Go to Post i will not post here...i will not post here....well...okay, yes I will - David66 [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:07
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Yellow Ball Question
Posted by Raul.   [PICTURE: SAME | NEW | HELP]
Engineer on team #111, Wildstang, from Rolling Meadows & Wheeling HS and Motorola.
Posted on 10/16/2000 6:08 AM MST
Please verify if my logic is correct:
If there are two yellow balls in scoring positions in one of your ramps, but your robot is touching one of them, then you still get the 10 points for the one you are not touching.
Is this correct?
Raul
#0047 (ChiefDelphi)
Two or more yellow balls in SCORING position => 0
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 10/16/2000 8:00 AM MST
In Reply to: Yellow Ball Question posted by Raul on 10/16/2000 6:08 AM MST:
Tricky issue.
I am going to rule that the second yellow ball is not in scoring position (because it is being touched by a robot of the same color designation as the ramp. Therefore, the second yellow ball does not cancel the 10 points scored by the first yellow ball.
Good question.
Joe J.
[IMG] code is Off
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Yellow Freight Question archiver 2001 0 24-06-2002 02:35
Big Ball Question... archiver 2001 2 24-06-2002 00:54
30" ball sits up there real pretty archiver 2001 18 23-06-2002 22:49
