Go to Post I'll not deprive you of the practice in reading the manual; you'll need it if you want to be an effective part of an FRC team. - Alan Anderson [more]
Unread 13-01-2012, 13:06
The Crop? The Crop? is offline
FRC #3475 (The Crop?)
The Crop? is an unknown quantity at this point
Removing LED's
So, after looking over the rules we couldn't find out rather or not it is legal to take the LED's from our components, and move them to the outside of our chassis for troubleshooting.
Unread 13-01-2012, 13:10
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Removing LED's
I encourage you to read rule 58.
[R58] The control system is designed to allow wireless control of the Robots. The Driver Station software, FirstTouch I/O module, cRIO, speed controllers, relay modules, wireless bridge, and batteries shall not be tampered with, modified, or adjusted in any way (tampering includes drilling, cutting, machining, gluing, rewiring, disassembling, etc.), with the following exceptions:
Emphasis mine.
I'm right 90% of the time, so why worry about the other 3%?
Unread 13-01-2012, 13:12
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Removing LED's
What components? Kit parts or components you make?
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 13-01-2012, 14:33
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Re: Removing LED's
If it's the former, then you might try using some cheap fiber optic cabling you see in light-up toys to run the light to the outside of the chassis.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 13-01-2012, 19:20
Re: Removing LED's
I kind of like the fibre optic idea, I don't think we'll worry about it though. It's really more of a cosmetic thing.
