Go to Post I WANT MY POOF BALLS! - Cyber Punk 234 [more]
Unread 17-01-2012, 17:38
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
How to import Rectangular Target Processing on robot code
Hi, I would like to know how to successfully integrate the "Rectangular Target Processing.vi" into a seperate robot code. I tried doing it but it did not work. All i did was copy paste the code from "Vision Processing.vi" and replaced it when the one in the robot code. How can i successfully get it to integrate it/?
"A team back in training !"
Unread 17-01-2012, 17:54
Re: How to import Rectangular Target Processing on robot code
There's a Tutorial in the Tutorials section of LabVIEW that explains how to do it.
Unread 17-01-2012, 22:54
Read the comment at the top left corner of the Vision Processing example's block diagram. It gives directions specifically tailored for adding it to an existing robot project.
Unread 15-02-2012, 12:00
The Trooper The Trooper is offline
FRC #2559 (nOrMaLiTy zErO)
The Trooper is an unknown quantity at this point
I was having the same issue until I followed those instructions, now I do not know how to calibrate the camera settings since I have successfully imported it.
Can you give me some guidance?
