Go to Post Step 1. Understand the game and how to win the match and the event. - Chris Fultz [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:13
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
control system programming
Posted by Jimmy Holmes.
Coach on team #27, Team RUSH, from Osmtech Academy and DaimlerChrysler.
Posted on 3/2/2000 6:26 AM MST
I hope the vast FIRST community can help us with this problem.
We are trying to run two van door motors at the same time using two different speed controllers
and two different pwm outputs on the controller. The problem is they run at two different speeds and cause
our arms to go out of alignment.We had them variable, running off of the same joystick ( pull back they both
go up, push forward they both go down). To solve the problem we made the joystick act like a switch
and changed the max values so they would run at the same speed, but know it is very jerky, (on off,
on off). We want to be able to be variable again but still adjust for the different speed motors. Is there a routine
that we could run in the program that could account for the difference? We know its not a friction issue just the motors
are not the same. I would like to thank you in advance for any help.
Jimmy Holmes Team27
#0047 (ChiefDelphi)
Re: control system programming
Posted by Mike Gray.
Engineer on team HOT from Huron Valley Schools sponsored by GM Milford Proving Ground.
Posted on 3/2/2000 8:29 AM MST
In Reply to: control system programming posted by Jimmy Holmes on 3/2/2000 6:26 AM MST:
Suggestions:
1. Eliminate the possibility of mechanical problems, with the motor or with the drivetrain.
2. Check for volt drops across terminations.
3. Check the integrity of the suspect speed controller, per InnovationFIRST instructions.
4. If the first three are fruitless, scale the PWM value to the speed controller:
First, determine the speed error. Declare a new variable which will be scaled to reflect the speed error. The new variable will be a transfer function for the faster motor. Perform a slope and intercept (mX+b) transform on the joystick variable and set the new variable equal to it.
Example:
new_variable=joystick / 2 + 64
This example assumes that you want to scale the variable to half-scale. You must add 64 counts so that 127 counts still represents center-stick. If you want 1/4 speed, simply divide by 4 and add 96.
Unfortunately, this method wil not make full use of the faster motor's potential, but you can't make the slow motor go any faster than 255 counts.
Even after scaling, the motors may launch unevenly due to variation in static friction. If you need to start the motors many times during a match, static friction may cause the linkage to 'warp'. I suggest using the x-axis on that joystick to modify the y-axis variables, so the operator can make small corrections to the linkage on the fly.
Hope this helps.
#0047 (ChiefDelphi)
Clever Software is no substitute for Rigid Hardware
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 3/2/2000 9:03 AM MST
In Reply to: Re: control system programming posted by Mike Gray on 3/2/2000 8:29 AM MST:
I think you are in for some real problems if the difference in motor speed is enough to bend your arm out of shape.
As a team that has had two motors driving 1 arm from different sides of the robot for 5 years now, I have a LOT of experience in this area.
Our standard has always been that, in such cases, the mechanism between the motors/gearboxes must be able to tolerate the motors driven in OPPOSITE directions without damage. I will admit that at times we have had machanism that didn't particularly LIKE such treatment, but never any that would suffer any permanent deflection (at least not by the time we were done with them).
This standard has served us well.
If you are having problems with the simple differences you have from the manufacturing tolerances of the motors, what are you going to do when one side of the arm catches on the goal or when some other robot loads one side of your arm or if you overload your motors and one motor's breaker trips slightly before the other?
Clever software is at best a band-aid to cover lack of rigid hardware.
I may be wiser to remove one of your motors and use the weight to stiffen up the hardware on your arm thus allowing the load to be driven from one side.
My advice, for what it is worth.
Joe J.
#0047 (ChiefDelphi)
Re: Clever Software is no substitute for Rigid Hardware
Posted on 3/2/2000 9:32 AM MST
In Reply to: Clever Software is no substitute for Rigid Hardware posted by Joe Johnson on 3/2/2000 9:03 AM MST:
You are right Joe. Software should never be used as an attempt to 'fix' a poor mechanical design. Software can however enhance greatly a good design.
In '98, we used parallel 4-bar linkages driven by separate motors. Warping was actually a feature, in that the end-effector could be skewed up to 30 degrees simply by driving the linkages at different rates.
For '99, I used 2 sets of compound 4-bar linkages to for the extensible member, each driven by a window lift motor. Learned a lot about motor variation, as 'warp' or 'skew' was not desired. Chose to match motors or adjust drive ratios rather than 'fix' the thing with software.
