Go to Post When Andy Baker holds an iPhone 4 in his left hand, the signal [i]increases[/i]. - Billfred [more]
Unread 11-06-2001, 16:40
Khalicl13 Khalicl13 is offline
#0486 (The Positronic Panthers)
Khalicl13 is an unknown quantity at this point
Send a message via AIM to Khalicl13 Send a message via Yahoo to Khalicl13
Exclamation Dashboard Viewer
I have recently became interrested in developing Windows applications and and I thought about how I can apply it to my robotics club. One way I thought of using it was to make a Dashboard Viewer that displays the data from the robot and operator interfaces.
I know that there are some people who have already created such programs. I was just wondering has anyone else attempted to create such a program. If so, I'd like to get in contact with you about creating a Dashboard Viewer.
My goal is to create a more customizable version of the Dashboard Viewer. Wish me luck.
Khalid Harun, Student Project Manager, Programmer, Webmaster
Team 486 - The Positronic Panthers
www.positronicpanther.com
_Khalid_13@yahoo.com
Unread 11-06-2001, 20:30
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
I did one in C/C++ back in 2000. It worked pretty well and I believe some people had some luck with it. In general most people found Dashboard Viewers to be unneeded but I'm sure some people found them useful. I know that Nate Smith did a version in Visual Basic.
My program, including source code, can be found at
http://www.bcpl.net/~mleese/dashboard.html
I did my Dashboard Viewer in two separate components. One was the graphical interface and the other was the library for reading from the dashboard port. I tried my best to abstract out the library for the interface as much as possible. The GUI is in C++ built with MFCs (because it was fast and I wanted a quick GUI). The library is written in straight C. They both have a dependency on the Win32 library. Someone (I forget their name but probably have it around somewhere) was kind enough to provide Java bindings for the library. That's not included with the source code above but I have it sitting on my harddrive if you're interested.
If you want a technical description of what I developed, feel free to ask. I can walk you through most of it as it isn't terribly complex. It does however use both Serial Port programming and Multithreading (the multithreading is done fairly badly but I haven't updated it since I learned better ). Anyway, I hope some of this helps.
Matt
Unread 11-06-2001, 21:12
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
We needed to use a dashboard program to view the position of our arm... when we were wedging with the bridge, we could have a button that moved our arm to a specific position.. but in order to set taht position we needed to have the dashboard there to view the position. It was very helpful... muhc better than doing a debug within the program
Tom
Unread 12-06-2001, 00:21
Thanks for the Response
Thanks for the quick response. I thought that I wouldn't get anything for a couple of days. thanx.
I'll be sure to contact some of you in a few days right after I get finished with my finals. I know that there are some really good dashboard viewers out there. Instead of displaying the data in terms of numbers, my goal is to eventually replace them with graphics such as the positrion of an arm or a voltage meter that is supplied to the drill motor or the exact position of the joysticks.
Eventually, I hope this makes some of the teadious tasks of calibrating joysticks and the Victors much easier.
Well, anyway, this will be among my tasks to do over the summer. I will be sure to contact some of you sometime next week.
And again, Thanks.
Unread 12-06-2001, 03:10
FRC Key Volunteer Trainer
AKA: CrazyNate
Yep, I made one...more specifically, I made a OCX that can be used in Visual Basic, VC++(or so I've heard), and just about anywhere else that supports ActiveX controls...I'm almost certain I've still got a copy of it around here somewhere...just a word of warning, it hasn't been tested with the 2001 control system, not that it should make a difference...my understanding of the changes to the dashboard for 2001 from 2000 was that they just changed one of the values returned (Port 1 X rather than Port 1 Wheel)
Nate
Nate Smith
nsmith@smythsoft.com
Unread 13-06-2001, 16:32
Ameya's Avatar
Ameya Ameya is offline
Freelance Goon
FRC #0293 (SPIKE Robotics)
Ameya is on a distinguished road
Send a message via ICQ to Ameya Send a message via AIM to Ameya
Question Dashboard ActiveX control
Nate
Could you post the source for the ocx file?
Ameya Agaskar
Team 293 alumnus
Unread 15-06-2001, 23:03
mccullocht mccullocht is offline
no team (n/a)
mccullocht is an unknown quantity at this point
Send a message via AIM to mccullocht
Java bindings for dashboard
Actually, I'm the one who wrote the bindings for the dashboard in java, so if you're interested in that, just email me (I think my email address is shown on this thing or something) and I can send it to you. I wrote an interface between Matt Leese's C library and Java, and then wrote a java wrapper class. The interface is slightly (very) obtuse, and I'm planning on rewriting it in native java. I also plan on writing a java class library of UI widgets for displaying different feedback from the robot in different ways. Again, if you're interested, just email me.
Trevor
"Thou shalt not follow the Null Pointer, for at it's end Madness and Chaos lie." -- Anonymous
Unread 15-06-2001, 23:24
AKA: CrazyNate
Re: Dashboard ActiveX control
Assuming that I can find the CD I put it on, sure...let me see what I can find...
Nate Smith
Unread 15-06-2001, 23:36
AKA: CrazyNate
hmmm, you can't add a file attachment when you're editing a post, so here's the code...i think i completed any changes I was making to it...I do see that the code is updated for the 2001 port format change...let me know what you find out...
Nate Smith
Has anyone implemented a dashboard viewer in WinCE? archiver 2001 1 24-06-2002 02:40
Team #118 ccisd/jsc robosonauts dashboard viewer public now archiver 2000 0 23-06-2002 23:12
Firestorm Dashboard Viewer Beta 2 archiver 2000 0 23-06-2002 22:58
Firestorm Dashboard Viewer archiver 2000 0 23-06-2002 22:57
Dashboard Viewer Beta Tester Needed archiver 2000 8 23-06-2002 22:45
