Go to Post That statement makes far too much sense for me to understand it. - Aignam [more]
Unread 10-09-2002, 17:34
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
PHP File Uploading Scripts
um, yeah.
ok, i'm an aspiring coder (read: some lazy guy who has a cheap webserver at home and doesn't like to carry floppy disks to school ), and i was looking around for some beginner level PHP scripts that would let me upload files through the HTTP protocal (err, that's redundant, isn't it...) to my server, from school.
i've seen several ones built into forums (like the one right here), but i don't want to make a forum just to use the upload script . so, i was wondering if there are any standalone scripts that someone could point me too. doesn't need to do much, just let me upload files to one folder and then i'll be happy. if possible, i'd want password protection, but that's not the biggest deal to me.
so, if anyone knows where to get any good scripts that work, please tell me, cause i don't like floppy disks..
and thanks in advance to anyone who can help.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 10-09-2002, 17:46
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
i can pull out all the 'forum' stuff from the image gallery, and post it on here.
it used to be stand-a-lone
It will just have the input box for the filename and then save it somewhere on your servers filesystem.
I'll put the script up tonight.
Brandon Martus
e-mail
Unread 10-09-2002, 17:57
College? What?
hmm, i guess i could try that. as i said before, it just needs to be able to handle any type of file uploads. of course, i'd rather be able to block other scripts or exe's, or have password protection, but i'm sure i can find a way around that.
one other question. if i took a PHP script that offered password protection, and then put that to login to the file uplaod thing, would that work? i'm not really good with PHP, so i don't really know what i'm talking about . just a random idea that poped into my head. the only other idea i have for password protection is some crazy way through IIS (or apache, if i'm ever not lazy enough to go and make it work), because i think it's possible to do that, but once again, i'm not really sure.
anyways, thanks again brandon.
AIM --> Woloi
Unread 10-09-2002, 18:10
busy.
AKA: B. Slash Kamen
it depends on what kind of security script you have.
the easiest way to do it (if you can & know how) is to set up .htaccess on apache.
If you're going to only have one login, then we can do a real simple username/password thing with the script.
I will make it so it only accepts file extensions that you specify. And has one login.
Brandon Martus
e-mail
Unread 10-09-2002, 18:42
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
...or if you wanna take the cheap-n-easy dan way out....
dump this into a file and name it upload.html:
PHP Code:
<html><head><title>PHP's FileUPLOAD</title></head><body>
<form enctype="multipart/form-data" action="upload.php" method="post">
<input type="hidden" name="MAX_FILE_SIZE" value="500000">
Username: <input type="text" name="user" size="10"> <br>
Password: <input type="password" name="pw" size="10"><br>
Send this file: <input name="userfile" type="file">
<input type="submit" value="Send File">
</form>
</body>
</html>
and name this upload.php
PHP Code:
<?php
if ($user != "ian"  ||  $pw != "is_hot")
    exit();
// In PHP earlier then 4.1.0, $HTTP_POST_FILES  should be used instead of $_FILES.
if (is_uploaded_file($_FILES['userfile']['tmp_name'])) {
copy($_FILES['userfile']['tmp_name'], "uploads/".$_FILES['userfile']['name']);
    echo
"upload success!";
} else {
    echo
"Possible file upload attack. Filename: " $_FILES['userfile']['name']
"<br>(<a href=\"http://www.php.net/manual/en/features.file-upload.errors.php\">error code</a> "$_FILES['userfile']['error'] .")";
That basically uploads the file to a directory called "uploads" in the php script directory (you have to make it) when the username is "ian" and the pw is "is_hot". This is quick, dirty, but it should work (if you have the newer php version and didn't set a crazy anti-global directive thing in the php config file, you need to change the first php line to:
if ($_POST['user'] != "ian" || $_POST['pw'] != "smells")
for more info, go here and here
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 10-09-2002, 21:10
busy.
AKA: B. Slash Kamen
yeah
thats basically what i was gonna do.
dan saved me some time.
mines a bit more cumbersome and probably confusing..
Brandon Martus
e-mail
Unread 10-09-2002, 21:13
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer &amp; Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
almost like HTML but different.
Unread 10-09-2002, 21:18
busy.
AKA: B. Slash Kamen
well, the top is html . ..
Brandon Martus
e-mail
Unread 10-09-2002, 21:21
College? What?
dan's thing works, but i have some problems with certain files. not a huge thing, just kinda annoying. now, i should probably learn PHP...
EDIT
yeah, i think the problem is with having the file size too small, but i made it much bigger (like, a GB), and it still failed to load a 2 MB file. i'm not sure if it's because it was an exe too, but it gave me errors based on file size. any ideas?
AIM --> Woloi
Unread 10-09-2002, 23:33
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Perl rules! Woo! *kicks php*
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 10-09-2002, 23:34
busy.
AKA: B. Slash Kamen
what were the errors?
copy/paste em, and we can help better
Brandon Martus
e-mail
Unread 11-09-2002, 15:14
College? What?
before it gave me error codes 1 and 2 for uploading files, now it just displays a blank screen and does nothing. i'm not sure why. maybe you guys have an idea?
AIM --> Woloi
Unread 11-09-2002, 16:32
Crusty Mentor
FRC #0097
Probably cause the username/password don't match and it was a 5-minute coding job so there's nothing in the code to tell you that, so nothing happens. Try changing the first few lines of the PHP to this:
PHP Code:
if ($user != "ian"  ||  $pw != "is_hot") {
   echo
"Username and Password don't match.  Hit back and try again.";
   exit();
Dan L
Team 97 Mentor
Unread 15-09-2002, 11:31
Trashed20's Avatar
Trashed20 Trashed20 is offline
Boom, Shawalala Boom!
#0862 (PCEP Lighting)
Trashed20 will become famous soon enough
Send a message via AIM to Trashed20
if you are still having problems try checking your php.ini file and the max file size argument. The max file size thing in the input is just an advisement, while the one in the php.ini file is the law, it can't be bigger than that, no matter what.
p.s. thanks to the people that posted this script, i wanted to do the same thing, and it was really easy to intregrate into my current user/login system thanks
Where has all the fun gone?
Unread 15-09-2002, 15:03
College? What?
where is the php.ini file? i saw it mentioned, but i couldn't find it anywhere.
AIM --> Woloi
File Sharing and Revision Tracking Madison FIRST-related Organizations 14 04-06-2003 18:01
php vs. perl Jack Website Design/Showcase 20 29-12-2002 17:01
Dashv2.ocx dependency file now available archiver 2000 0 23-06-2002 22:00
What's better, PERL/cgi or PHP/my_sql? mikefrei Programming 10 27-05-2002 22:50
Improving PBASIC: Request for Comments Greg Ross Programming 19 16-02-2002 22:14
