Go to Post There will always be a point in your FIRST experience when you realize you can get away with something that is against the rules. It is at that point when you have a choice to make about your own personal ethics, and what sort of example you will set for your students. - ToddF [more]
Unread 24-06-2002, 01:10
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
How can i mount a pneumatic piston to a pvc pipe!?!?!
Posted by Rob DeCotiis at 2/20/2001 1:27 PM EST
Student on team #504, RoBUCtics, from Red Bank Regional High School and Jesel.
#0047 (ChiefDelphi)
Re: How can i mount a pneumatic piston to a pvc pipe!?!?!
Posted by Kevin Sevcik at 2/20/2001 3:44 PM EST
Other on team #57, Leopards, from BT Washington and the High School for Engineering Professions and Exxon, Kellog Brown & Root, Powell Electrical.
In Reply to: How can i mount a pneumatic piston to a pvc pipe!?!?!
Posted by Rob DeCotiis on 2/20/2001 1:27 PM EST:
well it's probably too late now, but as a note for regionals...
I would think it'd depend on what the piston is doing and how much force is acting on it. if the mount doesnt need to be very strong or straight, then just hose clamp the thing on. otherwise, I'd take a block of wood, delrin, etc. and drill a hole the size of the pvc and a hole the size of the piston with about 1/2 inch between them. then you cut both holes in half, and screw that into the pvc and hose clamp the piston against the pvc, so it rests in that mounting. you'll probably need two of these things to get it straight, but it's fairly simple to do.
Unread 24-06-2002, 01:11
#0047 (ChiefDelphi)
Posted by Patrick Dingle at 02/21/2001 7:46 PM EST
Coach on team #639, Red B^2, from Ithaca High School and Cornell University.
One word: duct tape.
Patrick
#0047 (ChiefDelphi)
Posted by jason at 02/23/2001 1:16 PM EST
Student on team #521, waterford high school And millstone power station, from waterford high school and northeast utilities/ millstone power station.
our team used two piece of lexan to hold all of pnumatics on to are arm and it works good
#0047 (ChiefDelphi)
ZIP TIES!!!
Posted by Anton Abaya at 02/24/2001 3:20 AM EST
Coach on team #419, Rambots, from UMass Boston / BC High and NONE AT THE MOMENT! .
those babies are the cure for everything that fails!!!!
[IMG] code is Off
