Go to Post Any metric you want to apply to Pink, they will pass with flying colors. Pun intended. - Lil' Lavery [more]
Unread 14-01-2012, 13:42
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
Test Code
How do we test code on the robot without building and running as startup. We want to see if the code will work how we want to without erasing the previous code off of it.
Unread 14-01-2012, 13:47
Re: Test Code
Open Robot Main.vi and press the "play button" near the top left of the window.
Unread 15-01-2012, 22:05
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
Re: Test Code
is that it. i thought we tried that but it didn't work. there isn't anything we have to do after that?
Unread 15-01-2012, 22:14
Re: Test Code
Click through any warnings or windows that pop up. Make sure you are using Robt Main, not teleop or autonomous.
Unread 15-01-2012, 23:46
Re: Test Code
What did it do instead of what you expected?
Unread 15-01-2012, 23:50
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
Re: Test Code
If you use the teleop or autonomous, the code executes once, because it is not in a loop. By running robot main, the code sits in the actual game code loop.
By pressing the play button, it only disables the startup code, and runs your code in its ram, so when you restart the robot, the code disappears, and no harm is done.
Unread 16-01-2012, 07:39
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
Re: Test Code
Try to have the "Projectexplorer" and robot main open. Then run it. It should work
"A team back in training !"
Unread 16-01-2012, 08:26
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
Re: Test Code
thank you so much!!! i was using teleop (which is why it wouldn't work). i tried to run continuosly, but since none of the refnames were set, it didn't know what to do. thanks again!
