Go to Post Unconventional isn't necessarily innovation. - AdamHeard [more]
Unread 06-09-2002, 19:50
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
How differnt is basic stamp pbasic from...
first controller pbasic???
Unread 06-09-2002, 22:26
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Not a whole lot. There's some stuff that the Stamp can do that the RC doesn't use, and so that's a bit different. The language is the same, though. Just what you can do is different.
Jeff Waegelin
Unread 07-09-2002, 12:25
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
there is no indivual I/O commands. you can do everything but that. Inupt is handled by the 'SERIN' command, and output by the 'SEROUT' command.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 08-09-2002, 09:57
Don's Avatar
Don Don is offline
#0288 (the RoboDawgs)
Don is an unknown quantity at this point
Send a message via AIM to Don
I'm going to have to disagree with Jeff. I've made a small robot using just a bs2sx chip and I've programmed our teams robot and I thought there was a noticeable difference. It's true that pbasic is used for both, so the syntax for commands is exactly the same.
What helped me to understand the difference is two things. Learn how the FIRST RC controller works and figure out how the default program works. It may seem pointless to learn how the RC works, but it really helped me.
Unread 08-09-2002, 11:58
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
I think the stamp is a bit more simpler than pBasic.... sometimes too much that you don't know what's wrong. Our team lost the instruction book, does anyone know where I can go to download a copy for reference?
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 08-09-2002, 13:23
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
If you're refering to that spiral bound book from parallax, its at Parallax'swebsite. Its not too useful though, as most of the problems my team has ever had are specific to the InnovationFIRST controllers. For those problems, your only real resource is this forum.
Unread 08-09-2002, 14:28
College? What?
the best way to learn how to program for FIRST is to take the default program, and know it by heart. all you need to know is in it. then, when you need more advanced functions, go to the manual.
AIM --> Woloi
Unread 08-09-2002, 17:07
FRC Key Volunteer Trainer
AKA: CrazyNate
In Reality....
There is no physical difference between "standard" PBasic and "FIRST controller" PBasic, as there is an identical STamp 2sx chip used in either case. However, how much of the language is actually useful in the FIRST controller is the real question, as all I/O is handled through the RC's master CPU, rather than direct pin access like you would in a standalone setup...
Nate Smith
nsmith@smythsoft.com
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
Which PBASIC Stamp Editor are you using? Carl Owenby Programming 8 16-03-2003 00:44
Connecting USB webcam to pbasic stamp? JasonStern Programming 15 14-02-2003 23:45
Auxilliary Basic Stamp Chip Kai Zhao Technical Discussion 9 07-01-2003 21:21
Is anyone using the BASIC Stamp Preprocessor? Greg Ross Programming 4 12-02-2002 12:24
