Go to Post Guess i don't know what the secret weapon is, but i bet if it can be wedge shaped it is. - Chris [more]
Unread 23-06-2002, 23:58
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Pump Problems...
Posted by Anton Abaya at 2/1/2001 1:03 AM EST
Coach on team #419, Rambots, from UMass Boston / BC High and NONE AT THE MOMENT! .
well, we plugged the pump through the 60amp circuit breaker and we started playing around with it. (meaning we turned the pump on)...
in less than a minute, the circuit breaker was dying on us...anyone got a clue?
-anton
ps. josh is actually the one with this problem as i have not touched those PNEUMATICS. but any tips will help in case josh suddenly drops dead..
#0047 (ChiefDelphi)
Re: Pump Problems...
Posted by Al Skierkiewicz at 2/1/2001 1:55 PM EST
Engineer on team #111, Wildstang, from Wheeling High & Rolling Meadows High and Motorola.
In Reply to: Pump Problems...
Posted by Anton Abaya on 2/1/2001 1:03 AM EST:
Anton,
This is a strange one since there is every indication you can put a dead short across the breaker without tripping it for several seconds. Did the breaker repeatedly trip or just the one time. If just once, it was probably half tripped from shipment. If more than once and the pump was running fine, then you might have a defective breaker. In testing the pump we found it draws about 12 amps when getting upwards of 80PSI but draws more when starting. The start peak is normal and should not trip the breaker.
Let me know what you find.
#0047 (ChiefDelphi)
circuit breaker is bad?
Posted by Anton Abaya at 2/1/2001 11:44 PM EST
In Reply to: Re: Pump Problems...
Posted by Al Skierkiewicz on 2/1/2001 1:55 PM EST:
: Anton,
: This is a strange one since there is every indication you can put a dead short across the breaker without tripping it for several seconds. Did the breaker repeatedly trip or just the one time. If just once, it was probably half tripped from shipment. If more than once and the pump was running fine, then you might have a defective breaker. In testing the pump we found it draws about 12 amps when getting upwards of 80PSI but draws more when starting. The start peak is normal and should not trip the breaker.
: Let me know what you find.
: Al
umm, well i had our baby running at high gear today for like 10 minutes straight on the drills with vicious vicious spins and maneuvers. hmm, i wonder.
can i just buy a new circuit breaker from home depot or something? (is it a specific kind?)
well, time will tell. (do we have any extras of these babies?)
-anton
[IMG] code is Off
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Joystick problems archiver 2001 3 24-06-2002 02:40
Radio problems -- not archiver 2000 1 23-06-2002 22:23
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
Pneumatics pump allowed on robot? bigqueue Pneumatics 5 06-01-2002 12:30
