Go to Post Please try to apply GP to situations where it makes some sense, as otherwise you're just diluting the meaning. - Kevin Sevcik [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 08-10-2002, 15:18
hinge87 hinge87 is offline
#0226 (TEC CReW)
hinge87 is an unknown quantity at this point
Send a message via AIM to hinge87 Send a message via Yahoo to hinge87
Slotted Angle Aluminum
Is Sloted Angle Aluminum allowed in the OCCRA competitions?
Unread 09-10-2002, 18:15
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Slotted Alum Angle
This all depends. If your team takes reg. angle available from listed sources and slots it using appropriate legal tools then there is no problem at all. Hack saws and files along with a drill press works great.
If you are asking about purchasing slotted alum or extrusion alum that is in any special configuration then the question is, "Is this alum available from the approved sources".
Please read the OCCRA manual and materials section regarding this situation.
If this is not the answer you wanted please re ask the question and I will confer with the other leaders for a clearer answer.
Mike Martus
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
Bosch Aluminum Structural Framing Carl Owenby Technical Discussion 37 15-01-2003 21:11
Is an angle bracket allowed? archiver 2001 0 24-06-2002 00:58
Difference in aluminum archiver 2001 1 23-06-2002 23:49
Let's get some aluminum extrusions archiver 1999 3 23-06-2002 23:12
