Go to Post Doughnuts would probably be a pretty good alternative to churros. However, that could be open to debate. - Calvin Hartley [more]
Unread 15-01-2012, 18:24
Renegades2012's Avatar
Renegades2012 Renegades2012 is offline
FRC #4409
Renegades2012 is on a distinguished road
Crio?
We are having trouble flashing our Crio. Is there a patch or something that can fix this?
Team 4409
"I spent the last few years building up an immunity to Iocain powder." ~Westley <3Princess Bride<3
Unread 15-01-2012, 19:29
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Crio?
Are you remembering to include your team number?
Some more details would be helpful. Alternatively, using the search function may help you.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 15-01-2012, 19:47
FRC #4409
Re: Crio?
We have downloaded the program 3 times and it will not come up. we do not know what to do and we have checked the FIRST site. We do not know what to do next...
Team 4409
Unread 15-01-2012, 19:51
Re: Crio?
Make sure you are following the steps in the Getting Started Guide
If you are still having trouble with imaging, check out this thread on the FIRST forums:
http://forums.usfirst.org/showthread.php?t=18509
Unread 15-01-2012, 20:14
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Crio?
Be sure to download the language specific update for the image to come up. All of the updates can be found here, but you only need the one that you are programming in (Java, C++ or LabVIEW). Hope this helps.
I'm right 90% of the time, so why worry about the other 3%?
Unread 15-01-2012, 20:39
slijin's Avatar
Pockets
AKA: Samuel Lijin
Re: Crio?
You're not being very clear about what exactly your problem is. Is it just that you don't know how to use the imaging tool? Please describe what exactly you've done and where in the process you're getting stuck at.
Perhaps p17-18 of this will help.
Unread 15-01-2012, 21:11
mesamb1's Avatar
mesamb1 mesamb1 is offline
AKA: Sam Bacon
FRC #1466 (Webb Robotics)
mesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nice
Re: Crio?
Your problem may perhaps be just an IP issue if your cRIO is not even being seen by the cRIO imaging tool.
