Go to Post You can't observe things that aren't seen or reported. - Andrew Schreiber [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:17
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
ps and pdf to dxf ???
Posted by nick.
Other from kk high school.
Posted on 10/31/2000 11:50 PM MST
i have to convert and view postscript (.ps and .pdf)files in .dxf formats.
I tried WITH SOFTWARES LIKE ghostscript,pstoedit.... but failed because of some complicated .PS files
converting postscript files to dxf format..
i need ,a software which can run from command line.
thanks
NICK
#0047 (ChiefDelphi)
What are you trying to do?
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 11/1/2000 6:11 AM MST
In Reply to: ps and pdf to dxf ??? posted by nick on 10/31/2000 11:50 PM MST:
Nick,
What are you trying to import postscripts files of? Text, images, graphics?
Just on the surface, it seems like a kind of goofball thing to want to do (not that I haven't wanted to do a few goofball things myself from time to time).
If you tell us what your end goal is, there might be another way to skin the same cat.
Joe J.
P.S. You ask for a command line program. Do Unix, DOS, CP/M? If you are interested in Unix, you may try ImageMagik, it is a very powerful image program that we use on our webhost. We are only using it to automatically generate the thumbnail pictures for our picture gallery pages, but it is much more powerful than that. I have not looked into whether ImageMagik can help you or not, but you may want to check it out at the link below. Good Luck
#0047 (ChiefDelphi)
Magick Vs. Magik
Posted on 11/1/2000 6:19 AM MST
In Reply to: What are you trying to do? posted by Joe Johnson on 11/1/2000 6:11 AM MST:
I see that I have mis-spelled 'Magick' in ImageMagick.
Ah well... ...I suppose I should just let it pass, but someone may actually need the correct spelling to find the product so...
In this case, 'Magic' is officially mis-spelled in the following way 'ImageMagick' not 'ImageMagik' as I had inappropriately mis-spelled it in my last message. Clear? ;-)
Joe J.
[IMG] code is Off
