Go to Post When all you're holding is a hammer, every problem looks like a nail. - artdutra04 [more]
Unread 18-01-2012, 11:29
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Vision Tracking With Color
Some teams are using led's to make the reflective tape shine a different color. How are you doing that? shining a light right on it? or a light next to the camera?
Unread 18-01-2012, 11:36
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
shuhao is an unknown quantity at this point
To be honest, and color processing will probably be harder than just gray scale with white light.
Unread 18-01-2012, 11:38
Re: Vision Tracking With Color
The strip is a retroreflective material. It reflects light preferentially right back at the source. So you want to put a light as close to the camera lens as practical. When you use a colored light source, the reflection is shockingly obvious.
Unread 18-01-2012, 11:56
so would it be easier to use color or gray scale or shapes?
Unread 18-01-2012, 12:43
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Using gray scale has two main advantages:
  • Smaller image size by setting the colour level to 0 in the camera
  • Easier to find a threshold
The great thing with a uniquely coloured LED is you can have a smaller threshold range and therefore less particles that aren't the actual vision targets you're looking for.
Depending on what your goal with the camera is, you will likely do shape detection in either case.
Unread 18-01-2012, 13:17
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
We purchased the Ring Light from AndyMark as part of our FIRST Choice order. When we got it we epoxied it to the Axis camera with the lens in the center and hooked up the Ring Light to a 12V connection on the PD Board. We took a bunch of pictures at 320x240 resolution with the camera/LED with our Target and even in fairly bright ambient lighting the reflective tape is very bright. We started experimenting with the Vision Assistant using the method described here (Thanks Greg!) and after some tuning of the color parameters we found very good results with tracking the center of the Target with an execution time of approximately 12 mS. True, this was measured on the Laptop we were using and we have no testing yet on the cRIO itself but I am very impressed so far.
I am now a firm believer in the method described in Greg's paper rather than performing shape recognition. Earlier testing with the picture from the FRC manual (shrunk down to 320x240) required almost a full second per image to process, using the Performance Meter in Vision Assistant.
Unread 18-01-2012, 13:43
What are you using to program?
Unread 18-01-2012, 21:45
If you choose to go with the monochrome/grayscale approach, you may want to try setting the camera to have color disabled. This is a bit different from setting color level to 0. If you truly set the color enable to false, it will speed the decoding and avoid the cost of color altogether.
Greg McKaskle
Unread 19-01-2012, 10:29
DavidGitz's Avatar
We are using Labview but nothing in my original post requires that. Vision Assistant can create Labview vi's, Java and C++ code (I believe).
Unread 19-01-2012, 13:32
how would i create c++ stuff and where do you get the license for it. Off the labview install files?
Unread 19-01-2012, 15:08
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
This has everything in it:
http://www.usfirst.org/sites/default...20System_2.pdf
Unread 19-01-2012, 01:04
Lawlhwut Lawlhwut is offline
None #2853
Lawlhwut is an unknown quantity at this point
Quick question, how do I initialize the axis camera after delcaring it with "AxisCamera axis;"
Unread 19-01-2012, 01:33
WizenedEE's Avatar
AKA: Adam
Since it's a singleton and the get function returns a reference, you need to declare it as "AxisCamera& axis;"
Then, you use the GetInstance method in the initialization list.
class MyRobot : public SimpleRobot {
    AxisCamera& axis;
public:
    MyRobot()
        : axis(AxisCamera::GetInstance(/*ipaddress*/))
        // Constructor stuff
// rest of class
Alternatively, you could just call GetInstance whenever you want to call the AxisCamera methods and not have an instance variable for it at all.
