Help With Programing
Hello my team is a rookie team and its the first time we do FRC and we finally got the java image on the cRIO now were running ode that is directly copied from the java guide and its not running. Our code is as follows:
package edu.wpi.first.wpilibj.templates; import edu.wpi.first.wpilibj.SimpleRobot; import edu.wpi.first.wpilibj.Servo; import edu.wpi.first.wpilibj.RobotDrive; import edu.wpi.first.wpilibj.Timer; import edu.wpi.first.wpilibj.Joystick; public class RobotTemplate extends SimpleRobot { RobotDrive drive = new RobotDrive(1, 2); Joystick leftStick = new Joystick(1); Joystick rightStick = new Joystick(2); /** * This function is called once each time the robot enters autonomous mode. */ public void autonomous() { for(int i =0; i < 4; i++){ drive.drive(0.5, 0.0); Timer.delay(2.0); drive.drive(0.0, 0.75); Timer.delay(0.75); } drive.drive(0.0,0.0); } public void operatorControl() { while (isOperatorControl() && isEnabled()){ drive.tankDrive(leftStick, rightStick); Timer.delay(.005); } } } |
Re: Help With Programing
Is it not connecting to the computer or what?
BTW, I would not use the for loops. Remember the "action" is not done almost instantly, it takes time for a physical object to be actuated. I would also take out the delays. |
It's great to see rookie teams dive into text based programming languages!
getWatchdog().feed()? I think that's missing, or did you not enable watchdog? either way, the code looks fine other than that. |
Did you fix the db37 cable (the ribbon cable connecting the digital sidecar to the cRio) if not then the jaguars/victors will not work in ports 1 and 2. they will in ports 3 and 4 (we figured that out after a lot of testing)
here is the document on fixing the cable if it applies: http://www.usfirst.org/sites/default...structions.pdf |
i did not enable the watch do I'm not really sure what that does
Basically the watchdog is a guardian. When enabled you need to "feed()" it and keep it happy. However if your code goes into an infinite loop or something the code will not be able to "feed()" the watchdog and it will die, and dis-activate the motors and other components with it, so that the robot doesn't go wild and break itself or something else.
However if you did not enable the watchdog, you should be fine not putting the code in for it. |
#7
I just copied your program and pasted it into a new project and ran it. Other than the motor ports not matching mine, it seemed to run some motors, at least in autonomous. I didn't have joysticks on the test platform.
Were you seeing no movement at all? If so, I'd look for other problems, like (as has been said) the cable to the digital breakout board, or something else. You should verify that the driver station software is set up properly and that you see green "Communications" and "Robot Code" indicators and that your team number is set correctly. Let us know after trying those things. Brad |
#8
drive.setSafetyEnabled(false); // this turns off motor safety
for (int i = 0; i < 4; i++) {
Timer.delay(2.0);
drive.arcadeDrive(0.0, 0.75); // this was a typo in the book
Timer.delay(0.75);
drive.drive(0.0, 0.0);