#0047 (ChiefDelphi)
THE SOLUTION IS ACTUALLY VERY EASY
Posted by Patrick.
Coach on team #409, Flaming Eagles, from Oak Grove High School and NASA Ames Research Center.
Posted on 3/2/2000 6:34 PM MST
In Reply to: Re: Clever Software is no substitute for Rigid Hardware posted by Mike Gray on 3/2/2000 9:32 AM MST:
I hate to see all of you stressing like this, but have you considered using 2 speed controllers but only 1 pwm output? Included in the electronics bag should be a pwm cable that has red, black ad yellow instead of red, black and white. This cable plugs into pwm or realy outputs and splits into 2 outputs to a speed controller/spike. This calibrates the 2 victors exactly the same. That is what we are doing and have no problems with different speeds whatsoever.
-Patrick Wesonga
Team 409
San Jose, California
#0047 (ChiefDelphi)
Re: THE SOLUTION IS ACTUALLY VERY EASY
Posted by Jerry Eckert.
Engineer from Looking for a team in Raleigh, NC sponsored by .
Posted on 3/2/2000 9:06 PM MST
In Reply to: THE SOLUTION IS ACTUALLY VERY EASY posted by Patrick on 3/2/2000 6:34 PM MST:
: I hate to see all of you stressing like this, but have you considered using 2 speed controllers but only 1 pwm output? Included in the electronics bag should be a pwm cable that has red, black ad yellow instead of red, black and white. This cable plugs into pwm or realy outputs and splits into 2 outputs to a speed controller/spike. This calibrates the 2 victors exactly the same. That is what we are doing and have no problems with different speeds whatsoever.
Unfortunately, this solution doesn't address speed differences caused by variances in the mechanical assemblies, including the motors.
#0047 (ChiefDelphi)
Posted by Dung Cao.
Engineer on team #397 from Flint Southwestern Academy and Delphi Automotive - E&C.
Posted on 3/2/2000 9:16 AM MST
Another thing you can do is to calibrate the speed controller with the joystick you are planning to use. I found after calibration, the two speed controller will output the same PWM to both motors. The innovation FIRST web site has the documents on the 883 and how to calibrate it.
Good luck
: I hope the vast FIRST community can help us with this problem.
: We are trying to run two van door motors at the same time using two different speed controllers
: and two different pwm outputs on the controller. The problem is they run at two different speeds and cause
: our arms to go out of alignment.We had them variable, running off of the same joystick ( pull back they both
: go up, push forward they both go down). To solve the problem we made the joystick act like a switch
: and changed the max values so they would run at the same speed, but know it is very jerky, (on off,
: on off). We want to be able to be variable again but still adjust for the different speed motors. Is there a routine
: that we could run in the program that could account for the difference? We know its not a friction issue just the motors
: are not the same. I would like to thank you in advance for any help.
: Jimmy Holmes Team27
#0047 (ChiefDelphi)
Adjustment Screw on Motors.
Posted by Raul.   [PICTURE: SAME | NEW | HELP]
Engineer on team #111, Wildstang, from Rolling Meadows & Wheeling HS and Motorola.
Posted on 3/2/2000 2:57 PM MST
I fully agree with JJ's and other's suggestion to make your mechanism more rigid. However, I also assume that it may be too large of a design change to make at the competition site.
If you can still find a way, I would still try to put a rigid member from one side to the other that will force the motors to follow each other and thus they will in effect be working in parallel.
You said that it is not a friction problem in your mechanism. Did you know that the Van door motors have an adjustment screw for the worm gear tension? So, if all else fails, you can play with the tension on it until both motors are running the same.
#0047 (ChiefDelphi)
Re: Adjustment Screw on Motors.
Posted by Justin Stiltner.
Student on team #388, Epsilon, from Grundy High School and NASA, American Electric Power, Town of Grundy.
Posted on 3/3/2000 8:38 PM MST
In Reply to: Adjustment Screw on Motors. posted by Raul on 3/2/2000 2:57 PM MST:
What exactly does this screw do ?
Justin Stiltner
Team 388
#0047 (ChiefDelphi)
Posted on 3/3/2000 9:52 PM MST
In Reply to: Re: Adjustment Screw on Motors. posted by Justin Stiltner on 3/3/2000 8:38 PM MST:
I believe it is intended by design to allow the manufacturer to install the worm gear and adjust the free play and/or backlash on the worm gear. But it also can be used to induce extra friction and help to prevent backdriving (which is what we often do).
