Go to Post Well, John V-Neun still has a little bit of hair. Maybe it'll be an astroturf field? - Amanda Morrison [more]
Unread 06-11-2001, 06:53
Mark Jones Mark Jones is offline
Engineer - Team 343 MIM
FRC #0343 (Metal-in-Motion)
Mark Jones will become famous soon enoughMark Jones will become famous soon enough
Send a message via AIM to Mark Jones
Question Valeo window motor
Does anyone know the pitch and pressure angle of the spur gear on the Valeo window motor.
Unread 06-11-2001, 10:14
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
20 Degree Pressure Angle
The gear on that motor is a 20 Degree Pressure Angle gear.
The gear is 12 Tooth, 16 Diametral Pitch, Stub, 20 Degree Pressure Angle,
The gear is a "Stub" tooth gear, but it can mate okay with a full depth gear if you increase the center distance a bit from the theoretical number. Another option is to put shave the OD of the standard gear by .4"/DP, which in this case is .4/20 or .020"
If you are making your own gear, then of course, just make the gear a stub gear to begin with -- (.8/DP for the addendum, 1/DP for the dedendum).
Good Luck.
Joe J.
Unread 06-11-2001, 12:57
Gear limitatations from SPI
Thanks Joe...I thought it was a 16 pitch and something not available from Small Parts. Hopefully, FIRST will reinstate the "any size and any amount of sprockets, gears, and pulleys" rule for 2002.
Unread 06-11-2001, 16:47
AKA: Dr. Joe
FRC #0088 (TJ2)
My bad.
Yes the gear is a 16 DP gear.
I said that in one spot but missed it in another.
The OD of a standard gear should be cut .4"/16 = 0.025" in order to mate properly with the stub gear on the Valeo window motor.
Joe J
need window motor pic!! Rickertsen2 Motors 3 04-02-2003 21:50
window motor solid model Redhead Jokes Inventor 0 04-02-2003 14:23
Nippon Denso Window Motor Specs RichardBCR Motors 13 26-01-2003 07:01
The window motor is being mean to me... archiver 2001 2 24-06-2002 03:02
window motor archiver 1999 0 23-06-2002 21:52
