Go to Post I am mentored by individuals younger than 18 all the time. - Taylor [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:45
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Dashboard Viewer Beta Tester Needed
Posted by Nate Smith.
Other on team #66, GM Powertrain/Ypsilanti HS/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 1/21/2000 5:59 PM MST
I won't have access to my team's control system until Monday, so I was wondering if any teams meeting tomorrow who had any sort of a control system set up yet could do me a favor..go to the link below, and download the Dashboard Viewer beta 1. Then just hook up your OI to COM1, install the software, and see what it does...sorry, but yes, it does have to be COM1 for now, this will be fixed in the end. If you need it set for a different COM port, let me know and I can recompile the beta to use a different port and send it to you.
If you do this, please e-mail me at njsmith@online.emich.edu with the exact wording of any error messages that appear(i hope none do, i've already fixed a few) as well as general information as to how it worked(or didn't work!) Thanks!
Nate Smith
PS - This beta is just to make sure that the decoding functions work correctly. If they do, then I will clean up the code and release it...
#0047 (ChiefDelphi)
One more thing...
Posted on 1/21/2000 6:01 PM MST
In Reply to: Dashboard Viewer Beta Tester Needed posted by Nate Smith on 1/21/2000 5:59 PM MST:
One thing I forgot to add earlier, if you do download the software, PLEASE e-mail me at njsmith@online.emich.edu so I know who has given it a try...thanks!
Nate
#0047 (ChiefDelphi)
IMPORTANT UPDATE RE: Dashboard Decoder Beta
Posted on 1/21/2000 8:34 PM MST
Very shortly, I will be posting a NEW Dashboard.exe beta preview that uses my decoder library. I was notified shortly after posting of a few errors in the program, which I have corrected, and am currently working on a more robust UI for seeing all of the information passed through the Dashboard Port. As soon as is this completed, it will be posted to the same URL as mentioned in my message above. It should be completed by 11:30pm EST, and will be online at that time if not before.
To use the new program, download and install the old version that can be found at the link below. After doing this, download the new EXE file and copy it over the one installed by the setup program. Thanks to everybody who's volunteered to beta test it!
Nate
#0047 (ChiefDelphi)
Updates are now Online (EOM)
Posted on 1/21/2000 9:37 PM MST
In Reply to: IMPORTANT UPDATE RE: Dashboard Decoder Beta posted by Nate Smith on 1/21/2000 8:34 PM MST:
(EOM)
#0047 (ChiefDelphi)
Thank you team 470!
Posted on 1/22/2000 3:14 PM MST
Thanks to team #470, I was able to perform extensive testing on the Dashboard Decoder library today, and have just finished making the new code much cleaner and a bit more reliable. Download the final beta(hopefully) at the link below.
Nate Smith
#0047 (ChiefDelphi)
Message above AKA: Final Beta Ready for Download!
Posted on 1/22/2000 4:07 PM MST
In Reply to: Thank you team 470! posted by Nate Smith on 1/22/2000 3:14 PM MST:
(EOM)
#0047 (ChiefDelphi)
For all of you who were asking...AKA: OCX Source Code
Posted on 1/22/2000 5:53 PM MST
Well, I've gotten a few e-mails already asking for the source, so I just uploaded it, rather than e-mail it out to everybody...if you need help figuring anything else out, just drop me a line...
Nate
#0047 (ChiefDelphi)
A new record, more info, and I need beta testers again...
Posted on 1/22/2000 8:46 PM MST
Well, I think this is a new record for the most posts by one person in a thread...and probably about the only time that a single person has been the only one talking on a thread with this many messages in it...but, just wanted to share the latest additions for those of you thinking about writing a custom dashboard program..
The latest revision to my Dashboard Decoder library includes the following:
- 'CommError' event to notify the user if there is a problem communicating with the OI.
- The program will no longer crash if the OI is reset!
- Also, documentation is included as to how to use the library to start writing your own UI.
This program should be available before midnight EST for testing by those of you who are meeting tomorrow(Sunday - I know there's a few out there.) In order to keep easier track of the different beta versions that are circulating, there will not be a direct web page link to download the newest version. Please e-mail me at njsmith@online.emich.edu if you are interested in testing this version(only if you are meeting this Sunday please), and I will e-mail back to you with the information needed to download the updated version.
Nate Smith
PS - Here's a look at one of the many possible ideas for a custom program using the Decoder Library.
#0047 (ChiefDelphi)
Re: Dashboard Viewer Beta Tester Needed
Posted by Lora Knepper.
Student on team #69, HYPER (Helping Youth Pursue Engineering & Robotics), from Quincy Public Schools and The Gillette Company.
Posted on 1/23/2000 7:44 AM MST
I just figured that I'd add another voice to this thread for you. :-) Team 69 will be running your final beta in just a few short hours, and I'll be sure to tell you how it goes. Thanks for everything Nate!
Lora Knepper
[IMG] code is Off
Has anyone implemented a dashboard viewer in WinCE? archiver 2001 1 24-06-2002 02:40
Team #118 ccisd/jsc robosonauts dashboard viewer public now archiver 2000 0 23-06-2002 23:12
Firestorm Dashboard Viewer Beta 2 archiver 2000 0 23-06-2002 22:58
Firestorm Dashboard Viewer archiver 2000 0 23-06-2002 22:57
Dashboard Viewer Khalicl13 Technical Discussion 8 15-06-2001 23:36
