Go to Post Will.I.Am is not FIRST. - BrendanB [more]
Unread 06-07-2002, 15:48
nwagers nwagers is offline
#0240 (Mach Vee)
nwagers is an unknown quantity at this point
Send a message via AIM to nwagers Send a message via Yahoo to nwagers
Spike Relay Input
Does anyone know the pinout to the Spike Relay module where the PWM cable plugs in? I'm guessing that black is ground, Red is Power (+5V), and Yellow/White is the input.
Unread 06-07-2002, 19:39
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Re: Spike Relay Input
Yeah, that sounds right. If you're looking for info on the Spike Modules try these two sites from Innovation First: Spike Users Maual or Spike Installation Manual. I hope this helps!
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 16-07-2002, 18:20
The input to the Spikes is two opto isolators with resistors in series. They each drive a transistor which switches the coil currents. The input to a Spike, and the Relay outputs from the RC, are ground (black sounds good for this) and switched positive voltage on the other two wires, one controlling each of the two individual armatures of the relay.
info:
The Red Spikes' output terminals both rest connected to ground, and when either one of the two coils is energised, the armature corresponding to the energized coil, is brought to +12V., and current flows in the output load either to the grounded other armature terminal or, if connected as permitted last year, to ground.
Unread 16-07-2002, 22:23
#0240 (Mach Vee)
yeah, after I posted i realised that two of the wires had to be input and I played around with it until i found the right combination
Black - must be grounded
Red - puts it in reverse
White - puts it in forward
Spike RED Pinout Venkatesh Electrical 3 31-03-2003 21:42
Nason pressure switches JP_1163 Pneumatics 11 03-03-2003 23:03
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
Programming port input? Rickertsen2 Rumor Mill 1 21-01-2003 17:26
2.5 is alive !!!! (input ! .. more input ! ) Lloyd Burns Programming 2 14-01-2003 19:15