Some may argue that this will artificially reduce the life of the worm gear. However, in 1998 we relied exclusively on this feature to prevent our lift from sagging when extended and holding up our cage full of balls. We were in several matches that year (including a run of 8 straight matches in the elimination rounds) and never had a failure. We just had to tweak the tension periodically.
Raul
#0047 (ChiefDelphi)
Posted on 3/4/2000 4:08 PM MST
In Reply to: Re: Adjustment Screw on Motors. posted by Raul on 3/3/2000 9:52 PM MST:
Hmmm
you may have just saved me from doing a lot of fabracating at regionals.
Thanks
Justin Stiltner
Team 388
Unread 23-06-2002, 22:14
#0047 (ChiefDelphi)
Loosing output & breaking worm gears
Posted on 3/4/2000 5:09 PM MST
In Reply to: Re: Adjustment Screw on Motors. posted by Justin Stiltner on 3/4/2000 4:08 PM MST:
One option we explored last year when we discovered to our shame and horror just how backdriveable the Delphi Power Sliding Door Motors were, we too looked at the option of overtightening the screw on the motor armature.
It may work in the case you are looking into because you are really only trying to match free speeds,
BUT...
... I have a word or two of caution for teams trying to use such methods as a means of not falling when their robot is hanging:
Be careful.
There are two problems you can run into.
#1, you can easily loose 50% of the output of your motor this way -- even if you can afford the loss of stall torque, that is a lot of heat into those motors. If it is a motor you use a lot during a match you will run the risk of tripping the internal circuit breaker on the Delphi Power Sliding Door Motor (the same holds true for the window motor and the seat motor by the way).
#2, Even if you can stand the loss of output and the heat in the motors, you can tighten them so tight that if something DOES backdrive the motor (another robot trying to pull you off the bar, for example ;-) the plastic worm gears or the even the motor shafts can be damaged. Again, using our robot last year as an example, we tightened the nut so tight at one point that we could not backdrive the motor even with the weight of the robot working against it BUT our nice double D shaft looked like a piece of saltwater taffy after a match or two. Even our team, with as relatively easy access to spare power sliding door motors as we have, thought this was an unreasonably short motor life ;-) A redesigned mechanism allowed us to sleep at night without fear of having to replace motors rapidly.
Just a message from a team that has been there and done that. Take it for what it is worth.
Joe J.
#0047 (ChiefDelphi)
If using the van door motors to hang...
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 3/4/2000 6:06 PM MST
In Reply to: Loosing output & breaking worm gears posted by Joe Johnson on 3/4/2000 5:09 PM MST:
: ... I have a word or two of caution for teams trying to use such methods as a means of not falling when their robot is hanging:
Just a quick tip if anybody is using the van door motors to hang(like we are)...if you're looking for an easy way to keep from sinking when you stop lifting yourself up, just set the speed controllers to turn the electronic braking on(the jumper on the left two pins), and you'll hang there forever...we've got a 130lb machine, and we hung there for a long time...as long as you don't unplug the battery, that is... =)
Nate
See everybody at Ypsi!
#0047 (ChiefDelphi)
helps but not a panacea
Posted on 3/4/2000 8:16 PM MST
In Reply to: If using the van door motors to hang... posted by Nate Smith on 3/4/2000 6:06 PM MST:
As big of a fan of dynamic braking as I am, this too has its limits as I have discussed elsewhere on this forum.
It can do wonders if you are in the ballpark. If not, go to a non-backdriveable mechanism.
Again, just one man opinion.
Joe J.
#0047 (ChiefDelphi)
Works for us...
Posted on 3/4/2000 8:25 PM MST
In Reply to: helps but not a panacea posted by Joe Johnson on 3/4/2000 8:16 PM MST:
We've got both van door motors on the opposite ends of a winch spool, that uses small-diameter (1/4' or 3/16', not sure which) spectracord attached to a hook made from 1/4' aluminum plate. Our winch mechanism is mounted in the center of a piece of 1/4' aluminum angle that spans the rear of our machine. We weigh in at ounces under 130, and the braking is enough for us...so I'm happy with it =)
See everybody in Ypsi!
Nate
[IMG] code is Off
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
UNFAIR ADVANTAGE for CDI and new control system archiver 2000 6 23-06-2002 22:13
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
