set_vel(LEFT, TURN_SPEED * abs(heading_error)); //Psuedo PID (more of a PD)
      set_vel(RIGHT, DRIVE_SPEED);
      state = TURNING;
	  // Turn Right
      set_vel(LEFT,  DRIVE_SPEED);
      set_vel(RIGHT, TURN_SPEED * abs(heading_error)); //Psuedo PID (more of a PD)
      state = TURNING;
    else
      // We are right on
      state = COMPLETE;
    rc = WORKING;
    break;
  case COMPLETE:
/*    set_pos(LEFT, counts);
    set_pos(RIGHT, counts);*/
    camera_stop();
	state = START;
    rc = DONE;
    break;
return rc;
#else
printf("GOTO_COLOR: Camera is not being used!\r");
return DONE;
#endif
int cmd_camera_stop(void)
#if _USE_CMU_CAMERA
    printf("Stopping camera\r");
    camera_stop();
    return DONE;
#else
printf("CAMERA_STOP: Camera is not being used!\r");
return DONE;
#endif
int cmd_track_color(void)
#if _USE_CMU_CAMERA
    int color = 0;
    color = PARAM1;
    printf("Tracking color %d\r", color);
    return DONE;
#else
printf("TRACK_COLOR: Camera is not being used!\r");
return DONE;
#endif
int cmd_turn_to_color(void)
#if _USE_CMU_CAMERA
int rc = DONE;
switch (state)
  case START:
    time_out = robot_time + PARAM1;
    tolerance = MRAD2SERVO(PARAM2);
    printf("Turning towards tracked color.\r");
	state = TURNING;
    rc = WORKING;
    break;
  case IN_PROGRESS:
  case TURNING:
  case STOPPED:
  case LOST:
        state = LOST;
        break;
	  // Turn Left
      state = TURNING;
	  // Turn Right
      state = TURNING;
    else
        set_pid_stop(LEFT);
        state = STOPPED;
      else
        set_pos(LEFT, 0);
        set_pos(RIGHT, 0);
      state = COMPLETE;
    rc = WORKING;
    break;
  case COMPLETE:
	state = START;
    rc = DONE;
    break;
return rc;
#else
printf("TURN_TO_COLOR: Camera is not being used!\r");
return DONE;
#endif
int cmd_drive_to_color(void)
#if _USE_CMU_CAMERA
int rc = DONE;
switch (state)
  case START:
    printf("Driving towards tracked color\r");
    rc = WORKING;
    break;
  case IN_PROGRESS:
  case TURNING:
  case STOPPED:
  case LOST:
        state = LOST;
        break;
	  // Turn Left
      state = TURNING;
	  // Turn Right
      state = TURNING;
    else
      // We are right on
      state = COMPLETE;
    rc = WORKING;
    break;
  case COMPLETE:
	state = START;
    rc = DONE;
    break;
return rc;
#else
printf("DRIVE_TO_COLOR: Camera is not being used!\r");
return DONE;
#endif
There is a lot of stuff in there that is not in the default code. You need to add it.
Unread 06-02-2005, 14:34
GregC's Avatar
I Like Cheese.
AKA: GERG
#0384 (Sparky)
Thank you!
We're getting all sorts of errors with what we are trying to do, we'll take a look at yours to try to figure out our own problems x_x
Thanks again
-greg
cheese
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Autonomous With Camera schenkin Programming 20 16-02-2005 23:52
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
