Go to Post anything is possible with dedication. - [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 18-01-2012, 14:08
brunoUC's Avatar
brunoUC brunoUC is offline
AKA: Bruno Toso
FRC #1156 (Under Control)
brunoUC is an unknown quantity at this point
cRIO setup issue
hi, we used to connect our 8 slots cRIO to the the classmate, but recently we changed it for other laptop and we are having some problems while trying to connect the cRIO.
we can see the crio in MAX and we need to reconfigure it with the CompactRIO imaging tool so we can use the labview 2011 on it, but when we press apply the folowing error messege appears:
The cRIO IP address is unreachable. Ensure that one of your computer's network adapters is on the same subnet.
thanks from team #1156
Unread 18-01-2012, 14:10
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: cRIO setup issue
We had similar issues. Here is a list of things we fixed and now it works:
Make sure you're wifi is off
Make sure you're IP is set correctly (see tutorial in Labview)
Make sure you set the subnet to 255.255.255.0
Make sure you turn any proxy off.
And make sure you are using the crossover cable
Unread 18-01-2012, 14:17
brunoUC's Avatar
AKA: Bruno Toso
i already turned the wi-fi off with the device manager and i already set the ip on both the crio and on the laptop.
thanks
Unread 18-01-2012, 16:51
twetherbee twetherbee is offline
Mentor, Team 987
FRC #0987 (High Rollers)
twetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud of
One of the team's I mentor also has been having cRIO connection issues.
We have been getting the following error:
Error -2147220304 occurred at nisyscfg.lvlib:Restart.vi:1
Possible reason(s):
NI System Configuration: (Hex 0x800404B0) Timeout while waiting for reboot. System is offline.
Complete call chain:
ConfigUtility.lvlib:2012_FormatSystem.vi
ConfigUtility.lvlib:ReImageTarget.vi
ConfigUtility.lvlibialog.vi
I called NI FIRST Tech support and I gave them the error message. They said that it is a pretty common error they have been seeing this year.
He suggested that we try going through the same sequence to wipe out and reflash the cRIO with the wireless card on your laptop ENABLED, but still connecting to the cRIO with the yellow crossover cable.
They said that depending on the laptop vendor, they have seen that this solves the problem about half of the time. They also said that there is a fix for this issue coming.
The tech support phone number is 800-531-5066 (M-F, 1PM-7PM CST). Their web support forum is also available all day long.
We haven't tried it yet (snowed in today in the Pacific Northwest), so I don't know if it solves our problem.
Good Luck.
Unread 18-01-2012, 21:33
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
We had a similar issue.
When setting ip-addresses on the ethernet port, sometimes windows 'remembers' the old
addresses and it confuses the FIRST cRIO imaging tool, but MAX tool work fine.
Open a command window
type 'ipconfig'
If the output shows multiple ip-addresses for your ethernet port, you can delete them
with netsh.
type 'netsh'
type help and it will show you the syntax to delete the extra addresses.
Unread 18-01-2012, 22:03
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
read this
Ed Barker
Unread 18-01-2012, 22:09
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
In addition to Ed's excellent advice, turn off any Bluetooth adapters on your PC as well!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 19-01-2012, 08:04
Depending on exactly what you mean by that, it might not be sufficient. You have to DISABLE the wireless interface, not just turn it off.
thanks
The error message suggests otherwise. It's pretty specific. Run the ipconfig command and copy its output here so we can make sure everything looks the way it ought to.
Unread 19-01-2012, 08:55
Mastonevich's Avatar
Mastonevich Mastonevich is offline
Andrew
AKA: Andrew Elsen
FRC #1987 (BroncoBots)
Mastonevich is a jewel in the roughMastonevich is a jewel in the roughMastonevich is a jewel in the rough
twetherbee, I believe we had the same error at first. We found that we didn't install the LabView program/required libraries (it is required to communicate with the cRIO) and after installation the timeout error ceased.
Unread 19-01-2012, 09:39
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Adding to the posts by ebarker and jon236, we found that, while doing the update from an Acer Windows 7 laptop, we also had to turn off the Windows Firewall, before we had success.
Interestingly enough, a few days earlier, we updated our other cRio from an Hp Windows XP desktop and had no issues.
Eric
Don't PANIC!
S. P. A. M.
Unread 19-01-2012, 10:01
brunoUC's Avatar
AKA: Bruno Toso
here is what the ipconfig shows:
ethernet adapter local area connection:
Connection-specific DNS suffix......:
link-local IPv6 address.................: fe80::b8a8:90c:febe:fec5%11
IPv4 address..............................: 10.11.56.6
subnet mask...............................: 255.255.255.0
default gateway..........................:0.0.0.0
10.11.56.2
Unread 19-01-2012, 11:40
Mentor, Team 987
Thanks for the reply. I'm more of a mechanical guy, so I'm just helping them apply basic problem solving strategies.
I'm pretty sure that they have all the software and updates loaded correctly, though. They had their laptops connected to the cRIO at one point, but couldn't get any of the code to work. Somewhere along the lines of debugging, something got corrupted or they thought to try wiping the cRIO again and start over. That is when this issue began.
Turns out that our original problem was likely due to the modules in our older cRIO not being rearranged to the new configuration for this year. (I keep telling them that documentation is your friend....)
We're all snowed in here for another day (I miss living in Wyoming and Montana where towns actually own enough snow plows that a couple inches of snow doesn't shut everything down.) so we'll have to wait and see if any of these methods work.
Unread 20-01-2012, 10:33
Andrew
AKA: Andrew Elsen
One other note I found. I had the connections to the cRIO working fine after initial install. At some point you have register with NI to complete their process which I thought I had done. Then our connections stopped working with your same error. Through troubleshooting I finally restart our programming laptop, and it came up with the registration again. It required the fill in more required fields on the NI registration. From that point forward everything started working.
Unread 20-01-2012, 12:09
ebarker's Avatar
AKA: Ed Barker
Yes indeed - 'disable' all network interfaces, wireless, extra wired, bluetooth, hamachi, and anything that looks like an network interface.
If you do not disable all that then variations occur between PC's depending depending on the local PC configuration and how things are timing out in the NI software. That is why some computer work and some done. It depends on whether it can find the cRio before the timeouts occur.
So just do it to procedure and it will be fine. One day we will get an update that improves things, one day.
Ed Barker
