Go to Post We also use CAD heavily. Cardboard Aided Design. Which is considerably more accessible and intuitive to most students than the other CAD. - JamesCH95 [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:13
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
scoring ramp dimensions
Posted by Suzy.
Engineer on team Bulldogs from Breithaupt/Renaissance sponsored by DaimlerChrysler.
Posted on 10/22/2000 6:05 PM MST
Do you have the dimensions of the scoring ramp? I mean the placement of the squares on the ramp, where are they compared to the sides and each other?
#0047 (ChiefDelphi)
See Field Section
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 10/22/2000 6:41 PM MST
In Reply to: scoring ramp dimensions posted by Suzy on 10/22/2000 6:05 PM MST:
See the picture below.
It has been up for days on the 'field pictures' section of the main CDI page.
Good Luck.
Joe J.
#0047 (ChiefDelphi)
Re: See Field Section
Posted by Suzy.
Posted on 10/23/2000 5:26 PM MST
In Reply to: See Field Section posted by Joe Johnson on 10/22/2000 6:41 PM MST:
the picture is blurry and hard to read, this is why I asked for dimensions. Please list what the numbers are supposed to be or have a sharper picture. thanks from a 'blind' engineer.
#0047 (ChiefDelphi)
What my eye sees...
Posted on 10/23/2000 6:53 PM MST
In Reply to: Re: See Field Section posted by Suzy on 10/23/2000 5:26 PM MST:
The numbers look okay on my screen. Perhaps it is just that I have seen them before.
In any case here is the basic dim. stuff.
The squares are all 9 1/2 by 9 1/2 so I won't go into them any more.
Skipping the dim's detailing the squares, the dim's on the left side of the ramp read (from top to bottom)
34 3/4
19
3 1/4
Again skipping the dim's for the squares, the dim's along the top of the ramp read (from left to right)
9 1/4 and 29 1/4
The entire ramp is 48 by 48 in true view.
The ramp is 6 inches high (less the carpet).
The sub-floor is a 3/4 inch piece of plywood, spaced down 3/4 of an inch (by a wood '1 by 3'). The sub-floor is carpeted in the color of the ramp (red or blue, depending on the side of the field).
The edges and middle support for the ramp are made from a '2 by 6' cut into right triangles, the legs of which are 5 1/4 and 47 11/16. (Which works out to be 47.975 inches for the long side of the triangle -- ideal for mounting a 48 X 48 inch sheet of plywood to ;-)
I hope that this clears things up a bit.
Joe J.
[IMG] code is Off
Robot/Goal scoring: Official Answer Mike Martus Mike Martus OCCRA 6 21-10-2003 23:51
Pulling robot off ramp legal? archiver 2000 2 24-06-2002 00:14
hieght of the scoring ramp archiver 2000 1 24-06-2002 00:08
Technical question about ramp balancing archiver 2001 5 23-06-2002 22:29
Field and shelf missing dimensions kmcclary Off-Season Events 3 12-10-2001 18:21
